Antiguo 14-06-2009, 23:14:25   #31
SVarasV
Jeepmaniac
Avatar de SVarasV
Predeterminado Re: Dodge Ram Owners
Oye y no hay posibilidad de estacionarla afuera nomas?
No, ni una posibilidad...lo único sería estacionarla en el Metro, donde tenemos 2 estacionamientos. Probé y ahí entra....pero me da lata tener que caminar todos los días un poco menos de 1 cuadra ...estoy muy viejito
Antiguo 14-06-2009, 23:20:39   #32
pato castro
Avatar de pato castro
Andate en el Wagoneer a la pega
Antiguo 14-06-2009, 23:34:57   #33
MLOZANO
Got Jeep?
Avatar de MLOZANO
Entonces ponle unos 325/60R15... se va a ver rica!!!
UTV Polaris Ranger RZR 2008
Antiguo 14-06-2009, 23:51:26   #34
SVarasV
Jeepmaniac
Avatar de SVarasV
Todo tiene solución....
Antiguo 15-06-2009, 13:05:07   #35
Zeta.
Avatar de Zeta.
Para mejorar un poco el rendimiento pueden probar este aceite 100% sintetico Valvoline, con aprobacion Cummins CES 20081. Este aceite lo esta comercializando Repuestos Express.
Premium Blue Extreme
Premium Blue Extreme provides fuel economy benefits for on-highway Class-8 trucks. Statistically significant test results find up to 3% maximum improvement in fuel economy using SAE J1321/TMC RMP 1103, Type II techniques*. Testing was conducted by a leading independent laboratory.
Valvoline Premium Blue Extreme is formulated with high-quality synthetic basestocks and a boosted additive system.
Valvoline Premium Blue® Extreme Engine Oil
Hi-Performance Synthetic Engine Oil. The Premium Blue Advantage:
Hi-Performance Synthetic Technology meets the most demanding requirements of modern EGR engines operating at elevated temperatures, higher soot and higher acid levels in the engine oil.
Cummins approved for 5,000-mile oil drain extension, under normal duty, for 2007 engines. Superior synthetic basestocks provide faster, safe starts during freezing weather and enhanced thermal properties for hot weather operations.
Unique formulation has demonstrated improved fuel economy over leading conventional oils.
Reduced high temperature carbon buildup - both single and two-piece pistons - and ring/liner wear protection leads to improved oil consumption control.
Antiguo 15-06-2009, 13:23:02   #36
inspiron
aqui unas imagenes que salen en la web.. y que estan buenas
Antiguo 16-06-2009, 00:25:15   #37
FELIPE TUN TUN
Avatar de FELIPE TUN TUN
Contactar con FELIPE TUN TUN a través de MSN
esa es la ram de mi madre esta con 35` y nada mas....saludos
FELIPE TUN TUN está offline   Responder Con Cita
Antiguo 16-06-2009, 00:42:39   #38
harv
hola a todos soy HARV y soy nuevo aca, note que hablan de las dodge Ram, tengo un amigo con un jugetito de esos una Ram 1500 y tiene el problema con el sensor de posicion del cigueñal, alguien de ustedes sabe donde encontrarlo + ó - cuanto sale, agradecidos.
Mi joyita es una Hi-lux 98 4x4, es genial, chaoooo
harv está offline   Responder Con Cita
Antiguo 16-06-2009, 03:26:16   #39
mariof
Empezado por harv Ver Mensaje
yo almenos he encontrado de todo para mi ram 2500 y la 1500 q tenia antes en repuestosxpress
http://www.repuestosexpress.cl/
mariof está offline   Responder Con Cita
Antiguo 16-06-2009, 17:18:09   #40
harv
Empezado por mariof Ver Mensaje
Ok, gracias por el dato
La franja horaria es GMT -3. Ahora son las 15:21:57.
