Antiguo 18-02-2005, 09:03:59   #11
LAPOSO
Avatar de LAPOSO
Contactar con LAPOSO a través de MSN
YA po¨
cuanto cuesta !!!
LAPOSO está offline   Responder Con Cita
Antiguo 18-02-2005, 09:20:31   #12
LAPOSO
Avatar de LAPOSO
ha ... una consulta a los expertos:
sirve lo mismo que instalar una lona cubre pick up?
Antiguo 18-02-2005, 11:00:47   #13
Empezado por LAPOSO
Solo que no estas eliminando peso .. de hecho estas agregando el peso de la lona .. aunque depende de como esté confeccionada / colocada puede mejorar significativamente la resistencia ..
Antiguo 18-02-2005, 11:11:17   #14
La verdad que no em queda tan claro que sea mas eficiente la malla.
El tema aerodinamico no es tan simple como lo vemos los que no conocemos del tema, y hay ene aspectos que no son como pensamos.
Las bolsas de aire, efectos de presiones, y ene cosas mas hacen que el tema aerodinamico no sea tan simple.
No tengo tan claro que gaste menos con malla, no me extrañaria que el aire del pick up se mueva menos y que el otro se desplace sobre el o al go por el estilo.
Antiguo 18-02-2005, 11:19:28   #15
Ajaaaah miren lo que encontre:
http://www.awtrucks.com/tailgateup.htm
Dear Tom and Ray:
I'm an aerodynamics engineer. When I was in the U.S. Air Force a few years back, I worked with folks from the Lockheed low-speed wind tunnel.
In the 1970s aircraft production went into a slump, and Lockheed started looking.for other customers for its wind-tunnel services.
Prime candidates were automakers, and Lockheed was successful in convincing Ford, among others, that the wind tunnel wouId help them reduce drag and wind noise on their vehicles.
Needless to say, in the past 15 to 20 years, Lockheed has learned a lot about car and truck aerodynamics.
Anyway, they actually performed drag tests on pickups with the tailgate both up and down, and found that drag was actually LOWER with the tailgate CLOSED!
This ran counter to their intuition (and yours). The reason is that a closed tailgate sets up a large "bubble" of stagnant air that slowly circulates around the bed of the truck (we aero types call this a ("separated bubble"). When air approaches the truck, it "sees" the bubble as part of the truck. So to the air, the truck looks like it has a nice, flat covering over the bed, and the air doesn't "slam" into the vertical tailgate.
If the tailgate is open, or replaced by one of those "air gate" nets, however, that nice, separate bubble in the truck bed does not form (it "bursts").
Then the air approaching the truck "sees" a truck with a flat bed on the back of a tall cab. This is a very nonaerodynamc shape with a very LARGE drag.
So, believe it or not, it's best for gas mileage to keep the tailgate CLOSED. Hope this information is helpful.
Ed Fitzgerald
Research Assistant
Department of Aero/Mechanical Engineering
University of Notre Dame
En palabras simples, las camionetas tienen mejor coeficiente aerodinamico con la tapa que con la malla.
Antiguo 18-02-2005, 11:22:00   #16
Magonza4x4
Avatar de Magonza4x4
Edad: 60
...viste Eduardo que es pura calentura???
Gracias Gonzalo!! :wink:
Magonza4x4 está offline   Responder Con Cita
Antiguo 18-02-2005, 11:27:26   #17
Eduardo Silva
Avatar de Eduardo Silva
Empezado por Magonza4x4
Le creo a Ed Fitzgerald (Parece que sabe de lo que esta hablando)
Efectivamente Marcelo, es pura calentura...
Antiguo 18-02-2005, 11:28:51   #18
BUSTED
Antiguo 18-02-2005, 11:31:01   #19
-ArtSerey-
JAJAJAJAJAJA!!!!! :) :D
traktorke
Antiguo 18-02-2005, 13:21:47   #20
Empezado por Gonzalo Bravo
Dear Tom and Ray:
Ed Fitzgerald
Research Assistant
Impeque el dato GB
Parece inverosimil que actuen dos bolsas de aire en una misma area de contacto como es el bed de un pic up ..
Frecuencias HALTERO General 31 06-02-2012 16:10:43
Nissan King Cab 4x4 unica en Chile JPVM Venden - Vehiculos 4X4 132 27-08-2007 20:26:16
4ta fecha y ultima fecha de rally baja chile !!! AMERICO Rally Cross Country / Baja 64 10-11-2006 20:06:39
¿Quien entiende a Toyota Chile? Pato Fernández General 27 29-07-2004 14:00:57
La franja horaria es GMT -3. Ahora son las 23:49:14.
