Antiguo 12-05-2013, 22:21:40   #11
Carlos Cabrera
Thumbs up Re: Tercera Venta Garage
Empezado por FRANCO-RC Ver Mensaje
Me interesa el mitsubishi lo tienes aun ?
Aún a la venta,Franco.-
C.
Antiguo 14-05-2013, 20:02:35   #12
Carlos Cabrera
Post Re: Tercera Venta Garage
13.-Tapa original nueva Axial para diferencial Wraith,Ridgecrest
¿No sería bueno tener un repuesto barato para cuando la perfores de tanto rasparla o de un golpe???
$2.500.- VENDIDA
Antiguo 17-05-2013, 13:50:08   #13
Carlos Cabrera
7.-(2) Set de retenedores de cruzetas cardán para Tamiya CR-01.-
Compeltamente nuevo.-
$3.500.- c/par.- VENDIDOS
Antiguo 04-06-2013, 21:06:24   #14
Eduardo4x4
Predeterminado Re: Tercera Venta Garage
tienes aun el ESC
Eduardo4x4 está offline   Responder Con Cita
Antiguo 04-06-2013, 21:15:06   #15
Guga
Mande PM ..!!
Guga
Guga está offline   Responder Con Cita
Antiguo 04-06-2013, 22:44:41   #16
Carlos Cabrera
Si señores.
Aún ambos a la venta
Entrega sólo en Stgo:
4.-ESC Tamiya TEU104BK , Nuevo y Plastidipeado
Sport Tuned/25T limit
LiFe low voltage cutout
Max continuous current 60A forward
Output: Forward 100%, Reverse 50%
Weight: 47g
Size: 39.4 x 36.5 x 15mm
Input voltage: 6.6 - 7.2v
RX output voltage: 6.6 - 7.2v(Requiere BEC)
Drive frequency: 1khz
Feature:
For Motor Size: 540
Running Mode: Forward/brake/reverse control
Compatible receiver:Receivers with BRC designated for ground vehicle R/C models
Button allows easy setting of forward/reverse high points and neutral position
Reverse function can be disabled.
Features heat and over current protection functions with LED indicator.
Alarm and LED warnings indicates no-signal status .
Compatible with LF batteries, and includes a battery cut-off function to prevent over-discharging .
Equipped with aluminum heat sink Compatible with receivers from Tamiya and other manufactuers
When used with machines such as rock crawlers, protection functions works and may stop operation due to excessive motor load.
$20.000.-
5.-ESC Outcry Crawler Usado y "Plasti-dipeado"
Input Voltage: 4-12 NiCd/NiMH cells (1.2V per cell) or 4S LiPo cell
Weight: 49g / 1.72 oz
Size: 35mm/1.37inch x 33mm/1.29inch x 30mm/1.18inch
BEC input 5V-23V, 2S-4S Lipo
Rated current: 300A forward, 150A reverse
Motor limit: Anything more than 30+ turn brushed
Discrete Steps: 128 Forward, 128 Reverse
Connectors: Futaba J, Standard for Battery, Bullet Motor (all pre-installed)
Status LEDs: 1
Delay in reverse: No
Drag break: Yes
No Lipo Cutoff
$23.000.-VENDIDO
C.
Última edición por Carlos Cabrera fecha: 08-06-2013 a las 13:05:55
Antiguo 08-06-2013, 13:05:31   #17
Carlos Cabrera
Exclamation Re: Tercera Venta Garage
$23.000.- VENDIDO
Antiguo 20-06-2013, 11:52:02   #18
Carlos Cabrera
Sigue venta.-
C.
Antiguo 22-06-2013, 16:02:15   #19
Carlos Cabrera
9.-Preciosa carrocería Tamiya completa (Body) plástico duro Mitsubishi Pajero
Completamente nueva y embalada
Muchos detalles, limpiaparabrisas, espejos ,neblineros ,sunroof.
Focos,neblineros,pisaderas y parachoques cromados.-
1:10
Wheel base :252 mm
$35.000.-VENDIDA
3.-Ruedas para repuesto Tamiyas Nuevas
Diámetro Llanta 52mm
Diametro neumático 88mm
Hex 12 mm
Peso 55 gramos !!!
$5.000.-C/U.-VENDIDAS
Antiguo 07-10-2013, 22:01:27   #20
4x4x4
Avatar de 4x4x4
Sería bueno si pudieras anotar qué cosas van quedando.
4x4x4 está offline   Responder Con Cita
La franja horaria es GMT -3. Ahora son las 11:47:16.
