Antiguo 16-06-2009, 22:58:38   #1
Bombero 4x4
Avatar de Bombero 4x4
Predeterminado ECU Programable SPECTRE PERFORMANCE
Vendo ECU Programable SPECTRE PERFORMANCE EMS-PRO, es lo mas filete en programables, es base Megasquirt, pero mejorado, llegar e instalar.
Nueva sin uso, y esta con su RAMAL.
$ 850.000.-
NUEVO PRECIO $500.000.-
Atte.
Sebastián.
90992631
Descripcion:
The Spectre eMS-pro™ is a small computer, designed to control a wide variety of engines that use Electronic Fuel Injection. This unit is very similar to the computers that are found in all late model Fuel Injected vehicles however, unlike a GM or Ford computer, Spectre eMS-pro™ users are able to "customize" parameters on the computer to make it support greater horsepower, a wider variety of engine designs (4-cylinder - V-12, etc.), and a broad array of poweradders like nitrous, turbochargers, and superchargers. Spectre eMS-pro™ features include, launch controls, boost support for turbocharger or superchargers to 40psi, two-stage nitrous oxide controls, on-the-fly VE, spark tuning (distributor, coilpacks) plus staged injection capabilities for dual fuel/octane. Along with these features, you can communicate your programmable demands through a simple USB connection to your vehicle, then once your tune is set, share "tunes" with other Spectre EMS-Pro™ or Megasquirt™ users online, free.
Required Inputs
12 volt Switched ignition · Chassis or battery ground · Engine Position, one of the following: o Points o Distributor Sensor (any magnetic, hall, or optical input) o Crankshaft Trigger (hall/opto or magnetic; multiple tooth patterns supported) · Coolant Temperature o Affordable GM Temp Sensors by default; other thermistor-based sensors can be calibrated in software · Intake Air Temperature o Affordable GM Temp Sensors by default; other thermistor-based sensors can be calibrated in software · Manifold Pressure o 4-bar (40+ psi) map sensor included inside the · Spectre eMS-pro™ unit · Throttle Position o Any OEM 0-5v sensor can be calibrated to the Spectre eMS-pro™
Optional Inputs
Included with unit but not required to run most engine combinations: · Oxygen Sensor (any OEM Narrowband, or 0-5v Wideband such as Innovate LC-1) · Cam Position Sensor o Used in conjunction with Crank Position Sensors for TDC identification o Can be magnetic, hall, or optical · Nitrous Enable (if using Spectre EMS-Pro™ as a nitrous system trigger) · Knock Sensor Input o Tunable Knock Circuit designed to work with OEM knock sensors · 2-Step in o Launch rev limiter or boost builder input trigger (retards timing to configured settings when switched on) · External MAP sensor · Realtime Barometric Correction using second onboard MAP sensor
Outputs
Fuel Injector(s) o High or Low Impedance supported o Dual Bank, up to 8 injectors per bank. Can be configured as batch fire, or alternating banks. o Secondary bank can be used for secondary VE tables, or staged injection (dual fuel, etc.) · Fuel Pump Relay o Triggers ground side of typical fuel pump relays, includes safety shutoff when RPMs = 0. · Ignition Outputs: o Up to 4 spark outputs; can be used with factory coils, distributors, or wasted spark coilpacks o 0v Points triggering OR 5v TTL triggers · Fast Idle o Can support simple Fast Idle Valve for warm-up, or PWM-style (2-wire) IAC valves · 5 volt output o Supports TPS and other sensors that require 5 volt supply · Boost Control o Supports GM-style boost control solenoids · Tachometer Output o 12v square wave tach output, supports typical aftermarket tachometers · Cooling Fan Relay Control o Software configurable temps to enable and disable standard automotive Fan Control Relay (triggers ground side of relay) · Shift Light o Grounds LED-based shift light, or relay for other incandescent shift lights · LED Indicators o Indicate proper function of inputs and outputs on the Spectre eMS-pro™
Última edición por Bombero 4x4 fecha: 24-01-2010 a las 01:34:14
Antiguo 23-06-2009, 23:22:35   #2
Bombero 4x4
Predeterminado Re: ECU Programable SPECTRE PERFORMANCE
Se aceptan ofertas !!!!
Antiguo 02-07-2009, 00:51:38   #3
Bombero 4x4
Es lo mas filete en programables, se aceptan ofertas.
Antiguo 15-09-2009, 18:02:24   #4
Bombero 4x4
Oferta solo por esta semana.
$ 650.000.-
Atte.
Sebastián.
90992631
Última edición por Bombero 4x4 fecha: 24-01-2010 a las 01:33:32
Antiguo 24-01-2010, 01:35:15   #5
Bombero 4x4
Facilidades para conocidos.
La franja horaria es GMT -3. Ahora son las 01:34:03.
