Antiguo 08-08-2007, 13:15:35   #11
AndR3Z
Predeterminado Re: Motor toyota 2L TE permuto.
2L-TE
Developed as a new version of 2L-T, the 2L-TE features a new development used in Diesel engines at that time, the EFI(Electronic Fuel Injection) system. Although Toyota used this fuel injection system in gasoline engines years before, this is among the first Diesel engines to adopt such a system. Although the basic construction is similar to a modern gasoline injector, the EFI system in 2L-TE utilize considerably higher injection pressures. The EFI system meter fuel with great precision and succeeded in increasing the engine's efficiency. Like the 2L-T , it is 2.4L (2446cc) and it is a SOHC (Single Overhead Cam) engine, having 8 valves. It also comes with a Turbo charger. The bore is 92 mm and stroke is also 92 mm. Due to the EFI system, the 2L-TE is stronger than 2L-T, having maximum output of 97HP (72.3kW) at 3800 RPM and maximum torque is 24.54kg.m (240.3 N・m) at 2400 RPM. Redline of this engine is at 4800 RPM. Compression ratio is 21.0 : 1, slightly higher than 2L-T. 2L-TE was replaced by the KZ engine in the year 1993.
This engine was used in Toyota Hi-Lux and in Toyota Land Cruiser Prado
Antiguo 08-08-2007, 14:05:19   #12
LoiD
al final ¿cuanto vale el motor con ramal y ecu???? (sin caja)
LoiD está offline   Responder Con Cita
Antiguo 08-08-2007, 20:39:59   #13
Pez Gordo
Avatar de Pez Gordo
me interesa el motor, tienes PM
Antiguo 09-08-2007, 17:14:31   #14
DESERTICO
Avatar de DESERTICO
El valor aproximado del motor con caja, ecu y transfer es de 500 lucas más los impuestos...la idea es hacer un trueque cercano a ese valor.
Antiguo 09-08-2007, 22:12:47   #15
Cristian Macaya
te interesa cambiarlo por el motor 2.7 V6 del un honda legend. con caja automatica, ramal, ecu y mandos de la caja?? es año 93 si no me equivoco, se saco de un legend en desarme, lo queria para un proyecto de buggy pero al final cambie de idea. el motor es transversal.
Cristian Macaya está offline   Responder Con Cita
Antiguo 10-08-2007, 00:25:22   #16
Julio Irigoyen Neol
Avatar de Julio Irigoyen Neol
Edad: 61
Empezado por DESERTICO Ver Mensaje
Hola Jaime, mas impuestos cuanto es, iva 19% y que mas? internación, aduana, etc? o solo iva.
Julioqtro
Antiguo 10-08-2007, 00:31:06   #17
DESERTICO
Avatar de DESERTICO
Ttengo que ver lo del impuesto...al parecer es cercano al 30% del avalúo de motor. Voy a ir a Aduanas a ver ese tema mañana.
Antiguo 10-08-2007, 00:32:33   #18
DESERTICO
Avatar de DESERTICO
Empezado por Cristian Macaya Ver Mensaje
No, muchas gracias. Necesito cambiarlo por algo que me sirva en el proyecto del TLC HZJ75.
Antiguo 11-08-2007, 01:24:58   #19
DESERTICO
Avatar de DESERTICO
En la semana voy a ver el asunto de aduanas y lo voy a dejar montado en un Pallet....listo pàra mandárselo al que me de la mejor oferta.
Antiguo 13-08-2007, 16:06:12   #20
Pez Gordo
Avatar de Pez Gordo
te mande PM hace dias , espero respuesta.
La franja horaria es GMT -3. Ahora son las 00:43:52.
