R/C Off Road Foro exclusivo para autos radiocontrolados Off Road, Stadium Truck, RC Crawling, etc. |
05-05-2013, 23:32:00 | #1 |
consulta para ecx torment
La consulta es la siguiente tengo una camioneta 4x2 ecx torment y quiero modificar la electronica completa ya que encuentro que tiene poca potencia la idea es que pueda andar en las duna lo mejor posible por lo que me gustaria que me ayudaran a elegir la mejor combinacion de motor y acelerador, estube viendo en hobbking un combo Brushless Car Power System 4000Kv/100A (11T) y quiero saber si sirve para lo que yo quiero o nesecito otra combinacion , aqui les dejo las especificaciones de mi camioneta para que puedan comparar
Type: 2WD Short Course Truck Scale: 1/10 Length: 20.00 in (507mm) Width: 11.60 in (295mm) Height: 7.75 in (196.8mm) Ground Clearance: 1.5 in (38.1mm) Wheelbase: 13.1 in (332.7mm) Weight: 5lbs (2.3kg) Chassis: Injection Molded Nylon Composite Suspension: Independent Drivetrain: 2WD Tire Type: Dynamite® Speedtreads Shootout Motor or Engine: Brushed 540 Radio: DX2E 2-Channel Batteries: 7.4V 1800 6-Cell NiMH Charger: NiMH AC Peak Charger 110V-240V 2.0A Gear Pitch: 48P Completely ready-to-run with everything needed in one box Preinstalled Dynamite® waterproof Tazer™ 15T ESC Spektrum™ DX2E 2.4 GHz transmitter and waterproof SR201 receiver Preinstalled Dynamite® 15T brushed motor Dynamite 2-amp peak charger included Dynamite Speedpack™ 1800mAh Ni-MH battery included Waterproof Dynamite servo Upgraded driveshafts provide additional reliability even when pushed to the limits ESC and battery come pre-wired with high-current EC3™ connector Nylon composite chassis and parts material provide extreme durability Beginner-friendly battery retaining system means there are no body clips to lose Adjustable oil-filled shocks provide great handling 2WD transmission with gear differential makes it reliable and efficient Transmission includes an adjustable slipper clutch Fully-painted and -decaled body out of the box means it's ready-to-run and looks good Dynamite SpeedTreads™ Shootout™ wheels and tires provide relentless grip Detailed Information Type: Brushed Size: 540 Bearings or Bushings: Bushing # of Turns/Windings: 15T Timing: No Voltage: 4.8 - 9.6V Cells: 4-8 Ni-Cd/Ni-MH or 2S Li-Po Overall Diameter: 1.42 inch (36mm) Shaft Diameter: .125" (3.175mm) Shaft Length: 0.60 inch (15.5mm) Overall Length: 1.98 inch (50mm) |
Compartir en Redes Sociales |
