Antiguo 23-03-2005, 23:18:48   #11
Jorge Heuser
Empezado por CHINO GONZALEZ
Para los que no sabian:
Jeep/Dodge AX15 5-speed, the Jeep NV3550 5-speed, the Toyota R150F & R151F, the 87-92 Toyota Supra Turbo R154 and the Isuzu AR5 5-speed all share the same case to bellhousing bolt pattern. As such there are a number of possibilities that can be had when a 5-speed is desired:
94-95 Dakota 2.5L bellhousing: Connects all to any K car based 2.2L-2.5L OHC L4 in a RWD application.
94-99 Dakota 3.9L V6 Bellhousing: Connects all to any 3.9L V6 and any 273/318/340/360 V8.
96-99 Dakota 2.5L bellhousing: Connects all to any Jeep 2.5L L4. Because of it's GM inherited bolt pattern, also works with any Buick FWD V6 and supercharged V6, any Chevrolet 2.8/3.1/3.4 V6, any Cadillac 4.1/4.5/4.9 V8 and with a minor modification, any Olds Aurora DOHC V8 and Cadillac DOHC Northstar V8.
88-99 Jeep 4.0L L6 bellhousing: Connects all to any AMC 290/304/343/360/390/401 V8 and any 72 and later 232 L6 and 258 L6.
01-03 Jeep Liberty 3.7L V6 bellhousing: Connects all to any 3.7L V6, 4.7L V8 and 5.7L Hemi V8.
Isuzu Trooper 3.5 V6 AR5 bellhousing: Connects all to any Isuzu 3.2\3.5 V6
Aftermarket:
Advance Adapters: Bellhousing for AX15 to Chevrolet-Buick-Olds-Pontiac V8 and Buick V6. Connects all to same.
Advance Adapters: Adapter plate for AX15 to Ford bellhousing. Connects all to same. Also they have a plate for the NV3550 to do the same.
Novak Enterprises: Adapter plate for AX15 to GM 4-speed bellhousing. Connects all to same.
Further info: Jeep AX5, Toyota G52, W55, W56, W57 and W58 5-speeds all share a common face pattern on the case. As such, any 88-99 Jeep 2.5L bellhousing (NOT Dakota) will bolt a Toyota W series transmission to a 60 degree GM bolt pattern.
Aftermarket: Advance Adapters makes a bellhousing to bolt a W series Toyota trans to a Chevy-Buick-Olds-Pontiac block.
NOTE: Input shafts lengths vary.
Pre 1995 R150\R151 = 6.5"
1995 up Toyota R series = 7.5"
AX15 = 7.5"
87-92 Turbo Supra R154 = 7.25"
AR5 = ?
NV3550 = 7.5"
AX5 = 7.5"
Toyota W series = 6.5"
Advance Adapters makes an extra long pilot bearing if using a shorter input shaft tranny with a bellhousing that had a longer one. Obviously you can't put the longer input trans into a bell that had a shorter one.
Front bearing covers are interchangeable between the R series, AX15 and AR5. NV3550, AX5 and W series are not interchangeable.
Re buena esta info,de donde la sacaste :?:
Antiguo 24-03-2005, 02:48:02   #12
Reparando hace un tiempo una Dakota 2.5 me di cuenta que la caja era Japonesa y muy parecida a las Toyota pero no segui investigando, ahora veo que no andaba tan perdido :wink:
Antiguo 24-03-2005, 11:58:30   #13
Según leo y comprendo, Si tengo un R osea un 22RE > 95 ( no existe ) de eje piloto de 7.5 puedo ponerle una AX-15, por tanto podria ponerle un 4.0 HO a esa Hi Lux con la R151.
El problema de esta info es la fecha que no me cuadra mucho ..
Antiguo 24-03-2005, 16:13:13   #14
A T X
Avatar de A T X
Buenisima, informacion de 1º linea muy aplicacble a adaptaciones.
parece provenir de AA
buen aporte :wink:
Empezado por Tapage
aca en chile si existen. 22RE => 95' al 97/98, por ahi en esos años ya cambio a 2RZ
ATX-4X4. . . . . . . . Mandy
Antiguo 24-03-2005, 18:31:15   #15
CHINO GONZALEZ
Avatar de CHINO GONZALEZ
Empezado por Jorge Heuser
Aftermarket:
AX15 = 7.5"
AR5 = ?
NV3550 = 7.5"
AX5 = 7.5"
Bueno en interney hoy en dia se encuentra casi de todo, sobretodo en los foros gringos de 4x4, los cuales por decirlo nos menos nos llevan años de ventaja en lo que a contenidos y profundidad se refiere.
Yo hace tiempo que sabie esta informacion, y no tiene nada que ver con advance adapters.
Para aclarar un poco.
toyota r151f y r150f son las cajas del modelo 22re turvo y v6 respectivamene.
toyota G52, W55, W56, W57 and W58 5-speeds son las cajas de las 4 cilindros en sus respectivos años.
la similitud entra la apernadura de las cajas de jeep y toyota:
jeep ax5 -> toyota G52, W55, W56, W57 W58 (light duty)
jeep ax-15-> toyota r151f y r150f (medium duty)
tiene que ver basicamente al hecho de que todas son hechas por la misma empresa (Aisin-Seiki) .
CHINO GONZALEZ está offline   Responder Con Cita
Antiguo 24-03-2005, 20:29:16   #16
jorge avaria
que vehiculos traen los r151f y r150f ??? llegaran a iquique ??
Antiguo 24-03-2005, 21:23:33   #17
CHINO GONZALEZ
Empezado por jorge avaria
la tacoma v6 y la runner v6 almenos traen la r150f
Antiguo 28-03-2005, 14:05:21   #18
Empezado por ATX-4X4
Empezado por Tapage
Jumm es que acá en Panamá no .. el 22R hasta el 94.
Any case, es posible ponerle un 4.0 HO a una HI Lux con caja H150 o H1541 .. ?
Varios Hilux Rematando Toyotero Calama Venden - Partes y accesorios para 4X4 29 14-05-2014 15:30:03
Repuestos Originales Toyota ( Tlc Y Hilux ) Con Precios Nuevos. chevota Venden - Partes y accesorios para 4X4 0 17-10-2006 23:35:54
Campana caja de cambios Toyota Hilux 4x4 FOURWHEELROD Venden - Partes y accesorios para 4X4 0 17-10-2006 13:15:39
Cabezas de chancho Hilux y otros Toyotero Calama Venden - Partes y accesorios para 4X4 3 18-01-2006 15:30:51
La franja horaria es GMT -3. Ahora son las 04:59:25.
