Antiguo 02-07-2007, 20:53:46   #211
The Black Bull
Avatar de The Black Bull
Predeterminado Re: Black Bull EX-treme
esa es la primera de la ZF s5-42 y S5-47 (no sé cual será la de daniel, la mia es la -47 y tiene esa reducción)
Andr3Z ..segun la tabla deberia dar 94.1 ...asi que espero el proximo fin de semana para las pruebas de rigor
y ver en terreno si las matematicas mienten o no .
Daniel Roa
Antiguo 02-07-2007, 21:29:22   #212
AndR3Z
pero teni los numeros de las transfers? y de la corona? pa calcular bien
Antiguo 02-07-2007, 22:26:49   #213
The Black Bull
Solo esto :
NP 203
Type:
Chain-driven, cast-iron
Low-range ratio: 2.00:1
Weight (lbs.): 165= 74 KILOS
Lubricant: 10W-30/10W-40
Length (in.): 21.5
Width (in.): 19.0
Height (in.): 15.0
Used by: Ford, Chevy, and Dodge in all 1971-80 full-size vehicles. Use depended on the year, model, engine, and transmission. It is suitable for V-8 power in trucks with GVWRs of up to 10,000 pounds.
The NP 203 is a "full-time" transfer case; it has a set of differential gears which allow for full-time operation; the differential action can be manually locked out. Kits are available to eliminate the action and convert the 'case to part-time. An NP 203 can be distinguished from a part-time NP 205 by its single-piece rear output housing and shift rail coming out the side of the case.
NP 205
Type:
Gear-driven, cast-iron
Low-range ratio: 1.98:1
Weight (lb.): 138 =62KILOS
Lubricant: 80- to 90-weight
Length (in.): 13.0 (GM); 16.0 (IH)
Width (in.): 18.0
Height (in.): 12.0
Used by: 1971-1980 Broncos, Blazers, and Ramchargers (and corresponding full-size pickups); the NP 205 is still used on heavy Dodges. Some Dodge and IH models were longer, "divorce-mounted'' versions. The NP 205 has left- or right-side front outputs and a center rear output. Caution is advised: there were many varieties in NP 205 shaft splines and so forth. A PTO plate can be found on the left side of the 'case.
Mas la ZF que es igual a la tuya y coronas 4.11 y neumas 39,5
Quizas me falto algo ..no se pero enviame un mail a daniel.roa@alcoa.com.br o a daniel.roa4x4@gmail.com
y te envio la tabla para el calculo ..es muy posible que tengas razón
Avisa despues que veas la tabla si sale algun resultado diferente ,
Daniel Roa
Antiguo 03-07-2007, 00:49:33   #214
AndR3Z
5.72 x 2.0 x 1.98 x 4.11 =93.09:1 de reducción
super bien!!!
piensa q estai moviendolo con un 5.8 Ford, un motor de verdad.. no un 350 de juguete como andan algunos (sin animo de ofender)
Antiguo 03-07-2007, 02:04:11   #215
OB1
Avatar de OB1
Edad: 67
super bien!!!
Se viene guerra santa... (qué queda para uno con un mísero 1300cc)
OB1
Antiguo 03-07-2007, 09:18:23   #216
Sr.sj410
Avatar de Sr.sj410
Empezado por OB1 Ver Mensaje
OB1
o para un humilde 5.0....(para 1300 kg )
Antiguo 03-07-2007, 13:05:50   #217
poroto ®
Contactar con poroto ® a través de ICQ Contactar con poroto ® a través de MSN
super bien!!!
350 de juguete?
mmmmm
perdonalo sr porque no tiene ni la mas minima idea de lo que dice!
poroto ® está offline   Responder Con Cita
Antiguo 03-07-2007, 13:07:54   #218
poroto ®
siguiendo con el post, el otro dia en en taller de victor vi tu camioneta y debo felicitarte por los coilovers...
no se si funcionaran bien, pero se ven la raja....
ojala pronto puedas probarla
poroto
Antiguo 03-07-2007, 13:18:18   #219
AndR3Z
Empezado por poroto ® Ver Mensaje
350 de juguete?
mmmmm
poroto.. tengo un 350 y anda harto menos q mi 302
Antiguo 03-07-2007, 13:36:36   #220
poroto ®
ese sera el tuyo.....
pero lo que YO conozco, no se puede llamar juguete
La franja horaria es GMT -3. Ahora son las 20:51:47.
