Antiguo 08-10-2012, 20:00:51   #1
NOVITRACK
Predeterminado Motor ford 360 y cajas
Motor ford 360 con caja de camion automatica y tranfer de nissan patrol , el motor tiene 6.000.- kilometros fue sacado a un camion ford de lan chile solo usado interno del aÑo 78
NOVITRACK está offline   Responder Con Cita
Antiguo 09-10-2012, 00:06:14   #2
Pelao 69
Predeterminado Re: Motor ford 360 y cajas
falto precio y puede que sea un ford 460
Pelao 69 está offline   Responder Con Cita
Antiguo 09-10-2012, 17:39:24   #3
NOVITRACK
No es un 360 big block carburado 500 completo con cajas
Antiguo 10-10-2012, 12:15:21   #4
alvaro palacios
Contactar con alvaro palacios a través de MSN
fotos
alvaro palacios está offline   Responder Con Cita
Antiguo 10-10-2012, 13:46:52   #5
NOVITRACK
Empezado por alvaro palacios Ver Mensaje
fotos
mandame un mail a noviciado10@gmail.com y te mando fotos de lo que quieras
Antiguo 10-10-2012, 19:43:00   #6
mauricio fuentes h
cuanto vale y algun telefono
mauricio fuentes h está offline   Responder Con Cita
Antiguo 12-10-2012, 12:57:18   #7
Camellin
Una ayudadita jaja fono : 90014217 antonio
saludos juaco
Antiguo 12-10-2012, 13:26:53   #8
Kruger
Avatar de Kruger
360 Truck
360 Truck engine configurations and applications [show]
The 360, of 360.7 cu in (5.9 L) actual displacement, was introduced in 1968 and phased out at the end of the 1976 year run; it was used in the Ford F Series trucks and pickups. It has a bore of a 390 (4.05 inches (102.87 mm)) and used the 352's 3.5 inches (88.90 mm) rotating assembly. 360s were also constructed with heavy duty internal components for truck use. Use of a standard 352/390 cam for use in passenger cars along with carburetor and distributor adjustment allowed the 360 to give performance similar to that of the 352 and 390 car engines. Rated at 215 bhp (160.3 kW) at 4200 rpm and 375 lb·ft (508 N·m) of torque @3600 rpm (2-barrel carb, 1968). The 360 used the same block, heads and other parts as a 390, this makes them indistinguishable from each other unless the stroke is measured.
Antiguo 19-10-2012, 10:22:37   #9
NOVITRACK
Up-up-up-up
Antiguo 26-01-2013, 22:21:48   #10
watara
Avatar de watara
Empezado por NOVITRACK Ver Mensaje
Las cajas no la vendes a parte. yo tengo un 351 w con stroker me imagino que debería hacerle esta montado en un cj7
watara está offline   Responder Con Cita
La franja horaria es GMT -3. Ahora son las 16:29:05.
