Antiguo 27-04-2009, 23:21:11   #31
AlvaroSan
Predeterminado Re: 4x4 militares
Mmm, me quedo con lo neumas y tu Patrol JP, jejejeje
Antiguo 27-04-2009, 23:26:49   #32
High Mobility Multipurpose Wheeled Vehicle (HMMWV) (M998 Truck)
SpecificationsManufacturerAM GeneralWidth85"Ground Clearance16" LoadedLengthM966 / M998 / M1025 / M1035 / M1043 / M1045 / M1097180"M1026 / M1036 / M1038 / M1042 / M1044 / M1046185"M996 / M997202"HeightM998 / M1035 / M1037 / M1038 / M104269"M966 / M1025 / M1026 / M1036 / M1043 / M1044 / M1045 / M104673"M99686"M997102"Vehicle Curb WeightM998 / M1035 / M10387,700 lbs.M966 / M1025 / M1026 / M10368,200 lbs.M1043 / M1044 / M1045 / M10468,400 lbs.M966 / M1037 / M10428,660 lbs.M9979,100 lbsM1097 / M1097A110,000 lbs.M998A1 / M1035A1 / M1038A17,880 lbs.M966A1 / M1025A1 / M1026A18,380 lbs.M1043A1 / M1044A1 / M1045A1 / M1046A18,580 lbs.M996A18,580 lbs.M997A19,280 lbs.PerformanceMaximum Speed55 mph Governed @ Gross WeightRange275 - 337 mi.Maximum Grade60%Side Slope40 deg.FordingWithout Kit:30"
With Kit: 60"
Equipment SpecificationsCabCrew Seating2-4 ManSeat DesignFore/Aft AdjustableSteering TypePower AssistEngineManufacturerGeneral MotorsEngineDiesel, 8-cyl, 6.5 L, Naturally AspiratedRating150 hp @ 3600 rpm, EPA-CertifiedFuelDiesel, DF-2, JP-4, JP-8, VV-F-800CoolingWater, RadiatorFanEngine-Driven, Clutch TypeTransmissionManufacturerAllison, Fully AutomaticSpeeds3 Speeds Forward/ 1 ReverseTransferFull Time All Wheel Drive, Integral Transfer CaseSelf-Recovery Winch (Optional)OperationElectricLoad CapacityFifth Layer - 3,360 lbs.
Fourth Layer - 3,780 lbs.
Third Layer - 4,310 lbs.
Second Layer - 5,020 lbs.
First Layer - 6,000 lbs.
Antiguo 27-04-2009, 23:34:31   #33
Copiapo
Antiguo 28-04-2009, 00:26:45   #34
saggcl
Avatar de saggcl
JP
Faltan unas fotos de los Nissan Patrol de las FFAA, y lo que mas me gustarian serian unas fotos de los Mog de la Fuerza Aerea y de las camionetas 290GD de Telecomunicaciones del Ejercito
Te deje tarea
Antiguo 28-04-2009, 10:11:34   #35
Empezado por Julio Hevia Acuña Ver Mensaje
Guauu... que emoción ver tal cantidad de información y además ver que todos opinamos tan animosamente de los medios con que cuenta nuestra querida Armada de Chile o Infantería de Marina para ser un poco más específico...
A ver, algo de información que domino del tema... para empezar,.........
Con el tema de los HUMMERs que ven Uds en las fotos, efectivamente de la partida que se compró ya hay algunos que estan de baja... pero fue una compra de oportunidad y sin plan logístico ni plan de recambio (no conozco el detalle de cuantos llegaron ni cuantos hay funcionando)... pero de ahí a decir que solo hay 3 funcionando me parece algo exajerado, sin ir más lejos les puedo decir con certeza que hay 4 en Haití + los que ven Uds en las fotos + otros 2 en Pta Arenas + otros 2 o 3 en Talcahuano...
4 + 2 + 2 + 3(2) = 11(10), dificil, ya que solo llegaron 10, y de los cuales uno murio inmediatamente, o sea, nunca hubo mas de 9.-
Los de Hiati se me pasaron, y en PUQ yo que sepa NO hay.-
Antiguo 28-04-2009, 10:31:05   #36
SVarasV
Jeepmaniac
Avatar de SVarasV
Osea hay 7 dados de baja ??
Antiguo 28-04-2009, 10:36:59   #37
rinox
gracias JP por la fotos d los hummer.... son ricos....un "poco" mas civilizados de los MOG, pero igual de ricos vichos....que mala suerte que no existan aca en valdivia ...pasaria metido en el ejercito , como practico airsoft, en vez de la bushmaster , le colocaria una replica de ella en el techo pa dispararle a los pelaos, jajajjaja
saludos!
Antiguo 28-04-2009, 10:37:56   #38
rinox
dados de baja? es decir fuera de circulacion, listo pa remate y cosas asi?
saludos!
Antiguo 28-04-2009, 10:41:28   #39
SVarasV
Jeepmaniac
Avatar de SVarasV
saludos!
Nose, al menos no funcionando como decia GB ?
Antiguo 28-04-2009, 10:51:37   #40
Juan Luna
Hummer = perritos........
Yo tenia 10 perritos, bis, uno se murio el jueves no me quedan mas que 9.....
Delos 9 que quedaban,Bis, uno se cayo al mapocho no me quedan mas que 8...
La franja horaria es GMT -3. Ahora son las 05:17:56.
