Antiguo 01-05-2004, 09:50:41   #1
poroto ®
Predeterminado planeta off road de brasil
holaps
estuve mirando la web de planeta off road de brasil, que sale en los links
http://www.planetaoffroad.com.br/p08m.htm
este es el jeep de billj?
right?
porque no ha cambiado el motor?
dentro de todos los upgrades que tiene me suena como uno de los mas obvios y faciles de hacer.
por que no lo ha echo?
es complicado en brasil?
Antiguo 04-05-2004, 13:16:57   #2
billj
Predeterminado Re: planeta off road de brasil
Empezado por poroto
holaps
right?
Sim, é o meu jipe........... :wink:
Desde então, já troquei o motor para o 1.6 16V do Swift, entrou água no original.........
Não troquei antes porque não havia necessidade, o 1.3 atendia bem com a redução GRS 2 e diffs 4,88.......
Abraços,
billj está offline   Responder Con Cita
Antiguo 04-05-2004, 15:12:38   #3
poroto ®
Empezado por billj
Empezado por poroto
holaps
right?
Abraços,
aaaaaaaaaaaaaa
ok
alla puro barro???????
Antiguo 04-05-2004, 21:13:21   #4
Bill es americano, tal vez se le entenderia mejor si escribiese en Ingles .... :wink:
Antiguo 05-05-2004, 06:07:40   #5
billj
Empezado por JPVM
OK, this time in English....... :P
Yes, that is my rig.......... :wink:
Since thenm I´ve swapped the motor to a 1,6 16V from a Swift, water got into the original.........
I hadn´t swapped the motor before because there was no reason to, the 1,3 worked well with the GRS 2 t-case and 4,88 diffs........
Antiguo 05-05-2004, 07:21:17   #6
poroto ®
no worries billj
actually I got it just right the first time
I was just wondering, that it works just fine cos you only have mud there?
have you tried your configuration in rocks?? sand???
Antiguo 05-05-2004, 07:55:34   #7
billj
Empezado por poroto
no worries billj
With my gear reduction, I´ve had very little problems. Yes, the little 1.3 sometimes lacked torque in long mud runs, where tire speed is important. But in rocks, there was necer any problem. Sand I haven´t ran in much at all.
The 1,6 16 valve is a LOT more powerful though. I never would have imagined such a difference........ :wink:
Abraços,
Antiguo 05-05-2004, 07:59:08   #8
Empezado por poroto
Empezado por billj
Empezado por poroto
holaps
right?
Abraços,
aaaaaaaaaaaaaa
ok
Troquei=Cambiar=Swap
Leyendo despacio se entiende bien.
Antiguo 05-05-2004, 12:49:51   #9
Empezado por billj
Empezado por poroto
no worries billj
Abraços,
Hey Bill , is your Swift engine running on alcohol there in Brazil ? This gives a little more "uumph" over the regular gasoline engine , right ? Ever thought of making some 'zuki engine preparation following Suzuki's Pike Peak racer ?
Antiguo 05-05-2004, 13:46:10   #10
Empezado por JPVM
Empezado por billj
Empezado por poroto
no worries billj
Abraços,
Oye ueon, si quieres escribir en ingles andate a Pirate
IV Raid Fraternidad Off Road 2007 Organizado Por El Club Pucara 4x4 chelocko Paseos, Raids, Competencias y Eventos 4x4. 350 27-08-2007 21:40:46
Revista Off Road Javier Arancibia General 11 20-03-2007 13:48:31
4 Neumaticos 100% Off Road AZZ Venden - Partes y accesorios para 4X4 20 14-02-2007 22:47:44
Rally Road Book Ritoque AMERICO Rally Cross Country / Baja 9 21-09-2006 17:44:43
Este Viernes 4 de Julio se lanza Revista Off Road 4x4 RoNdrigo Pastén General 35 31-12-1969 21:00:00
La franja horaria es GMT -3. Ahora son las 20:55:39.
