Antiguo 04-07-2007, 14:14:08   #11
Pancho Coddou
Predeterminado Re: Throttle.... Para Que Sirven
no es por ser mala onda pero todos los datos serios que he visto sobre los throttle body spacer indican que no hacen nada, voy a buscar mas info.
Antiguo 04-07-2007, 14:46:29   #12
pato castro
Avatar de pato castro
No sirven para nada, plata a la basura, a lo mejor pueden mejorar un poco el rendimiento al separar la mariposa del múltiple de admisión y evitar que esta se caliente, pero no veo mucha mejora si así fuera...
Antiguo 04-07-2007, 14:52:14   #13
Pancho Coddou
en un motor con carburador y en menor medida con tbi hace algo pero en motores inyectados al parecer nada, he estado mirando un poco y encontre un cosa que habia leido hace un tiempo.
Subject: Re: AIRAID.COM Contact Form
Date: Fri, 09 Mar 2001 09:20:36 -0700
Dear Sir, thank you for your inquiry in our products. The spacer makes no HP on the Dyno. It makes all of it's power in torque in the low end. If you haven't noticed any power on the Dyno or the track then it's doing what it's supposed to. You would not see any gains down the 1/4 mile or increases on the Dyno. The idea of the spacer is to improve overall drivability and fuel mileage. In most cases when people install a bolt on part they expect better mileage and power, what happens is they are into the throttle a lot more than before trying to test performance and that's when the decrease in mileage happens.
Sincerely,
<Airaid Technician>
Points to look at:
"The spacer makes no HP on the Dyno. It makes all of it's power in torque in the low end."
"If you haven't noticed any power on the Dyno or the track then it's doing what it's supposed to."
"The idea of the spacer is to improve overall drivability and fuel mileage."
So...it doesn't make any more HP, is not supposed to help in 1/4 mile performance (or on the Dyno), and is mainly for mileage and bottom end Torque. Well, Dyno's show TQ figures and there were no changes, mileage stayed the same, and 1/4 mile performance wasn't affected on the several others who have tried it (including us). They also are still not able to explain how the spacer keeps the swirl effect through the two turns (90 degree and 45 degree) in the intake plenum of the Dodge Ram/Dakota/Durango manifolds.
Antiguo 04-07-2007, 15:16:21   #14
ANGELLO ROTTA
OK... MEJOR ME LO GASTO EN CHELAS.....
Antiguo 04-07-2007, 17:14:39   #15
Pancho Coddou
Empezado por ANGELLO ROTTA Ver Mensaje
jajajajajajajajajaja
mucho mejor al parecer
La franja horaria es GMT -3. Ahora son las 03:39:57.
