Antiguo 10-05-2006, 01:20:21   #21
Empezado por -ArtSerey-
....drive a Legend, drive a LandCruiser.-
Drive a Legend, drive a Hil....ups, perdon...asi no era!!!
Slds!
Antiguo 10-05-2006, 10:51:00   #22
-ArtSerey-
traktorke
Antiguo 10-05-2006, 11:27:39   #23
aschuck
Deberia tener un v8 --- el v6 me tinca medio chico pa o que debe pesar
Antiguo 11-05-2006, 03:18:24   #24
Pato Leguía
Avatar de Pato Leguía
Toyota FJ Cruiser Specificatiions
Engine 4.0-liter DOHC 24-valve SFI VVT-i V6
239 hp @ 5200 rpm
278 lb-ft @ 3700 rpm
Ignition Electronic, with Toyota Direct Ignition System(TDIS)
Transmission 5-speed electronically controlled automatic overdrive (ECT)
6-speed manual (full-time 4WD model)
Drivetrain Rear-wheel 2WD or part-time 4WD for automatic transmission models
full-time 4WD for manual transmission models
automatic limited-slip differential (2WD model)
Suspension High-mounted, double-wishbone front suspension and stabilizer bar
4-link rear suspension with lateral rod with coil springs and stabilizer bar
Steering Power-assisted variable-gear rack-and-pinion
Turning circle diameter -curb to curb (ft.) 41.8
Brakes Power-assisted 4-piston front/2-piston rear ventilated disc brakes with Anti-lock Brake System (ABS) with Electronic Brake-force Distribution (EBD) and Brake Assist [1]
Vehicle Stability Control (VSC) [2] Standard
Traction Control Standard
Active Traction Control Available (4WD model)
Dimensions
Overall height (2WD/4WD) 71.3/72.0
Overall width 74.6
Overall length 183.9
Wheelbase 105.9
Track (front/rear) 63.2/63.6
Head room (front/rear) 41.3/40.3
Shoulder room (front/rear) 58.4/53.9
Hip room (front/rear) 55.4/51.0
Leg room (front/rear) 41.9/31.3
Seating Capacity 5
Off-Highway
Skid plates On engine/front suspension, fuel tank and transfer case (transfer case on 4WD models only)
Angle of approach/departure (degrees) 2WD: 32/29
4WD: 34/30
Minimum running ground clearance (in.) 2WD: 8.7
4WD: 9.6
Rear axle ratio automatic [3] : 3.72:1
manual [3] : 3.91:1
Transfer case ratios - 2-speed (high/low) 1.000/2.566
Capacities
Curb weight (lb.) 2WD: 4050
4WD manual: 4290
4WD automatic: 4295
Gross Vehicle Weight Rating - GVWR (lbs.) 2WD: 5330
4WD: 5570
Cargo volume (cu. ft.) [4] (behind front/rear seats) 66.8/27.9
Towing capacity [5] (lb.) 5000
Fuel tank (gal.) 19.0
Tires
Size P265/70R17
Type Mud-and-snow-rated steel-belted radial blackwall
Spare Full-size
MPG
Mileage Estimates (mpg city/highway) [6] 2WD: 18/22
4WD manual: 16/19
4WD automatic: 17/21
Antiguo 11-05-2006, 15:08:57   #25
mas power que un 4.0 HO pesa menos de 5 mil lbs .. con unas 4.88 y unas 35" ..
No demoran los lift kits !
Antiguo 11-05-2006, 15:48:16   #26
BRONCO-80
Avatar de BRONCO-80
Contactar con BRONCO-80 a través de MSN
si el motor es el mismo que la 4runner yo creo q le basta..ese motocito tira bastante bien..lo que no me gusto es que interactua el control de traccion y no un bloqueo de diferencial...eso de que te frenen la ruedas no me gusta mucho...
BRONCO-80 está offline   Responder Con Cita
Antiguo 22-05-2006, 14:20:27   #27
Eduardo Silva
Avatar de Eduardo Silva
Las imágenes valen mas que 1000 palabras.
http://www.4wdtoyotaowner.com/FJCruiser.html
Antiguo 22-05-2006, 15:15:32   #28
Una de las cosas mas lindas que pueden ver mis ojos ..
Antiguo 22-05-2006, 15:30:38   #29
Muy lindas fotos!... en toyota.com salen todas las verciones y especificaciones. Seria cosa de encargar uno a Toyota Chile y ya...jajja...como si fuera tan fa$il!!! xD
Antiguo 24-05-2006, 11:44:24   #30
pato castro
Avatar de pato castro
Empezado por Tapage
Ya hay:
http://www.chaosfab.com/ucataco_05.html
8)
La franja horaria es GMT -3. Ahora son las 21:48:00.
