Antiguo 28-11-2023, 03:23:13   #11
Zaher0021
Edad: 28
Predeterminado Re: Distribuidor del toyota land cruiser
Empezado por Jarriero Ver Mensaje
Hola les queria preguntar donde puedo comprar un distribuidor sellado para un toyota land cruiser 81 (es con platino y condensador), ya que cuando me meto al barro con mucha agua se moja y empieza con los tirones. O si Uds tiene otra solucion para esto.
Muchas Gracias
Espero una pronta respuesta.
Hello Diego,nrega job card list
Installing a Chevrolet distributor in a Toyota 2F or 3F engine involves connecting the red cable to the positive side of the ignition coil and the green cable to the negative side. Ensure the distributor is correctly aligned with the engine's timing marks before tightening it down. It's crucial to follow the specific wiring diagram for your distributor and engine model to ensure proper connections. If you have a service manual for your vehicle, it would provide detailed instructions. Good luck with your installation.
Zaher0021 está offline   Responder Con Cita
Antiguo 27-01-2024, 10:02:35   #12
nora10
Muchas Gracias
For a sealed distributor for your '81 Toyota Land Cruiser, I recommend checking with Toyota dealerships, auto parts stores, or online platforms specializing in vintage car parts. Ensure the distributor is compatible with platinum and a condenser. Additionally, consider water-resistant ignition components or installing a distributor cap with a tight seal to minimize water entry. Regular maintenance, including checking seals and wiring, can also prevent moisture-related issues. Addressing these concerns will help enhance your Land Cruiser's performance during off-road adventures.
Última edición por nora10 fecha: 27-01-2024 a las 10:12:18
nora10 está offline   Responder Con Cita
Antiguo 27-01-2024, 10:10:23   #13
nora10
El distribuidor oficial del Toyota Land Cruiser desempeña un papel crucial al poner en manos de los entusiastas y clientes este icónico vehículo todoterreno. Como punto de conexión entre la marca y los consumidores, el distribuidor no solo proporciona acceso a la última tecnología y diseño de Toyota, sino que también ofrece servicios esenciales, respaldo y mantenimiento. Con un enfoque en la calidad y la satisfacción del cliente, el distribuidor del Toyota Land Cruiser juega un papel fundamental en la experiencia de quienes buscan aventuras en un vehículo robusto y confiable.
La franja horaria es GMT -3. Ahora son las 08:53:21.
