Antiguo 18-10-2007, 04:15:37   #1
AndR3Z
Predeterminado oyota Hilux High Lift
Estaba con ganas de comprarme la F-350 High Lift.. pero despues de ver esta.. uff.. no sé
compro esta y le compro a parte la carroceria de la 350?
... los dejo con la info y el link
http://www.tamiyausa.com/product/ite...oduct-id=58397
Combining nostalgic feel with modern mechanics, the superbly detailed classic Toyota pick-up truck body is now mounted on the same chassis as the Ford F-350 High-Lift.
# About the Model Durable ladder frame chassis features steel channel and resin crossmembers for high strength.
# Adjustable front and rear leaf spring suspension system equipped with friction dampers.
# 3-speed transmission allows gear changing and realistic low-speed driving.
# Propeller shafts and slipper clutch efficiently transfer power to all wheels on any type of terrain.
# Differential may be easily locked in place to enable improved off-road performance.
# Highly-detailed injection-molded body complete with new parts for rear bumper, muffler, side steps, side mirrors, and wipers, accurately reproduces the classic pick-up truck.
# Manufacturer logos depicted with metal transfer stickers, and various metal plated parts accentuate the truck's body.
# Quick-access battery compartment enables easy battery changes without removing body.
# Includes type 540 motor.
# 4-channel transmitter, ESC, and running battery & charger are all separately required.
# Installing the separately available Pick-Up Truck Multi-Function Unit MFC-02 (ITEM 53957) will further enhance the truck and put a wide range of realistic light, sound, and vibration effects at your fingertips.
Antiguo 18-10-2007, 10:26:32   #2
Thumbs up Re: oyota Hilux High Lift
Salio .. va a salir ??? .. cuenta mas po !!! mira que la temperatura aun no llega a un estado de compra ... jejejej
Antiguo 18-10-2007, 12:40:37   #3
Calvin
Predeterminado Re: oyota Hilux High Lift
Uta que linda.... definitivamente mi veta RC va por los de Escala, se ve muy linda... ¿caja tres velocidades...? ademas... ATR
Felcitaciones!!!!
Antiguo 18-10-2007, 12:48:02   #4
AndR3Z
la pille anoche a las 3AM en la pagina de Tamiya (llegue ahi por RCCrawler)... pero interiorizandome un poco mas anoche cache q la van a lanzar luego.. aun no tiene codigo de Tower Hobbies. es cosa de esperar no más.
Antiguo 18-10-2007, 15:23:58   #5
Gecko4x4
Avatar de Gecko4x4
Preciosa, increible el nivel de detalles.....el termometro comenzo a subir
Gecko4x4 está offline   Responder Con Cita
Antiguo 18-10-2007, 23:54:27   #6
Juan-Carlos
Avatar de Juan-Carlos
Compratela wn
esta filete
Antiguo 27-03-2008, 00:48:56   #7
AndR3Z
a todo esto la tienen en stock en hobby express en $273.600
por si hay algun otro calentin por ahi...
Antiguo 28-03-2008, 13:23:48   #8
matador
Edad: 61
utas que linda...pero ya tengo encargado mi FJ40 de Tamiya a Hobbiexpress...antes de fines de abril debería estar por estos lados...
salu2.Matador
Antiguo 31-08-2008, 19:31:04   #9
scorpions
Avatar de scorpions
Edad: 30
hola no pues esta chidicima yo me quiero comprar una = pero no sse donde
scorpions está offline   Responder Con Cita
La franja horaria es GMT -3. Ahora son las 23:15:33.
