Antiguo 22-06-2015, 14:54:03   #11
Martin Guerra
Predeterminado Re: Salidas de estanque de bencina
Ese es el queso. buena !!! Gracias
Empezado por RVP Ver Mensaje
en la descripcion dice, tiene valvulas en las puntas que se cierran con el aire (ni idea como)
http://www.polyperformance.com/Liqui...le-Pickup-Kits
n Tank Fuel Pickup Kits from Liquid Iron Industries are an easy to install solution to fuel starvation at steep angles and high G forces with low fuel levels. Each pickup contains a one way valve that closes when exposed to air so the system always pulls fuel. Get the most out of your fuel cell with a multiple pickup kit from Liquid Iron Industries. These kits can be installed in under an hour with common hand tools and a drill.
Martin Guerra está offline   Responder Con Cita
La franja horaria es GMT -3. Ahora son las 13:47:54.
