Crucetas Spicer Dana 44 5-760X
Vendo par de crucetas Dana Spicer 5-760x traidas desde USA.
Sirven para los ejes Dana 44. Estas crucetas son una nueva version de Dana Spicer y segun dicen aguantan un 30% mas que las crucetas normales. Ademas de ser originales Dana Spicer. http://www.4wheeloffroad.com/product...u_joint_jeeps/ http://www.quadratec.com/products/52302_102.htm Estan nuevas en caja. $60.000 el par. No se venden por unidad ni se baja el precio ya que me salio muy caro el envio. http://www.northerndrivetrain.com/im...spi-5-760x.jpg |
Re: Crucetas Spicer Dana 44 5-760X
Tambien sirven para Dana 30.
Application Chart 1972 - 1991 Chevy K-5 Blazer & GMC Jimmy... all 1 3/16 inch diameter bearing cap 1972 - 1986 Chevy K-10 & K-20, GMC K-15, K-25 Pick-Up... all 1 3/16 inch diameter bearing cap 1972 - 1993 Dodge W100, W150, W200, W250... all 1 3/16 inch diameter bearing cap 1973 - Dodge W300, W350... all 1 3/16 inch diameter bearing cap 1973 - 1975 Dodge WM300 POWER WAGON... all 1 3/16 inch diameter bearing cap 1994 - 2001 Dodge RAM 1500 with Dana 44... all 1 3/16 inch diameter bearing cap 1994 - 1999 Dodge RAM 2500 with Dana 44... all 1 3/16 inch diameter bearing cap 1974 - 1993 Dodge RAMCHARGER... all 1 3/16 inch diameter bearing cap 1978 - 1996 Ford Bronco all 1 3/16 inch diameter bearing cap 1975 - 1977 Ford F100 Full Time... all 1 3/16 inch diameter bearing cap 1972 - 1977 Ford F100 Part Time... all 1 3/16 inch diameter bearing cap 1976 - 1979 Ford F150 Full Time... all 1 3/16 inch diameter bearing cap 1976 - 1997 Ford F150 Part Time... all 1 3/16 inch diameter bearing cap 1975 - 1979 Ford F250 Full Time with Dana 44... all 1 3/16 inch diameter bearing cap 1978 - 1995 Ford F250 Part Time with Dana 44... all 1 3/16 inch diameter bearing cap 1980 - 1985 Ford F350 Part Time with Dana 44... all 1 3/16 inch diameter bearing cap 1980 - 1997 Ford Ranger ...all 1 3/16 inch diameter bearing cap 1974 - 1980 IHC Scout 800 Series all 1 3/16 inch diameter bearing cap 1974 - 1979 IHC 100, 110, 120, 900, 1000, 1200 Series all 1 3/16 inch diameter bearing cap 1984 - 2001 Jeep Cherokee Compact XJ... all 1 3/16 inch diameter bearing cap 1982 - 1988 Jeep 10 Series...all 1 3/16 inch diameter bearing cap 1974 - 1988 Jeep 20 Series...all 1 3/16 inch diameter bearing cap 1974 - 1981 Jeep 40 Series...all 1 3/16 inch diameter bearing cap 1974 - 1983 Jeep Cherokee Full Size SJ...all 1 3/16 inch diameter bearing cap 1994 - 1999 Jeep Grand Cherokee...all 1 3/16 inch diameter bearing cap 1983 - 1991 Jeep Grand Wagoneer...all 1 3/16 inch diameter bearing cap 1978 - 1983 Jeep Wagoneer...all 1 3/16 inch diameter bearing cap 1984 - 1990 Jeep Wagoneer Compact XJ... all 1 3/16 inch diameter bearing cap 1997 - 2006 Jeep Wrangler TJ... all 1 3/16 inch diameter bearing cap 1993 - 1995 Jeep Wrangler YJ... all 1 3/16 inch diameter bearing cap |
Hola cumpita.
Te comento que instale dif. De cheroke en una blazer y no he podido encontrar la cruceta delantera. Será esta que tu tienes la que yo necesito ??? Si tu crees que si me sirve te las compro. Saludos |
Hola Patito.
Tanto tiempo cumpa. Porque no mides tus crucetas para asegurarte. El diametro de los cubos que tengo yo deberian ser: Cubo = 1.188 inches ( 1 3/16 inches ) |
Hola chino!!!!!
Vas al dia nacional del jeepero??? Saludos federico |
Aun disponibles.
Acepto ofertas. |
| La franja horaria es GMT -3. Ahora son las 17:15:35. |
