Antiguo 25-09-2008, 00:37:43   #1
caxtrol
Smile Interesante articulo sobre el ancho de los neumaticos
Para los que les interesa saber mas del tema, les dejo el link
http://www.expeditionswest.com/resea...tion_rev1.html
y un pequeño resumen para los que no tenga tiempo que tambien aparece en el link.
The impact of tire width on traction
Position: A tall, narrow tire is a superior choice for all off-highway surface conditions with the exception of deep, soft sand or mud.
Summary:
This is an empirical summary of my position. The supporting details of this argument are contained in the body of the document. The start of my study came as a result of asking the critical question. What is better for most trail surfaces; a wide or narrow tire?
This initially led me to research the physics of tire traction, which is mostly related to dynamic friction as the vehicles are not just parked on a surface trying to maintain a static state. There has been some research on the subject related to performance vehicles and race cars, operating on highly tactile surfaces, and running at high speeds (and subsequent heat generation), but there was no significant research done for off-highway vehicle operation. So I spent several months researching the subject, testing the logic and formulating a position. Why a position, and not a conclusion or "law" of tire performance? For me to proclaim a conclusion would require much greater testing volume, samples, variables etc., which time does not allow. So, the following is my position.
When driving off-highway, the performance of a vehicles tires is influenced by the elements of friction as related to the following items: Adhesion, momentary molecular bonding, deformation and mechanical keying (Haney, 2003). Where a race car operates on a highly tactile surface, which allows wide, even smooth tires to perform exceptionally (due to adhesion and bonding), an off-highway vehicle operates in the exact opposite environment, with minimally tactile surfaces. Rocks, dirt ledges, dusty boulders, highly irregular surfaces, sandy washes, etc. occupy the fourwheeler's environment. Surfaces that do not provide high adhesion rates or momentary bonding. However, these surfaces are highly irregular, which does provide the opportunity to take advantage of mechanical keying and deformation. These traction elements require high contact pressure, coupled with low air pressure to get the tire to flex with the terrain. A wide tire distributes the vehicles weight over too large of a surface, preventing deformation from occurring at the same rate as a narrow tire with the same pressure (force). A narrow tire will hold better than a wide one by keying to the surface aggregate due to the greater vertical force.
It is important for me to note that this document is NOT about reducing tire air pressure "airing down". Airing down provides its own performance benefits which are not covered in detail in this paper. For all examples assume that the wide and narrow tire are both at 15psi for the trail.
Abstract:
While the coefficient of friction (Ff = Cf x Fv) is linear and not affected by width (on a perfectly smooth surface, traction is consistent despite width), it is the variability of the road surface conditions off-highway that improves traction for a narrow tire. The greater the contact pressure, the greater of effectiveness of the friction elements of Deformation and Mechanical Keying. A narrow tire also presents less rotating resistance on a soft surface, like shallow mud, snow and sand. Additional performance is gained by the assumption that most vehicles can fit a taller tire if it is narrower, which provides greater axle clearance. Final arguments are made for the benefits related to reduced rotating mass and unsprung weight.
CAXTROL
caxtrol está offline   Responder Con Cita
Antiguo 25-09-2008, 01:41:22   #2
Jorge Cila y M.Teresa
Avatar de Jorge Cila y M.Teresa
Edad: 78
Predeterminado Re: Interesante articulo sobre el ancho de los neumaticos
Descueve
¿quién traduce?
Jorge Cila y M.Teresa está offline   Responder Con Cita
Antiguo 25-09-2008, 01:57:30   #3
saggcl
Avatar de saggcl
Empezado por Jorge Cila y M.Teresa Ver Mensaje
Descueve
¿quién traduce?
http://translate.google.es/translate...-8&sl=en&tl=es
Antiguo 25-09-2008, 03:18:45   #4
RoNdrigo Pastén
Banned
ok, segun el link del amigo, ahi va :
Tire de Expediciones Selección de viajes: El impacto de la anchura del neumático de tracción
Article Type: Position Paper, White Paper Tipo de artículo: documento de posición, Libro Blanco
By: Scott Brady, Expedition's West Por: Scott Brady, de la Expedición del Oeste
Date: 3/28/2005 (revised 4/17) Fecha: 3/28/2005 (revisado 4 / 17)
Position: A tall, narrow tire is a superior choice for all off-highway surface conditions with the exception of deep, soft sand or mud. Posición: Un alto, estrecho neumático es una opción superior para todas las carreteras fuera de las condiciones de superficie, con la excepción de profunda, suave arena o barro.
Index: Índice:
I. Summary I. Resumen
II. Abstract II. Resumen
III. Definitions III. Definiciones
IV. Understanding tire placarding IV. Neumático de fijación de Entendimiento
V. Understanding off-highway tire performance V. entendimiento fuera de la carretera el rendimiento del neumático
VI. Recommended Sizes for GVW VI. Recomendados para tamaños PBV *
VII. Real world examples of narrow tire use VII. Mundo real ejemplos de reducir el uso de neumáticos
VIII. History of tire engineering VIII. Historia de la ingeniería de neumáticos
VIIII. Other tire selection considerations Viii. Otras consideraciones de selección de neumáticos
X. References X. Referencias
Summary: Resumen:
This is an empirical summary of my position. Este es un resumen empírico de mi posición. The supporting details of this argument are contained in the body of the document. Los detalles de este argumento están contenidas en el cuerpo del documento. The start of my study came as a result of asking the critical question. El comienzo de mi estudio llegó como resultado de pedir a la cuestión fundamental. What is better for most trail surfaces; a wide or narrow tire? ¿Qué es mejor para la mayoría de las superficies de pista, un amplio o estrecho neumático?
This initially led me to research the physics of tire traction, which is mostly related to dynamic friction as the vehicles are not just parked on a surface trying to maintain a static state. Esto me llevó inicialmente a la investigación de la física del neumático de tracción, que es principalmente relacionados con la dinámica de fricción como los vehículos no son sólo estacionado en una superficie tratando de mantener un estado estático. There has been some research on the subject related to performance vehicles and race cars, operating on highly tactile surfaces, and running at high speeds (and subsequent heat generation), but there was no significant research done for off-highway vehicle operation. Ha habido algunas investigaciones sobre el tema relacionado con el desempeño y carrera de vehículos automóviles, que operan en superficies altamente táctil, y corriendo a altas velocidades (y la posterior generación de calor), pero no hubo importantes investigaciones realizadas por fuera de la carretera el funcionamiento del vehículo. So I spent several months researching the subject, testing the logic and formulating a position. Así pasé varios meses investigando el tema, la lógica de pruebas y la formulación de una posición. Why a position, and not a conclusion or "law" of tire performance? ¿Por qué una posición, y no una conclusión o "ley" de neumáticos de rendimiento? For me to proclaim a conclusion would require much greater testing volume, samples, variables etc., which time does not allow. Para mí, de proclamar una conclusión requeriría mucho mayor volumen de pruebas, muestras, variables etc, que el tiempo no lo permiten. So, the following is my position. Así pues, la siguiente es mi posición.
When driving off-highway, the performance of a vehicles tires is influenced by the elements of friction as related to the following items: Adhesion, momentary molecular bonding, deformation and mechanical keying (Haney, 2003). Cuando la conducción fuera de carretera, la ejecución de un neumáticos de vehículos está influenciada por los elementos de fricción en relación con los temas siguientes: Adhesion, momentánea unión molecular, y la deformación mecánica introducir (Haney, 2003). Where a race car operates on a highly tactile surface, which allows wide, even smooth tires to perform exceptionally (due to adhesion and bonding), an off-highway vehicle operates in the exact opposite environment, with minimally tactile surfaces. En caso de que un coche de carreras funciona en una gran superficie táctil, que permite una amplia, incluso las llantas lisas para llevar a cabo con carácter excepcional (debido a la adhesión y de unión), un fuera de la carretera vehículo opera en el medio ambiente exactamente lo contrario, con un mínimo de las superficies táctiles. Rocks, dirt ledges, dusty boulders, highly irregular surfaces, sandy washes, etc. occupy the fourwheeler's environment. Rocas, repisas suciedad, polvo, rocas, superficies muy irregulares, lavados de arena, etc ocupar el fourwheeler del medio ambiente. Surfaces that do not provide high adhesion rates or momentary bonding. Superficies que no ofrecen las tasas de alta adherencia o unión momentánea. However, these surfaces are highly irregular, which does provide the opportunity to take advantage of mechanical keying and deformation. Sin embargo, estas superficies son muy irregulares, que ofrece la oportunidad de tomar ventaja mecánica de introducir y deformación. These traction elements require high contact pressure, coupled with low air pressure to get the tire to flex with the terrain. Estos elementos requieren de tracción de alta presión de contacto, junto con la baja presión del aire para obtener el neumático a la flexión con el terreno. A wide tire distributes the vehicles weight over too large of a surface, preventing deformation from occurring at the same rate as a narrow tire with the same pressure (force). Un gran neumático distribuye el peso sobre los vehículos es demasiado grande de una superficie, evitando la deformación se produzca a la misma tasa que un neumático estrecho con la misma presión (fuerza). A narrow tire will hold better than a wide one by keying to the surface aggregate due to the greater vertical force. Un estrecho neumático se mantenga mejor que una por una amplia Introducción a la superficie total debido a la mayor fuerza vertical.
It is important for me to note that this document is NOT about reducing tire air pressure "airing down". Es importante para mí señalar que este documento no es acerca de la reducción de la presión del aire del neumático "se transmite de abajo". Airing down provides its own performance benefits which are not covered in detail in this paper. Transmitido por su propia proporciona ventajas de rendimiento que no están cubiertos en detalle en este documento. For all examples assume that the wide and narrow tire are both at 15psi for the trail. Para todos los ejemplos asumen que la amplia y estrecha de neumáticos son a la vez en 15psi para la pista.
Abstract: Resumen:
While the coefficient of friction (Ff = Cf x Fv) is linear and not affected by width (on a perfectly smooth surface, traction is consistent despite width), it is the variability of the road surface conditions off-highway that improves traction for a narrow tire. Si bien el coeficiente de fricción (FF = Cf x FV) es lineal y no afectadas por el ancho (en una superficie perfectamente lisa, la tracción es coherente a pesar de ancho), es la variabilidad de la superficie de la carretera condiciones fuera de carretera que mejora la tracción para un estrecho de llantas. The greater the contact pressure, the greater of effectiveness of the friction elements of Deformation and Mechanical Keying. Cuanto mayor sea la presión de contacto, la mayor eficacia de la fricción de elementos de deformación mecánica Introducción. A narrow tire also presents less rotating resistance on a soft surface, like shallow mud, snow and sand. Un estrecho neumático también presenta menos resistencia a la rotación sobre una superficie blanda, como poco barro, nieve y arena. Additional performance is gained by the assumption that most vehicles can fit a taller tire if it is narrower, which provides greater axle clearance. Rendimiento adicional es adquirida por la hipótesis de que la mayoría de los vehículos pueden encajar un taller de neumáticos si es más restringido, que proporciona una mayor limpieza de eje. Final arguments are made for the benefits related to reduced rotating mass and unsprung weight. Final argumentos se hacen por los beneficios relacionados a la reducción de masa en rotación y unsprung peso.
Antiguo 25-09-2008, 03:20:45   #5
RoNdrigo Pastén
Banned
repeti el post
Antiguo 25-09-2008, 12:56:54   #6
Roland
Avatar de Roland
Que buena la conclusión del gringo..... Para discutir un poco
Antiguo 25-09-2008, 13:00:13   #7
caxtrol
Roland
Parece que tu ya habias leido el articulo, por la configuracion barrera que tienes.
Antiguo 25-09-2008, 15:30:12   #8
TaTan MiTsU
En resumidas cuentas,
Arena y pavimento, neumaticos mas anchos, mayor superficie de contacto, carga del peso mas esparcida, mejor agarre.
Barro, tierra y rocas, neumaticos mas altos y no tan anchos, carga del peso mas centrada, mejor agarre.
Sl2
Antiguo 25-09-2008, 15:44:59   #9
GastonSur
Empezado por RoNdrigo Pastén Ver Mensaje
repeti el post
Te diste un buen trabajo.
Antiguo 25-09-2008, 15:54:59   #10
Roland
Avatar de Roland
Empezado por caxtrol Ver Mensaje
Roland
De alguna forma si José, pero no leyendo este artículo, si no observando que se hace en otros países distintos de USA, por ejemplo OZ, algunos de Asia y otros de Europa.
En general, para el barro, neumas angostos y altos, como el simex 35x10,50 que tengo instalado para esos propósitos.
Para arena y otros terrenos, el pitbull 35x14,50. Hasta ahora esa configuración me dado muy buenos resultados.
La franja horaria es GMT -3. Ahora son las 11:17:44.
