-   -   Motores en Wagoneer (http://www.twistedandes.com/foro/showthread.php?t=14744)
Javier Acuña 27-07-2005 11:46:34
Motores en Wagoneer
Cuales fueron los Wagoneers que traían el 360 y 401? Que ejes eran los que usaban?
Mario Cerda 27-07-2005 12:53:48
Wagoneer 1971-1983
Grand Wagoneer 1984-1991
J-Series Truck 1971 - 1987
Engine
Type : 6 Cyl
Displacement : 258 ci
Bore & Stroke : 3.75 x 3.90 in
Compression Ratio : 8.0:1
Power : 110hp @ 3,500
Torque : 195lb-ft @ 2,000
Induction : 1bbl Carter YF
Type : V-8 OHV
Displacement : 304 ci
Bore & Stroke : 3.75 x 3.44 in
Compression Ratio : 8.4:1
Power : 150hp @ 4,200
Torque : 245lb-ft @ 2,500
Induction : 2bbl Autolite 2100
Type : V-8 OHV
Displacement : 360 ci
Bore & Stroke : 4.08 x 3.44 in
Compression Ratio : 8.25:1
Power : 175hp @ 4,000
Torque : 285lb-ft @ 2,400
Induction : 2bbl Autolite 2100 /4bbl Autolite 4300
Type : V-8 OHV
Displacement : 401 ci
Bore & Stroke : 4.16 x 3.68 in
Compression Ratio : 8.35:1
Power : 215hp @ 4,200
Torque : 320lb-ft @ 2,800
Induction : 4bbl Autolite 4300
Transmission
Type & Model (Manual)
1. 3 Speed Warner T-14A (1971-79 6cyl Wagoneers)
2. 3 Speed Warner T-15A (1971-79 V8 Wag. & Trk)
3. 4 Speed Warner T-18 (1971-79 Wag, 71-87 Trk)
4. 4 Speed Tremec T-176 (1980-86 Wag & Trk)
Ratios
1. 1)3.10 2)1.74 3)1.00 R)3.10
2. 1)3.00 2)1.83 3)1.00 R)3.00
3. 1)6.32 2)3.09 3)1.69 4)1.00 R)7.44
4. 1)3.52 2)2.27 3)1.46 4)1.00 R)3.52
10.5" (6 Cyl)
Type & Model (Automatic)
1. 3 Speed GM TH-400 (1971-79 with Quadra-Trac)
2. 3 Speed Chrysler TF-727 (1980-91 Wag, 80-87 Trk)
Ratios
1. 1)2.48 2)1.48 3)1.00 R)2.07
2. 1)2.45 2)1.45 3)1.00 R)2.00
Clutch Diameter
10.5" (6 Cyl)
11" ( V-8 )
Transfer Case
Type & Model (Part Time)
1. 2 Speed Dana 20 (std 1971-79 manual trans)
2. 2 Speed NP-208 "Command Trac" (std 1980-91)
3. 2 Speed NP-229 "Selec-Trac" (opt 1983-86)
4. 2 Speed NP-228 "Quadra-Trac" (opt 1985-91)
5. 2 Speed NP-242 "Selec-Trac" (opt 1987-91)
Ratios
1. 2.57/1.00
2. 2.60/1.00
3. 2.61/1.00
4. 2.61/1.00
5. 2.72/1.00
Type & Model (Full Time)
1. 1 or 2 Speed BW 1339 "Quadra-Trac" (1971-79 automatic trans)
2. 2 Speed NP-219 "Quadra-Trac " (opt 1980-85)
Ratios
1. 2.03/1.00
2. 2.61/1.00
Axles
Front Type & Model
FF, Dana 44
Rear Type & Model
SF, Dana 44 (1971-75 Wag, 1/2 ton Trk, 74-83 wide track, 87-91 Grand Wag)
SF, AMC 20 (1976-86 Wag & 1/2 ton Truck)
SF, Dana 60 (1971-1987 3/4 ton Truck)
FF, Dana 60 (1971-87 3/4 ton, 1 ton Truck)
Ratios
3.07, 3.31/3.54, 3.73 Wagoneer
3.07, 3.54/3.73, 4.09 Truck
Notes:
1974 the Axles went from a track width of 57.5" to 59" (narrow track Wagoneers & Cherokees). It also marked the first year of the open knuckle design and disk brakes. It also changed the wheel lug pattern from 5 on 5.5" to 6 on 5.5". The years of
1974-mid 1977 the front Dana 44 came with the desirable "flat top" knuckle design, which is used for the high steering setup.
1979 an older have a passenger side front differential.
1980 - 1991 have a drivers side front differential
Javier Acuña 27-07-2005 13:20:22
Empezado por Mario Cerda
Type : V-8 OHV
Type : V-8 OHV
Don Mario, sabía que serías tu el que me respondería! :D
Pero que años se vieron los motores 360 y 401? Cuales son los modelos que lo tienen?
Hernan Iriarte 27-07-2005 15:40:57
podrias poner el link de la pagina, como pa hecharle una miradita (cultura general :lol: )
RoNdrigo Pastén 27-07-2005 17:12:32
una vez encontre una wagoneer que tenia V8 de fabrica, diferencial Dana 44 trasero y Dana 27 delantero.
Que motor seria ese :?:
Me imagino que seria una mas antigua que las que publicaste.
Mario Cerda 27-07-2005 17:49:24
Empezado por Hernan Iriarte
http://www.jeepgod.net/wagoneer.html
Mario
Mario Cerda 27-07-2005 18:02:36
Empezado por Javier Acuña
Para los Jeep Wagoneers, la información que dispongo dice:
AMC 360
Disponibilidad:
Opcional en Custom del 71 al 73
De serie en Standard y Custom de 74 al 77
De serie en Limited el 78
De serie del 79 al 80
Opcional del 81 al 86
De serie del 87 al 91
AMC 401
Disponibilidad
Opcional en Standard y Custom del 74 al 77
Opcional en Limited el 78
Mario Cerda 27-07-2005 18:07:05
Empezado por RoNdrigo Pastén
Hola Rodrigo,
Ese es un AMC de 327 cid (conocido como Vigilante) que se uso en las Wagoneer entre 1965 y 1968
AMC 327 V8
Bore x Stroke : 4.00" x 3.25"
Displacement : 327 (5.35L)
Compression Ratio : 8.7:1
Horsepower (gross) : 250@4700
Torque (gross) : 340@2600
Main Bearings : 4
Valve Configuration : OHV
Fuel : 2bbl carburator
Mario
Javier Acuña 27-07-2005 18:31:02
AMC 360
Disponibilidad:
AMC 401
Disponibilidad
Ahora si!!! Gracias compadre, al parecer me gusta lo que me ofrecen, es un Wagoneer 1981 en un palo. Lo único que sabe el dueño que es V8 y que alguien le dijo que era un 6.3
No es malo :wink:
Mario Cerda 27-07-2005 18:34:18
No es malo :wink:
Hola Javier,
Que te mande el VIN y sabemos al toque que motor tenía de fabrica.
Mario
La franja horaria es GMT -3. Ahora son las 11:12:19.
