| Rally Cross Country / Baja Foro exclusivo para Rally Cross Country o carreras tipo Baja |
Herramientas |
#361 |
varios quedaron fuera
si terminan sin abandonar tienen buenas posibilidades de un buen lugar, quedan demaciadas etapas, la de mañana es una de las mas dificiles y mas larga dnd puedo ver la clasificacion por categorias??????????????? |
#362 |
Edad: 63
#363 |
Edad: 63
Esto lo llamo coraje del bueno, un corredor paraplejico:
Solo vale decirle: Vamos hombre que se puede!!! N° 392 - TEAM TOT CURSES ![]() ESTEVE PUJOLIsidreESP15/05/1972176 cm70 kg ![]() AUGE MEDINAEricESP29/03/1978176 cm70 kg Vehicle MODEL MAKE KYRON 2.7DCI SSANGYONG Isidre Esteve: «There are thousands of things that can be done from a wheelchair» On March 24, 2007, Isidre Esteve crashed massively on the Almeria Rally fracturing two vertebrae. Now a paraplegic, the, once, elegant and consistent rider will never win the Dakar in which he did finish fourth in 2001 and 2005. Loyal to his reputation, Isidre did all he could to play down his situation. «There are thousands of things that can be done from a wheelchair», he immediately says. Well supported and driven by the passion of his friends, Isidre soon put a three year project together to create a new team and continue his motor racing passion in a car. «It is a fine project. For the moment, there is just one car on which I have worked on the set up throughout 2008. The first events that we took part in with my co-driver, Eric Augé were encouraging. We finished 8th overall and 4th in the production class on the Montes de Cuenca.” While Isidre has only managed to put in 3,000 kilometres with his new machine, there is something more important for the Catalan. “The most important thing is that all the steering wheel modifications proved to be reliable. The unknown for me was to know how my body would hold up to the several hours in the driver seat.” Isidre Esteve will be present in Buenos Aires for the 31st Dakar with a modest ambition of finishing the rally. The first phase of what he hopes is a sporting renaissance. » List of entrants |
#364 |
quien sabe algo de peschiera y compañia???
en la hoja de llegada no figura |
#365 |
Ojo que hay una hora de diferencia con Argentina, el resumen es ahora, 19:00hrs.-
#366 |
empeso en fox sport!!
#367 |
por lo que veo en fox sport la etapa parese de rally mobil el tierral fue gigante creo que los chilenos estan para las etapas mas tecnicas
fue solo la primera mañana va estar mejor suerte a los chilenos... |
#368 |
mucho polvo,, lastima lo que paso con chaleco lopez.. aqui un link del mercurio
http://www.emol.com/deportes/especiales/dakar2009/detalle_noticia.asp?idnoticia=338081 |
#369 |
Americo, Latrach, Gabriel.....
Llamen a mi cel En Argentina 03546-15659390 En Chile 0054-9-3546-659390 Osvaldo |
#370 |
