Antiguo 29-07-2009, 12:55:41   #71
PiluPelao
Edad: 63
Predeterminado Re: Personalized
Amigos:
Aqui los productos que tengo en Stock:
22042" MOUNTING CUP, BLACK, PLASTIC GAUGE22372" 2-HOLE GAUGE PANEL, BLACK, ALUMINUM22382" 3-HOLE GAUGE PANEL, BLACK, ALUMINUM23003-3/4" TACH, 8,000 RPM, BLACK23023-3/4" TACH, 8,000 RPM, SHIFT-LITE, BLACK2343TIRE PRESSURE GAUGE, 60 PSI W/PEAK HOLD3207BLUE LIGHT BULB BOOTS (3/PKG)3211REPLACEMENT BULB & SKT FOR 2-5/8" & 2" MECH3214RED LIGHT BULB BOOTS (3/PKG)3215GREEN LIGHT BULB BOOTS (3/PKG)3218LONG-LIFE INTERNAL REPLACEMENT BULBS32246' COPPER TUBING, 1/8" DIA.3303-M2" BOOST-VAC, 60 Cm HG- 2.0 BARS, MECH3304-J2" BOOST-VAC, 2.5 Kg/Cm2 MECH3311-J2" FUEL PRESS, 0-1.0 Kg/ Cm23327-M2" OIL PRESS, 0-7 BARS, SSE, SPORT-COMP3332-M2" WATER TEMP, 50-115`C, MECH3337-M2" WATER TEMP, 40-120`C, SSE, SPORT-COMP3341-M2" OIL TEMP, 60-140`C, MECH3348-M2" OIL TEMP, 60-170`C, SSE, SPORT-COMP33912" VOLTMETER, 8-18 VOLTS SSE, SPORT-COMP4303-M2" BOOST-VAC, 60 Cm HG- 2.0 BARS, MECH43272" OIL PRESS, 0-100 PSI, SSE, ULTRA-LITE4327-M2" OIL PRESS, 0-7 BARS, SSE, ULTRA-LITE4337-M2" WATER TEMP, 40-120`C, SSE, ULTRA-LITE4348-M2" OIL TEMP, 60-170`C, SSE, ULTRA-LITE43532" OIL PRESS, 0-100 PSI, FSE43562-1/16" OIL TEMP, 100- 340`F, FSE43572" TRANS TEMP, 100-250`F SSE, ULTRA-LITE43632" FUEL PRESS, 0-100 PSI FSE, W/O PEAK & VALLEY43762" BOOST-VAC, 30 IN. HG/ 15 PSI, FSE, ULTRA-LITE43912" VOLTMETER, 8-18 VOLTS SSE, ULTRA-LITE5703-M2" BOOST-VAC, 60 Cm HG- 2.0 BARS, MECH, PHANTOM5727-M2" OIL PRESS, 0-7 BARS, SSE, PHANTOM5737-M2" WATER TEMP, 40-120`C, SSE, PHANTOM57912" VOLTMETER, 8-18 VOLTS SSE, PHANTOM5903-M2-1/16" BOOST-VAC, 60 CM/HG-2.0 BARS, MECH, ES5927-M2-1/16" OIL PRESS, 0-7 BARS, SSE, ES5937-M2-1/16" WATER TEMP, 40- 120`C, SSE, ES5948-M2-1/16" OIL TEMP, 60- 170`C, SSE, ES59903-3/4" TACH, 10,000 RPM, SHIFT-LITE, ES6103-M2-1/16" BOOST-VAC, 60 CM/HG-2.0 BARS, MECH6127-M2-1/16" OIL PRESS, 0-7 BARS, SSE, COBALT6137-M2-1/16" WATER TEMP, 40- 120`C, SSE, COBALT6148-M2-1/16" OIL TEMP, 60- 170`C, SSE, COBALT62903-3/4" TACH, 10,000 RPM, SHIFT-LITE, COBALT2339045" TACH, 10,000 RPM, SHIFT-LITE, AUTO GAGE2339055" TACH, 8,000 RPM, SHIFT-LITE, AUTO GAGE2339115" TACH, 10,000 RPM, SHIFT-LITE, AUTO GAGE
12083GRAmort. Del. Nitro-Gas VITARA12715GRAmort. del. Nitro-Gas L200 '06-12716GRAmort. del. Nitro-Gas D4012717GRAmort. tras. Nitro-Gas D403522Amortiguador dirección NISSAN3524Amortiguador dirección TOYOTA3530Amortiguador dirección SUZUKI3540Amortiguador dirección CJ7/YJ/TJ/XMITS040BMuelle del. IRONMAN L200 '06- (B)MITS040CMuelle del. IRONMAN L200 '06- (C)MITS041BBallesta IRONMAN L200 '06- (B)MITS041CBallesta IRONMAN L200 '06- (C)NISS041CBallesta IRONMAN NAVARA D40 (C)795Gemela engr. IRONMAN l200 '06-1102UBKU-Bolt715TUKKit casq. ballestas IRONMAN L200762UKKit casq. ballestas IRONMAN XJ769UKKit casq. ballestas IRONMAN D40W12000Cabrestante Monster 12000 12vW9500Cabrestante Monster 9500 12vIHOOKBOWGancho c/grillete IRONMANIRECOVERYKit rescate IRONMANISNATCHEslinga IRONMAN 8tn x 9m (c/bolsa)IHID001Luz Xenon 9" IRONMAN (unidad)IVEGA220Vega 220 / 100W Halogen Light (pair)IGAMMA175Gamma 175 / 100W Halogen Kit (pair)
Antiguo 29-07-2009, 13:07:18   #72
PiluPelao
Edad: 63
Ahora se ve:
Amigos:
AUTOMETER
  • 22042" MOUNTING CUP, BLACK, PLASTIC GAUGE
  • 22372" 2-HOLE GAUGE PANEL, BLACK, ALUMINUM
  • 22382" 3-HOLE GAUGE PANEL, BLACK, ALUMINUM
  • 23003-3/4" TACH, 8,000 RPM, BLACK
  • 23023-3/4" TACH, 8,000 RPM, SHIFT-LITE, BLACK
  • 2343TIRE PRESSURE GAUGE, 60 PSI W/PEAK HOLD
  • 3207BLUE LIGHT BULB BOOTS (3/PKG)
  • 3211REPLACEMENT BULB & SKT FOR 2-5/8" & 2" MECH
  • 3214RED LIGHT BULB BOOTS (3/PKG)
  • 3215GREEN LIGHT BULB BOOTS (3/PKG)
  • 3218LONG-LIFE INTERNAL REPLACEMENT BULBS
  • 32246' COPPER TUBING, 1/8" DIA.
  • 3303-M2" BOOST-VAC, 60 Cm HG- 2.0 BARS, MECH
  • 3304-J2" BOOST-VAC, 2.5 Kg/Cm2 MECH
  • 3311-J2" FUEL PRESS, 0-1.0 Kg/ Cm
  • 23327-M2" OIL PRESS, 0-7 BARS, SSE, SPORT-COMP
  • 3332-M2" WATER TEMP, 50-115`C, MECH
  • 3337-M2" WATER TEMP, 40-120`C, SSE, SPORT-COMP
  • 3341-M2" OIL TEMP, 60-140`C, MECH
  • 3348-M2" OIL TEMP, 60-170`C, SSE, SPORT-COMP
  • 33912" VOLTMETER, 8-18 VOLTS SSE, SPORT-COMP
  • 4303-M2" BOOST-VAC, 60 Cm HG- 2.0 BARS, MECH
  • 43272" OIL PRESS, 0-100 PSI, SSE, ULTRA-LITE
  • 4327-M2" OIL PRESS, 0-7 BARS, SSE, ULTRA-LITE
  • 4337-M2" WATER TEMP, 40-120`C, SSE, ULTRA-LITE
  • 4348-M2" OIL TEMP, 60-170`C, SSE, ULTRA-LITE
  • 43532" OIL PRESS, 0-100 PSI, FSE
  • 43562-1/16" OIL TEMP, 100- 340`F, FSE
  • 43572" TRANS TEMP, 100-250`F SSE, ULTRA-LITE
  • 43632" FUEL PRESS, 0-100 PSI FSE, W/O PEAK & VALLEY
  • 43762" BOOST-VAC, 30 IN. HG/ 15 PSI, FSE, ULTRA-LITE
  • 43912" VOLTMETER, 8-18 VOLTS SSE, ULTRA-LITE
  • 5703-M2" BOOST-VAC, 60 Cm HG- 2.0 BARS, MECH, PHANTOM
  • 5727-M2" OIL PRESS, 0-7 BARS, SSE, PHANTOM
  • 5737-M2" WATER TEMP, 40-120`C, SSE, PHANTOM
  • 57912" VOLTMETER, 8-18 VOLTS SSE, PHANTOM
  • 5903-M2-1/16" BOOST-VAC, 60 CM/HG-2.0 BARS, MECH, ES
  • 5927-M2-1/16" OIL PRESS, 0-7 BARS, SSE, ES
  • 5937-M2-1/16" WATER TEMP, 40- 120`C, SSE, ES
  • 5948-M2-1/16" OIL TEMP, 60- 170`C, SSE, ES
  • 59903-3/4" TACH, 10,000 RPM, SHIFT-LITE, ES
  • 6103-M2-1/16" BOOST-VAC, 60 CM/HG-2.0 BARS, MECH
  • 6127-M2-1/16" OIL PRESS, 0-7 BARS, SSE, COBALT
  • 6137-M2-1/16" WATER TEMP, 40- 120`C, SSE, COBALT
  • 6148-M2-1/16" OIL TEMP, 60- 170`C, SSE, COBALT
  • 62903-3/4" TACH, 10,000 RPM, SHIFT-LITE, COBALT
  • 2339045" TACH, 10,000 RPM, SHIFT-LITE, AUTO GAGE
  • 2339055" TACH, 8,000 RPM, SHIFT-LITE, AUTO GAGE
  • 2339115" TACH, 10,000 RPM, SHIFT-LITE, AUTO GAGE
IRONMAN
  • 12083GRAmort. Del. Nitro-Gas VITARA
  • 12715GRAmort. del. Nitro-Gas L200 '06-
  • 12716GRAmort. del. Nitro-Gas D40
  • 12717GRAmort. tras. Nitro-Gas
  • D403522Amortiguador dirección
  • NISSAN3524Amortiguador dirección
  • TOYOTA3530Amortiguador dirección
  • SUZUKI3540Amortiguador dirección CJ7/YJ/TJ/X
  • MITS040BMuelle del. IRONMAN L200 '06- (B)
  • MITS040CMuelle del. IRONMAN L200 '06- (C)
  • MITS041BBallesta IRONMAN L200 '06- (B)
  • MITS041CBallesta IRONMAN L200 '06- (C)
  • NISS041CBallesta IRONMAN NAVARA D40 (C)
  • 795Gemela engr. IRONMAN l200 '06-
  • 1102UBKU-Bolt715TUKKit casq. ballestas IRONMAN L200
  • 762UKKit casq. ballestas IRONMAN XJ
  • 769UKKit casq. ballestas IRONMAN D40
  • W12000Cabrestante Monster 12000 12v
  • W9500Cabrestante Monster 9500 12v
  • IHOOKBOWGancho c/grillete IRONMAN
  • IRECOVERYKit rescate IRONMAN
  • ISNATCHEslinga IRONMAN 8tn x 9m (c/bolsa)
  • IHID001Luz Xenon 9" IRONMAN (unidad)
  • IVEGA220Vega 220 / 100W Halogen Light (pair)
  • IGAMMA175Gamma 175 / 100W Halogen Kit (pair)
Antiguo 29-07-2009, 13:16:01   #73
FSalinas
Contactar con FSalinas a través de MSN
A cuanto este producto?
FSalinas está offline   Responder Con Cita
Antiguo 29-07-2009, 13:22:13   #74
PiluPelao
Edad: 63
$63.282,- con IVA
Empezado por samu Ver Mensaje
Antiguo 29-07-2009, 19:57:31   #75
joacoZr2
Contactar con joacoZr2 a través de MSN
hola que es este kit 769UKKit casq. ballestas IRONMAN D40 , y cuanto cuesta si no es un kit de levante , cuanto sale unbo y cuanto levanta la navara d40
gracias saludos
joacoZr2 está offline   Responder Con Cita
Antiguo 29-07-2009, 20:29:48   #76
PiluPelao
Edad: 63
Dame un correo y te envio detalles y precios te parece?
Empezado por joacoZr2 Ver Mensaje
gracias saludos
Antiguo 29-07-2009, 20:32:28   #77
joacoZr2
hola ese es joaco.m25@gmail.com
Antiguo 29-07-2009, 22:15:09   #78
PatoPower
Avatar de PatoPower
Hola, llámame mañana. Gracias.
Pato Gajardo
Patopowerparts
PatoPower está offline   Responder Con Cita
Antiguo 29-07-2009, 23:58:30   #79
PiluPelao
Edad: 63
OK te llamo o paso
Empezado por PatoPower Ver Mensaje
Pato Gajardo
Patopowerparts
Antiguo 30-07-2009, 00:53:08   #80
Pato Molina
De cagado no tengo plan pagado, por lo que no puedo poner calificaciones, pero hice negocios con Personalized (PiluPelao) y un 7.
Espectacular el servicio, muy buenos precios, excelentes consejos, en fin nada más que decir, solo que una muy buena persona. Da gusto tratar con gente decente para los negocios.
Muchas gracias por todo y a hacerle empeño para poder comprarte los focos, me enamoré de ellos....................
Esto de tener tantas necesidades básicas mi señora aún no lo entiende, jajajajajjaja
Un abrazo y mucha suerte con el negocio.
Pato Molina.
Pato Molina está offline   Responder Con Cita
La franja horaria es GMT -3. Ahora son las 10:27:22.
