Antiguo 17-11-2005, 20:04:39   #11
Ignacio
Avatar de Ignacio
Contactar con Ignacio a través de MSN
Empezado por SALVELINUS
A que motor y tranfer se puede acomplar sin tener que hacer fllanche,
Motor: por lo que se, cualquier Chevrolet 262, 350, etc...
Transfer: NO estoy seguro, pero yo tengo el adaptador para la NP203 que lo podría dar junto con la caja.
Ignacio está offline   Responder Con Cita
Antiguo 17-11-2005, 20:12:29   #12
Javier Acuña
Avatar de Javier Acuña
Si no me equivoco la transfer era la NP208. No estoy seguro sobre la NP205.
Un poco de info:
The SM465 is an outstanding, heavy-duty truck transmission designed and used in ½, 3/4 and 1+ ton trucks. The SM465 was made by General Motors from 1968 to 1991. They are found primarily in GM and Chevrolet trucks, Blazers, Suburbans and many other models falling under the 1/4-ton to 1-1/2-ton platforms.
The 465 is an intellegently designed and very well-built transmission and remains easy to locate and generally inexpensive to buy and maintain. The strength, relatively short size and the gearing of the transmission make it a good choice for a variety of on-road and off-road situations. It has a very good set of road manners contrasted by its enormous off-road brawn.
The "SM" in the transmission's designation stands for Syncrho-Mesh, in the tradition of other GM gearboxes.
As the reader will conclude, the Chevrolet and General Motors SM465 will marry directly to a GM style bellhousing. This includes Chevy car, Buick, Oldsmobile and Pontiac bellhousings. However, since this transmission has such a large bearing retainer, the car size bellhousing bore is smaller than the transmission's input bearing retainer. If you need to join this transmission to a GM bellhousing with the 4-11/16” bore, it can be done. The bore must be opened up to 5.000” and the retainer turned down to 4.995” as precision slip-fit. We can perform this service with a very quick turnaround, or you may have it done by a good machine shop local to you. We also sell new bearing retainers turned to the dimension you require.
Antiguo 30-11-2005, 20:43:25   #13
Ignacio
Avatar de Ignacio
Aún en venta
Antiguo 03-12-2005, 07:01:26   #14
4x4virtual
Contactar con 4x4virtual a través de MSN
Predeterminado caja
le puedo poner un transfer de renegado un dana 20 ?
4x4virtual está offline   Responder Con Cita
Antiguo 03-12-2005, 16:34:12   #15
4x4virtual
Predeterminado sm 465
esta llegar y usar .. ?
Antiguo 05-12-2005, 15:04:18   #16
Ignacio
Avatar de Ignacio
Empezado por 4x4virtual
No se.
Antiguo 05-12-2005, 15:06:55   #17
Ignacio
Avatar de Ignacio
Está en perfecto estado
Antiguo 06-12-2005, 16:00:50   #18
4x4virtual
Predeterminado sm
vale , entonces se puede poner la np-205 ?
Antiguo 06-12-2005, 16:11:46   #19
Ignacio
Avatar de Ignacio
No lo se, ya que esta caja estaba puesta con un adaptador a una transfer NP203. y después a una NP205 (era parte de una configuración doubler SM465 + NP203 + NP205.
Que dato necesitas para saber si es compatible cin la NP205? cantidad de etrías del eje de salida?
Antiguo 08-12-2005, 15:44:21   #20
4x4virtual
Predeterminado muncie
eso mismo. gracias
Opcion cambio de TH350 por Muncie 465??? mbonifacino General 4WD 12 09-04-2007 18:20:08
sm465 2WD cristianz Novatos 10 01-04-2007 00:50:30
Sm465...1997 Gato Richy Venden - Partes y accesorios para 4X4 1 01-11-2006 02:08:58
Muncie SM465 Gato Richy Venden - Partes y accesorios para 4X4 11 24-09-2005 14:44:04
La franja horaria es GMT -3. Ahora son las 22:20:58.
