Antiguo 08-02-2006, 13:07:12   #1
piraña
Avatar de piraña
Predeterminado handy yaesu tribanda vx-5
vendo handy yaesu modelo vx-5 tribanda valor 150m mil pesos. acepto ofertas.
The Yaesu VX-5R is a triple band (6M, 2M & 440 MHz) HT with extensive receive coverage, and leading-edge features. It receives the AM and FM broadcast bands, shortwave (AM) to 16 MHz, VHF and UHF TV audio, VHF Air and public service frequencies. The specific ranges covered are: 0.5-16, 47-729 and 800-999 (less cellular). The die-cast aluminum housing, augmented by an extensive gasketing system sets a new standard for water resistance among amateur HTs. This robust construction has earned it a MIL-STD 810 rating.
The supplied FNB-58LI 7.2 V 1100 mAh Lithium-ion battery provides 5 watts out on 6M and 2M and 4.5 watts on 440 MHz. Features include: 16 digit 9 memory DTMF autodialer, CTCSS/DCS, 220 memories, aluminum die-cast case and 8 character alphanumeric display.
At only 2.3 x 3.4 x 1.1 inches (58x87x28 mm) it will go with you everywhere. Hikers and mountain climbers may connect the optional SU-1 Barometric Sensor for direct air pressure readings. The VX5R comes with SMA Antenna, FNB-58LI Lithium Ion Battery, NC-72B Battery Charger, Belt Clip and Wrist Strap. The VX5R is black, but there is also a silver version. Click here for specifications.
Features
* 220 Alpha Memories
* AM/FM BCB
* SW to 16 MHz
* CTCSS/DCS
* European Tone Burst
* Wideband Receive
* Dual Watch
* ARTS-Automatic In-Range Transponder
* Backlit Keypad & LCD
Antiguo 11-02-2006, 16:12:01   #2
piraña
Avatar de piraña
algun interesado? este equipo es muy bueno, puedes escuchar y transmitir en los canales gprs, puedes escuchar estaciones de rasio fm y am como de banda corta, es resistente al hundimiento en agua, se conecta con un gps, con un pc, sirve ademas de repetidora, es muy muy completo, lo mejopr para jeepear es que es de carcaza de aluminio, acepto ofertas y cambalaches.
Antiguo 11-02-2006, 18:15:29   #3
samuraco
Avatar de samuraco
Contactar con samuraco a través de MSN
Predeterminado permuta
te interesa permutarlo por un base kenwood tm-241 vhf ??
samuraco está offline   Responder Con Cita
Antiguo 11-02-2006, 20:52:12   #4
piraña
Avatar de piraña
ok, mandame fotos ha renefernandez@tie.cl para ver en que condiciones esta, teniendo tu mail t mando fotos de mi equipo.
Antiguo 12-02-2006, 14:34:41   #5
samuraco
Avatar de samuraco
este es mi cel/ 90012483 llamame y nos podemos juntar soy de conce .....
Antiguo 23-06-2006, 21:31:13   #6
piraña
Avatar de piraña
volvio a la venta, acepto permutas
Antiguo 06-07-2006, 23:59:15   #7
mayck_charly
Avatar de mayck_charly
Contactar con mayck_charly a través de MSN Contactar a mayck_charly a través de Yahoo
Empezado por piraña
yy sigue a la venta te la permuto por una tk762g mas antena asp7450 nueva con montaje perforado saludos.
mayck_charly está offline   Responder Con Cita
Antiguo 07-07-2006, 00:21:21   #8
piraña
Avatar de piraña
eltk es de la linea comercial, si no me eqivoco son canalizados, la verdad es que lo cambiaria por un base pero no por uno canalizado, no me sirven, gracias
Antiguo 07-07-2006, 14:04:01   #9
Claudio Troc
Predeterminado Hola, permutarías tu equipo por un ICOM IC2200
Hola, permutarías tu equipo por un ICOM IC2200, esta impecable.
Claudio Troc
ruta4x4@gmail.com
Claudio Troc está offline   Responder Con Cita
Antiguo 07-07-2006, 14:24:49   #10
the.cheix
lo compadre tengo un primo que anda en busca de este hady su telefono es 09-8625490 ( manuel).
Handy narnia316 Novatos 14 09-01-2007 02:24:13
Permuto Radio VHF marca YAESU modelo VERTEX VX-150 SAYAGO Compran 4 21-09-2005 20:49:36
[b]HANDY YAESU mod. FT-411L[/b] mogote Venden - Partes y accesorios para 4X4 2 23-06-2005 19:12:28
Handy TH-235A, al agua Zeta. General 12 24-11-2004 14:32:58
Radio VHF (comprada, necesito datos donde instlarla!!!) Pato Leguía General 16 10-11-2004 12:51:19
La franja horaria es GMT -3. Ahora son las 02:26:47.
