Antiguo 10-07-2010, 18:20:13   #11
claudioburgos
Avatar de claudioburgos
Predeterminado Re: AYUDA Problema caja ram 1500 2004
Ya me respondi solo, busque en internet y aparecia como hacerle el obd (on board diagnostic) es super facil , le tienes que dar contacto tres veces y dejar el contacto dado, y despues contar los parpadeos del check engine juntandolos de 2 en 2 por ejemplo a mi me me entrego los codigos 12 (un parpadeo, una pequeña pausa y depues dos parpadeos) el 37 y el 41 , termina con el 55 que significa que termino la revision y no hay mas codigos.
Seba hazlo es super facil ¡¡¡ mira aca abajo estan los codigos, el 12 y 41 no cache que eran jajajaj pero el 37 dice clarito que esta malo el solenoide de la caja. 37 Torque converter clutch solenoid CKT or park/neutral switch failure
bueno si alguien sabe lo que significa el codigo 12 y 41 se agradeceria la ayuda ¡¡¡
claudio burgos
ON-BOARD DIAGNOSTICS Dodge OBD1 Pre 96
1. Cycle the ignition key ON-OFF-ON-OFF-ON within 5 seconds. To cycle the ignition key ON means to turn it only as far as it takes to get the radio to come on. It does not mean to turn the engine on.
2. Count the number of times the "check engine" lamp on the instrument panel flashes on and off. The number of flashes represents the code. There is a slight pause between the flashes representing the first and second digits of the code. Longer pauses separate individual codes. For example, flash-flash-flash [pause] flash-flash represents the code 32.
A code of "55" represents end of error codes. If this is all you get then no error codes are stored in the computer. This is the normal condition
CODE Description of Trouble Code
11 Timing belt skipped 1 tooth or more from initial learned value, Intermittent loss of either camshaft or crankshaft position sensor, No crank reference signal detected during engine cranking
12 Direct battery input to PCM was disconnected within the last 50 key-on cycles (normal)
13 No change in MAP from start to run
14 MAP sensor voltage too low
15 No vehicle speed sensor signal
17 Closed loop temp not reached or engine cold too long
21 02s sensor problem (oxygen sensor), upstream or down stream
22 Engine coolant temp sensor out of range
23 Intake air temp sensor out of range
24 Throttle Position sensor out of range
25 Idle air control motor circuits, target idle not reached (+/- 200),vacuum leak found
27 Injector control circuit
31 Evap purge flow monitor failure or evap solenoid circuit
32 EGR system failure
33 A/C clutch relay circuit
34 Speed control Solenoid circuits
35 Rad Fan control relay circuit
41 Generator field not switching properly
42 Fuel pump relay control ckt, Auto shutdown relay control ckt, No ASD relay output voltage at PCM, Fuel level sending unit volts out of range, Fuel level unit No change over miles
43 Multiple/ single cylinder misfire
44 Battery temp sensor volts out of range
46 Charging system voltage too low
51 Fuel system lean
52 Fuel system rich
53 Internal control failure
54 No Cam signal at PCM
55 End of error messages (If you get this only, no errors were found)
62 PCM failure SRI mile not stored
63 PCM Failure EEPROM write denied
64 Catalytic Converter Efficiency Failure
65 Power steering switch failure
Antiguo 10-07-2010, 19:56:19   #12
_Sebastian_
Avatar de _Sebastian_
Uff Claudio te las mandaste, exelente info, la proxima semana voy a hacer el scanner espero que no sea nada grave, por lo visto lo tuyo no es nada muy grave, que bueno! ojala tenga la misma suerte, apenas tenga novedades te aviso. Muchas gracias denuevo por la informacion!
Saludos!
_Sebastian_ está offline   Responder Con Cita
Antiguo 11-07-2010, 22:09:12   #13
claudioburgos
Empezado por Seba199 Ver Mensaje
Saludos!
Seba ojala que te resulte , yo creo que los codigos son los mismo, por que la mia es 95, pero hace la prueba y buscamos los codigos para la 2004.
saludos compadre
Claudio Burgos
Antiguo 09-08-2010, 00:39:30   #14
_Sebastian_
Empezado por claudioburgos Ver Mensaje
saludos compadre
Claudio Burgos
Claudio alfinal corte por lo sano, fui a buscar la camioneta donde un maestro que le estaba haciendo una barra antivuelco y la lleve a talca a reparar la caja ya que ya estaba hace mucho tiempo parada, la camio en el trayecto se porto super bien creo que iba como en 3 me fui a 90 100 y no dio ningun drama solo que me dio 5km x litro pero para como iba revolucionada es mas que suficiente! me dio bastante confiansa el maestro, ayer sabado la deje cuando este lista te aviso como quedo y te paso el dato!
La franja horaria es GMT -3. Ahora son las 14:43:59.
