Venden - Partes y accesorios para 4X4 Espacio para avisos de venta (de caracter no comercial) de partes y accesorios para 4x4. Todo mensaje que no tenga que ver con el tema será eliminado sin previo aviso. |
Herramientas |
#11 |
EASYLIFT AIRJACK
1 Fabricated Lifting Bag High tenacity Polyester cloth coated both sides with plasticised PVC. Double skin to top and base. 2 Inlet Connector welded to bag Inner mechanical connection of glass reinforced polyamide, overmoulded in PVC. 3 Exhaust Connector Cone Rubber injection moulding 4 Bag Connector/Valve Glass reinforced polyamide moulding. 5 Hose - 6 metres (20 feet) UV resistant EPDM rubber extruded lay-flat tube. DIMENSIONS Model Diameter Height Volume Lift Capacity cm ins cm ins Litres cu.ft. Kilos lbs ELH04 86 34 70 28 407 14.36 4,000 8,800 http://www.air-jack.com |
Compartir en Redes Sociales |
