Antiguo 29-01-2004, 07:36:29   #11
Empezado por MJN
jajjajaja
oye pero las llantas cuentan
no pusiste minimo de cosas
Asi es TODO vale.-
Antiguo 29-01-2004, 08:46:47   #12
poroto ®
Contactar con poroto ® a través de ICQ Contactar con poroto ® a través de MSN
aparentemente el jeep se llama FIREANT
pertenece al equipo Currie/wagoneer que participa en el circuito ARCA
algunos datos
- two feet above ground and six feet below
-started with the burned-out hulk of a late model TJ Wrangler
-narrower body might negotiate squeezes better, so he cut 3.25" from each side of the tub and took 6.5" from the hood and grill
-4.7 liter Power Tech V8 and five-speed automatic transmission from a Grand Cherokee.
-Mopar parts under the hood.
-custom brass radiator from Mattson Radiator
-air filter from K&N
-The stock Cherokee exhaust manifolds
-custom stainless 12-gallon gas tank
- Atlas II gear-driven transfer case from Advance Adapters
-front, a trimmed Ford 9" heavy-duty housing
-Currie High Pinion 9" third member with 4.56 gears and a Detroit Locker
-The axles are 35-spline, and one-ton knuckles were used for strength.
-Wilwood disc brakes all around
-37x12.50R15LT Goodyear Wrangler MTR's mounted on 15x8" Centerline Hellcat wheels with Champion Beadlocks
-custom triangulated Currie rear suspension with coil springs and wrap-under long lower rear arms (back)
-custom long wrap-under lower arms were used also and we can report they work beautifully. Coilovers from Swayaway, instead of separate TJ coils and shocks
-polished stainless column and steering shaft from Flaming River
- AGR provided it's Rock Ram hydraulic ram assisted steering kit to go along with their heavy-duty pump and Type II steering box
-Extra tough 1.25x.500" chromoly tie rod and drag link with heim ends
-one-inch higher on the frame by using modified and cut body mounts. Currie Enterprises rocker guards and front and rear Rock Crawler bumpers also keep the rocks at bay
-custom 5/16" aluminum skidplates act as the crossmember and also protect the transmission and engine oil pan.
-Warn XD9000i
-full roll cage with "Spotter Bars" to keep the spotter in contact with the Jeep
-Beard Super Seats with S-line seatbelts and a custom dash with Autometer gauges from James Gang Racing
- 1/3 horsepower Currie 12-volt compressor and battery cutoff switch was installed under the front passenger seat
http://www.extreme4x4.com/Fireant/page7.html
pertenence a jon currie (el dueno de currie)
ojala no me equivoke pero se parece demasiado
poroto ® está offline   Responder Con Cita
Antiguo 29-01-2004, 08:47:53   #13
ChernobylV8
Resumo en 2 palabras
"CURRIE ENTERPRISES"
Antiguo 29-01-2004, 08:51:08   #14
GerardoLW
Contactar con GerardoLW a través de MSN
Wrangler TJ de Currie Enterprises, le llaman Fire Ant Jeep. Jeff waggoner and John Currie eran piloto y copiloto respectivamente cuando en el 2001 ganaron el evento final del Goodyear Skyjacker Extreme Rock Crawling.
Specs:
Engine: 4.7 liter Jeep Power Tech OHC V8
Induction: Multi point sequential fuel
injection Transmission: Grand Cherokee five-speed automatic
Transfer Case: 3.01:1 Atlas II
Front end: 63" wide Currie High Pinion 9" with one-ton knuckles, 35- spline axles, Detroit Locker, Wilwood brakes and Warn locking hubs
Rear end: 63" wide Currie High pinion 9" with 35-spline axles, Detroit Locker and Wilwood disc brakes
Ring and Pinion: 4.56:1
Suspension: Custom Currie long arm with coilover front and triangulated rear with coils and long wrap-under arms
Tires/Wheels: 37x12.50R15LT Goodyear Wrangler MTR's/Centerline 15x8" Hellcats with Champion Beadlocks
Sponsors:
Currie Enterprises - Rearends, Suspension, Components & Set-up - Anti-RockTM™ Sway Bar, 9-PlusTM Rearend Housings & Components, Goodyear® - Tires, Advanced Adapters®, - Atlas II Transfer Case, Detroit Lockers® - Locking Differentials, Warn® - Winches & Hubs, Mickey Thompson® - Wheels, Sway-A-Way® - Shock Absorbers, Centerline Wheels® - Wheels
GerardoLW está offline   Responder Con Cita
Antiguo 29-01-2004, 08:52:34   #15
poroto ®
ja ja
parece ke llegue primero
ojala haya ganado
:D
agrego fotito mas derecha
Antiguo 29-01-2004, 08:56:58   #16
GerardoLW
Pero tengo los Sponsors :D :D :D
Antiguo 29-01-2004, 09:04:36   #17
MIREN BIEN, EL TIEMPO PASA...
Asi como en los sorteos anteriores, sorry que no lo haya mencionado, NO SE PUEDE EDITAR LOS MENSAJES, debe ser uno nuevo.-
Antiguo 29-01-2004, 15:04:25   #18
m.J.n.
TA DIFICIL :?
m.J.n. está offline   Responder Con Cita
Antiguo 29-01-2004, 16:02:35   #19
poroto ®
re100 me di kuenta que parece no ser el fireant
el otro tiene coilovers adelante y atras
este solo espirales
esas barra que como que se enroscan en los yugos ke son?
barras de torsion?
Antiguo 29-01-2004, 16:41:02   #20
Empezado por poroto
este solo espirales
barras de torsion?
Asi es, no tiene Coilovers.
Esas barras son los tensores y son una particularidad de la tienda que lo armo :wink:
FALTA POCO PARA LOS 100.000post EN TWISTEDANDES!!!! -ArtSerey- General 87 15-09-2004 16:56:27
Twisted Andes en Desafío de Los Volcanes 2003 MLOZANO General 2 31-12-1969 20:00:00
PORTADAS TWISTED ANDES MLOZANO General 1 31-12-1969 20:00:00
MI PRESENTACION EN TWISTED ANDES Y UN GRAN SALUDO KARLITROZ POZO Novatos 10 31-12-1969 20:00:00
La franja horaria es GMT -3. Ahora son las 20:44:42.
