Antiguo 13-11-2010, 08:17:56   #1
inspiron
Predeterminado reportaje de LUN.cl sobre buggies
http://www.lun.com/Pages/NewsDetail....=0&PaginaId=14
Antiguo 13-11-2010, 10:32:43   #2
Pato Leguía
Avatar de Pato Leguía
Predeterminado Re: reportaje de LUN.cl sobre buggies
Corra su propio rally por 380 mil pesos al día....
Antiguo 13-11-2010, 11:41:28   #3
SVarasV
Jeepmaniac
Avatar de SVarasV
Harto caro...por 100 lucas yo arrendaría por un día en Copiapó.
Antiguo 13-11-2010, 19:37:14   #4
Buena iniciativa, capaz que sean chinos jajaja..
Antiguo 13-11-2010, 22:05:51   #5
V A M P I R O
Un par de fotos:
170hps y 900 kilos
Antiguo 13-11-2010, 22:10:17   #6
Pato Leguía
Vampi, hay como conseguir más specs? origen? valor?
Antiguo 13-11-2010, 22:19:45   #7
V A M P I R O
Voy a ver como me va, habria que partir preguntandole al Nacho Casale creo yo
Saludos!
Antiguo 13-11-2010, 22:28:25   #8
V A M P I R O
Saludos!
Ya, el bala vampiro cree haberlo pillado:
SpecificationsProfessional sandrail, dune buggy manufacturer,
4130 chassis, BAJA1000 approved
2200cc GM Ecotec Engine,
Automatic CVT,
CARB and EPA Approved Green Sticker / MSO Street Legal in Some States, See Your Local DMV
Engine Performance:
•GM / Chevrolet Ecotec, Built by CBM Motorsports, Forged Pistons, 90-Day Warranty
•170HP 2.2 Liter Engine @ 155 Ft. Lbs. of Torque
•Exhaust: Stainless Steel Twin Tip Muffler with Stainless Steel Header Manifold, Certified Catalytic Converter
•Stainless Steel Intake Manifold
•Cooling: Large Capacity Radiator, Triple 9 Fans (Independently Relayed and Fused)
•Air Filter: K&N Washable Pleated Mesh
•MSD Ignition: Mefi 4 Computer & Wiring Harness
•Power Steering Assist
•Alternator 120 Amp
Transmission:
•Automatic CVT
•8 to 1 (2WD) .091 Differential, F-N-R Transmission
•Axles: Chromoly with 930 CV Joints
•Automatic Clutch: Team Industries Driven Clutch and Comet Drive Clutch, Kevlar Belt
•Shifter: Billet Machined Aluminum F-N-R
Chassis Construction:
•Chassis Construction: 1-1/2 Chromoly .083 to .130 depending on Location, Mig Welded
•Suspension Rear: Chromoly, 4130 Swing Arms
•Suspension Front: Chromoly Double A-Arm, Tig and Mig Welded
•Spindles Front: Chromoly, Mig/Tig Welded
•Full Skid Plate
•Frame: Powder Coated
•Gel Coated Fiberglass Body, 3 Standard Colors: Red, Black, White. Special Order Colors: Yellow, Green, Blue and Orange
Performance and Fuel Capacity:
•Keyed High Speed Ignition Approx. 70 MPH
•Keyed Low Speed Ignition Approx. 35 MPH
•Fuel Capacity: 16.0 Gallons
Brakes, Suspension, Tires & Wheels:
•Travel and Suspension: 20 Front and 18 Rear
•Chromoly Heims 7/8 and 3/4
•Shocks Front: Vogtland Off-Road 10 x 2.0 x 7/8, Piggy Back Reservoir, Nitrogen Filled
•Shocks Rear: Vogtland Off-Road 13 x 2.0 x 7/8, Piggy Back Reservoir, Nitrogen Filled
•Front Hubs: Billet Machined Aluminum
•Rear Hubs: S10 Chromoly Micro Stub and Bearing
•Brakes: Front and Rear Independent: 4 Calipers, 2 - 4 Piston with 9Drilled Rotors Front, 2- 4 piston with 11-1/2 Drilled Rotors Rear
•Dual Brake Reservoir with F-to-R Adjustable Bias
•Emergency Brake
•All Terrain Tires Front and Rear
•5 Bolt Spun Wheels with Beadlock
Safety:
•Full Suspension Seats, Fully Adjustable, Heated, Low and High settings
•Simpson 5-Point Safety Harnesses
•Simpson Window Nets
•Simpson Limit Straps
Electrical & Instrumentation:
•Battery: AGM 12-Volt DC, 350 Cranking Amps
•12-Volt Disconnect: Master On/Off Switch Located Under Dash
•Gauges: Tachometer, Oil Pressure, and Water Temperature
•Control Panel: Control Panel with LED Indicator Lights for On/Off Switches
•Circuit Breakers: No Need To Replace Blown Fuses, just Reset Circuit Breakers.
•Lighting: (2) Running Lights; (1) Buggy Whip Mount, Aux (Pre-Wired forFour Roof Spot Lights (2) - 30 Amp Relays), Interior LED Light
•Horn: Twin 12-Volt Air Horns
•Starter: Hi-Torque GM 12-Volt Electric Starter
Optional & Customized Features Available:
•Spare Tire Rack (Removable)
•1.5 Ton Aluminum Jack (Removable)
•(4) 6 HID Lights Light Rack / Roof Mounted Storage Rack
•(2) 6 Round HID Front Driving Lights
•Custom Paint can be Made As Per Your Request
Click Aqui
Antiguo 13-11-2010, 22:30:58   #9
Pato Leguía
cuanto saldrá???? te faltó el precio!! jejejeje
Antiguo 13-11-2010, 22:36:14   #10
V A M P I R O
Ya va jefe
La franja horaria es GMT -3. Ahora son las 07:25:41.
