Antiguo 21-06-2005, 11:39:20   #21
pasamelas a mi correo .. tapage46@yahoo.com o datapage_6@yahoo.com para subirlas ..
Tomale tambien una pic al mismo diferencial delantero y trasero .. algo anda mal acá por que no puede ser 7.5 atrás ..
Antiguo 21-06-2005, 22:59:26   #22
cristianfelipe
hola, aca encontre una pagina que difiera con la anterior...
http://www.brian894x4.com/Gearratiosanddiffs.html
There doesn't seem to be any rhyme or reason for
part of the later model gear codes found in the
Tacomas, T-100s, 4Runners and Tundra.
I've seen both A and B listed on 4x4s. Toyota did
offer two types of rear diffs on these models. A
new style standard 8" diff with no locker.
Sometimes referred too as an 8.4" diff, but in
reality uses the same 8" gear as older trucks, but
entirely redesigned and stronger 2 pinion carrier.
Other models came equipped with a special
electric locking diff that used the same carrier
design as the older 4 pinion diffs.
I originally thought the A and B differentiated
between the two styles, but it apparently does not.
05 = 3.15
A = 2 Pinion, Open Diff?
B = 4 Pinion, Open Diff?
C = 2 Pinion, LSD ?
eso sale...es tb aplicable a la hilux??, igual encaja mas porque el ultimo digito es una letra...
pd:Tapage te mande las fotos a tapage46@yahoo.com :D
nos vemos
cristianfelipe está offline   Responder Con Cita
Antiguo 22-06-2005, 11:21:12   #23
Bro .. esas imágenes están mostruosamente grandes .. !!!!!
Antiguo 22-06-2005, 11:42:22   #24
cristianfelipe
oops!
No espera...
Esa no es mi placa, ni tampoco la foto que te envie, de hecho, es a placa de la hilux de un amigo...
Mi mail es el que te llegaron fotos de los diferenciales y la placa.(no te llegaron?)
Mi frame number es distinto... aunque bueno el axle code es el mismo asique para ese efecto da lo mismo.
nos vemos y gracias :D
Antiguo 22-06-2005, 11:52:39   #25
cristianfelipe
Antiguo 22-06-2005, 12:08:38   #26
Acá estan las fotos ya " reducidas " del diferencial trasero ..
No notan como que estan soldadas las mangas . .. ? raro ah.
Antiguo 22-06-2005, 12:12:49   #27
Para mi está claro que este diferencial delantero es un 7.5"
Como ganar recorrido y altura en una Hilux IFS??? Hilux Surf-Vigo General 4WD 3 20-09-2006 14:21:55
Salida VII Region ... 22 y 23 de Octubre .. Pelao Daza Paseos, Raids, Competencias y Eventos 4x4. 116 26-10-2005 16:41:51
Cual es la "relacion de dientes" de una Hilux... cristianfelipe General 4WD 3 17-06-2005 14:12:57
Compro bloqueo electrico para Hilux cristianfelipe Compran 0 14-06-2005 23:45:00
Como levantar una Hilux unas pulgadas?? LAPOSO General 4WD 4 31-12-1969 20:00:00
La franja horaria es GMT -3. Ahora son las 15:18:38.
