Antiguo 28-04-2005, 19:01:35   #1
Predeterminado Suspensiones Pro.
Hola a todos .. me quedé plop
These links work different than hiems in that you would usually have hiems at each end of the link and you would want to lock the hiem shaft to the link, with lock nuts, so as to maintain their original setting. The axle movement and articulation is absorbed in the hiems.
In the use of the twisty, you use a twisty on the link end at the frame attachment point. The other end of the link has a welded fitting that has the eccentric cut (bling, weight, bling), the link is fixed in place by its mount to the axle, but still can still move in its mount. The twisty is fixed in place by its mount to the frame, but can also move in its mount. The link and the twisty do there work as the axle articulates.
Este es el thread .. muy interesante este Buggy ..
http://forum.ih8mud.com/showthread.p...1&page=3&pp=30
Que les parece ..
Antiguo 28-04-2005, 20:18:55   #2
Miren el bello resultado ..
Desde 0 impresionante ..
Antiguo 28-04-2005, 20:20:33   #3
Juan-Carlos
Avatar de Juan-Carlos
cual es la gracia??
que puede doblar mas o algo asi o mayor agarre
Antiguo 29-04-2005, 00:50:41   #4
juan andrade
Avatar de juan andrade
esos son diferenciales portal (de mog)pero esta borrada la parte donde se identifican
Antiguo 29-04-2005, 11:32:54   #5
Empezado por juan andrade
No son de Mog .. son Ford 9" claro que un hibrido con 3rd member de alimunio y otras hartas weas más ..
Antiguo 29-04-2005, 14:32:36   #6
Roberto Román
Avatar de Roberto Román
Empezado por Tapage
No son de Mog .. son Ford 9" claro que un hibrido con 3rd member de alimunio y otras hartas (%&#@) más ..
3rd member hibrido? viejito son de drag racer!
No traen planetarios ni satélites, piñón de ataque y corona nada más, olvídate del bloqueo...
Antiguo 29-04-2005, 14:57:36   #7
Roland
Avatar de Roland
Empezado por Roberto Román
Ese está con spool :wink:
Antiguo 29-04-2005, 19:17:47   #8
Empezado por Tapage
Ni las **** idea de como eran los diff de drag racer .. ni idea .. !
Antiguo 06-05-2005, 15:15:14   #9
Empezado por honguito 4x4
cual es la gracia??
Gracia :?: , te parece poco poder andar con esos neumaticos en un jeep de esa altura :?: Imaginate lo estable que es.-
Antiguo 06-05-2005, 15:32:57   #10
Predeterminado Re: Suspensiones Pro.
Empezado por Tapage
http://forum.ih8mud.com/showthread.p...ge=3&pp=30
Que les parece ..
El sistema y la contruccion del jeep no son de lo mas novedoso. Porsupuesto que el trabajo es increible.
Pero lejos lo que mas ma llamo la atencion es el tamaño de esos bujes
http://forum.ih8mud.com/attachment.p...7395&stc=1
Feria Pro Tiempo Libre Copa Jaque 4x4 TioGau Paseos, Raids, Competencias y Eventos 4x4. 77 09-12-2008 09:00:47
Vendo Motorola Pro 7150 Militar mayck_charly Venden - Partes y accesorios para 4X4 2 12-03-2007 13:32:19
pro y contra de bloqueo indura coco Novatos 9 22-02-2006 15:40:09
Vendo Handy Motorola Pro 3150 mayck_charly Venden - Partes y accesorios para 4X4 7 27-10-2005 10:04:00
Suspensiones Exoticas (articulo de la 4x4Power) JPVM General 4WD 5 31-12-1969 21:00:00
La franja horaria es GMT -3. Ahora son las 14:17:17.
