Antiguo 02-06-2009, 13:22:38   #1101
Pato-Patrol
Predeterminado Re: SJ413 - Gonzalo Bravo
Nice !!!! ...
como para subir el World Record unos metros mas, por si se les ocurre venir a los alemanes nuevamente ...
Antiguo 02-06-2009, 21:59:25   #1102
Roland
Avatar de Roland
ni mas ni menos que un 2JZ
Y en auto viene ???
Antiguo 02-06-2009, 22:18:38   #1103
Y en auto viene ???
Ese motor viene el el Toyota Aristo y en el Toyota Supra Japones, tambien el Toyota Supra de Exportacion y en el Lexus GS300.
Hay diferencias estre el modelo JDM y el el USDM, pero son basicamente los mismos motores con diferentes turbos y electronica.-
2JZ-GTE
Engine bay of MK4 Supra
The 2JZ-GTE is an inline-layout, six-cylinder, belt-driven dual-overhead camshaft, air-intercooled, twin-turbocharged, cast-iron engine designed and manufactured by Toyota Motor Corporation that was produced from 1991 untill 2002 in Japan. Final development of the 2JZ-GTE was outsourced to German engineering firm Johann A. Krause Maschinenfabrik GmbH for refinement to meet production car homogolation requirements set forth by the former All-Japan Grand Touring Car Championship. Two gearboxes were offered for the engine:
* Toyota A341E 4-speed automatic
* Toyota V160 and V161 6-speed manual (jointly developed with GETRAG GmbH as the Type 233)
The 2JZ-GTE originally powered the Toyota Aristo V (JZS147) in 1991 before becoming Toyota's flagship performance engine in the Toyota Supra RZ (JZA80). Its mechanical basis was the existing 2JZ-GE, but differed in its use of sequential twin turbochargers and an air-to-air side-mounted intercooler. The block, crank, and connecting rods of the 2JZ-GE and 2JZ-GTE are the same with the exception that the 2JZ-GTE has a forged crankshaft and oil squirters installed in the block to aid in cooling the pistons. Toyota's VVT-i variable valve timing technology was added to the engine beginning in September 1997, whence it phased out the original engine. Consequently, maximum torque was raised for engines selling in all markets.
The addition of twin turbochargers, jointly developed by Toyota with Hitachi, in sequential configuration had raised its commercially-cited output from 230 PS (166 kW, 225 hp DIN) to the, then, Japanese auto industry maximum of 280 PS (206 kW, 280 hp DIN) at 5600 rpm. In its first appearance, torque was advertised as 44.3 kgm (435 Nm, 320 lbft) to be later recited as 46.4 kgm (455 Nm, 335 lbft) with the introduction VVT-i in 1997. The mutually-agreed, industry-wide output ceiling was enforced by Japan's now-defunct "Gentlemen's Agreement" exclusively between Japanese automakers selling to the Japanese domestic market. For the North American and European markets, power was raised to 320 hp DIN (229 kW) at 5600 rpm.
The export version of the 2JZ-GTE achieved its higher power output with the use of newer stainless steel turbochargers (ceramic for Japanese models), revised camshafts, and larger injectors (550 cc/min for export, 440 cc/min for Japanese). The mechanical similarities between the Japanese-specification CT20 turbine and export-specification CT12B turbine allow interchangeability of the exhaust-side propeller shaft. Additionally, the export-exclusive CT12B turbine received more durable turbine housings and stainless steel turbine and impeller fins. Multiple variants of the Japanese CT20 turbine exist discretely, which identified with the B, R, and A part number suffixes (eg.: CT20A).
The flagship 2JZ-GTE engine is popularized as the adversary to Nissan's RB26DETT, both with regards to their iron block-attributed durability, inline-six configuration, aftermarket recognition, and auto racing pedigree. Both of these engines, after having been extremely modified and tuned, can produce over 1,000 hp.
Applications:
* Toyota Aristo V300 JZS161 (Japan-only)
* Toyota Supra RZ/Turbo JZA80
Antiguo 03-06-2009, 16:27:56   #1104
RNewcomb
unos pocos mods mas y.....
Estas seguro que este video no es de una Hayabusa???
Harto simpático el motorcito, quedará muy entretenido de manejar.
Antiguo 03-06-2009, 16:35:50   #1105
Pancho Ibarra
Avatar de Pancho Ibarra
Y finalmente que caja usaras??
Antiguo 03-06-2009, 21:44:51   #1106
Empezado por Pancho Ibarra Ver Mensaje
La caja sera la A340 que trae, no estoy aun seguro de las transfers, pero hasta hoy la idea es:
2JZ GTE
Caja Toyota A340E convertida a F (poniendo el eje de salida y cola de la AW4)
Cuerpo reductor planetario de la NP231
Transfer Toyota TLC
Mis ejes, cardanes y todo.
Antiguo 03-06-2009, 21:49:36   #1107
Roland
Avatar de Roland
Ahora ya me enriele en el proyecto...
Antiguo 04-06-2009, 12:18:53   #1108
Pancho Ibarra
2JZ GTE
Transfer Toyota TLC
Perfecto y como andan las relaciones de esa caja con respecto a una Hilux ?
Relacion final app ?
Antiguo 04-06-2009, 13:04:44   #1109
A que te refieres? Esta es A/T y las Hilux son mecanicas.
De relacion final va a quedar impecable, ya que ese conjunto viene con coronas 3.9:1, y considerando que yo tengo 5.13, el motor tiene su regimen optimo con 33.6", lo cual lo hara ideal para andar en dunas con 33" y el resto con 36" .
Por el lado del dual, si bien con la caja A/T anda bien con una sola transfer, con dos va a quedar muy comodo con caja A/T y un "crawl ratio" de 100:1.-
Antiguo 04-06-2009, 16:55:12   #1110
Pancho Ibarra
Es automatica, no tenia idea, va quedar excelente con caja AT y con 100:1 ideal.
Gonzalo Bravo, el Famoso RoNdrigo Pastén General 5 17-09-2009 03:49:32
Vendo equipos para Suzuki Samurai o SJ413 Roland Venden - Partes y accesorios para 4X4 81 04-06-2007 17:34:36
Felicitaciones a DON Gonzalo Bravo Panz General 2 28-04-2007 20:58:00
Torque Pernos Corona de SJ413 sj413 General 4WD 6 16-08-2004 10:09:56
Gonzalo Bravo, ¿fuiste a Glamis y no avisaste? pato castro General 4 31-12-1969 21:00:00
La franja horaria es GMT -3. Ahora son las 06:43:10.
