Antiguo 11-05-2013, 15:46:35   #1
Carlos Cabrera
Exclamation Tercera Venta Garage
Amigos, debido al enorme éxito de la última venta , aquí publico más cosas compradas de más ,en mi "Tercera Gran Venta Garage."
Algunos precios son conversables.
Venta sólo Santiago. Entrega en mi trabajo o en mi casa.-
"La venta se concreta sólo cuando yo te confirmo."
1.-Cargador Tower Hobbies
Usado . Optimas condiciones
1-8 celdas NiCd y 1-8 Celdas NiMh
110v , 10 memorias, 0.1 a 5 Amp.
Múltiples programaciones.-
Extra super fácil de usar.
Requiere transformador con la potencia suficiente.-
Peak charges 1-8 NiCd or NiMH cells
Charge current ranges from 0.1 to 5.0 amps (3A maximum with AC input)
Adjustable trickle charge rates from 0, 100mA, 200mA
AC/DC convenience for use at home or track
2 x 8 LCD for easy programming and use, showing battery volts, peak
sensitivity, charge time, current and capacity various error indications and more
Adjustable peak sensitivity from 3mV - 20mV, to custom match
charger to specific batteries
Automatic charge mode automatically sets charge parameters based on
the operating condition of the battery
Store pre-set charge parameters for up to 10 batteries in memory
Multiple sound cues and melodies
Solid-state reverse polarity and short circuit protection on input and output
INCLUDES: Tower Hobbies AC/DC Digital Peak Battery Charger with manual
One lead with standard connector.
SPECS: Input Voltage: 110V AC 60Hz, 11-15V DC
Compatible Cell Types: Nickel-Cadmium (NiCd), Nickel-Metal Hydride
NiMH)
Cell Count: 1-8 cells
Peak Charge Rate: .1-5A (3A max. w/AC input)
Fast Charge Termination: Peak detection
Trickle Charge Rate: 0, 100mA, 200mA selectable
Peak Sensitivity: 3-20mV adjustable
Display Type: 2x8 LCD
Sound Cues: Individual tones and pre-set melodies
Battery Memory: 10
Output Connectors: Spring loaded terminals
Case size: 5 x 3.4 x 5.5" (127 x 86 x 140mm)
Weight: 2.94lb (1335g)
$15.000.-
VENDIDO
2.-Transformador 220v--->110v
300 watts
$10.000.-
VENDIDO
3.-Ruedas para repuesto Tamiyas Nuevas
Diámetro Llanta 52mm
Diametro neumático 88mm
Hex 12 mm
Peso 55 gramos !!!
$5.000.-C/U.-
VENDIDAS
4.-ESC Tamiya TEU104BK , Nuevo y Plastidipeado
Sport Tuned/25T limit
LiFe low voltage cutout
Max continuous current 60A forward
Output: Forward 100%, Reverse 50%
Weight: 47g
Size: 39.4 x 36.5 x 15mm
Input voltage: 6.6 - 7.2v
RX output voltage: 6.6 - 7.2v(Requiere BEC)
Drive frequency: 1khz
Feature:
For Motor Size: 540
Running Mode: Forward/brake/reverse control
Compatible receiver:Receivers with BRC designated for ground vehicle R/C models
Button allows easy setting of forward/reverse high points and neutral position
Reverse function can be disabled.
Features heat and over current protection functions with LED indicator.
Alarm and LED warnings indicates no-signal status .
Compatible with LF batteries, and includes a battery cut-off function to prevent over-discharging .
Equipped with aluminum heat sink Compatible with receivers from Tamiya and other manufactuers
When used with machines such as rock crawlers, protection functions works and may stop operation due to excessive motor load.
$20.000.-
VENDIDO
5.-ESC Outcry Crawler Usado y "Plasti-dipeado"
Input Voltage: 4-12 NiCd/NiMH cells (1.2V per cell) or 4S LiPo cell
Weight: 49g / 1.72 oz
Size: 35mm/1.37inch x 33mm/1.29inch x 30mm/1.18inch
BEC input 5V-23V, 2S-4S Lipo
Rated current: 300A forward, 150A reverse
Motor limit: Anything more than 30+ turn brushed
Discrete Steps: 128 Forward, 128 Reverse
Connectors: Futaba J, Standard for Battery, Bullet Motor (all pre-installed)
Status LEDs: 1
Delay in reverse: No
Drag break: Yes
No Lipo Cutoff
$23.000.-
VENDIDO
6.-Kit RC4WD de 4 links para Trail Stomper.
Completamente nuevo.
Con esto transformas la suspencion con paquetes de resortes a Liks , aumentando dramáticamente su recorrido y desempeño Off Road.
Sólo para un yugo.-Puede ser delantero o trasero indistintamente.-
$20.000.-
VENDIDO
7.-(2) Set de retenedores de cruzetas cardán para Tamiya CR-01.-
Compeltamente nuevo.-
$3.500.- c/par.-
VENDIDOS
8.-Set de links plásticos de repuesto para Wraith y Ridgecrest .(2 Sup y 2 Inf) (2 set a la Vta)
La primera salida que tuve con la Wraith choqué y rompí un link.Lamentablemente no vienen repuestos en los RTR.
Por eso pensé que me hubiera gustado tener unos de repuesto y además baratitos e hice estos pequeños packs para repuestos.
$2.500.-c set.-
9.-Preciosa carrocería Tamiya completa (Body) plástico duro Mitsubishi Pajero
Completamente nueva y embalada
Muchos detalles, limpiaparabrisas, espejos ,neblineros ,sunroof.
Focos,neblineros,pisaderas y parachoques cromados.-
1:10
Wheel base :252 mm
$35.000.-
VENDIDA
10.-Links plásticos para SCX-10 y reemplazar tu barra "Y". Usadas
$2.000.-(2 set)
11.-Repuesto LED Axial AX24256 para Sistema NVS nuevo.-(2 a la venta)
$4.000.- cu
12.-Repuesto LED Axial AX24254 para Sistema NVS nuevo.- (2 a venta)
$2.000.- cu.-
13.-Tapa original nueva Axial para diferencial Wraith,Ridgecrest
¿No sería bueno tener un repuesto barato para cuando la perfores de tanto rasparla o de un golpe???
$2.500.-
VENDIDA
14.-Motor brushed Tamiya 27T nuevo .-
$8.000.-
VENDIDO
15.-Cuerpo plástico (4) amortiguadores con tapa y rosca Wraith ,Ridgecrest.-
$2.500.-
16.-Cuerpos plásticos con tapa y rosca amortiguadores SCX-10.(4) Nuevos.
$2.000.-
17.-Roscas aluminio (2) para amortiguadores SCX-10.Nuevas.-
$3.000.-
18.-Set barra de direccion SCX-10 Nueva.-
$3.500.-
La gran mayoría nuevo.
Todo lo usado está en buenas u óptimas condiciones
Cualquier duda me preguntas !!.-
Saludos-.-
Carlos.-
Última edición por Carlos Cabrera fecha: 08-10-2013 a las 09:42:43
Antiguo 11-05-2013, 15:58:04   #2
Carlos Cabrera
Exclamation Re: Tercera Venta Garage
Nombre:  DSC01381.jpg
Vistas: 631
Tamaño: 71,4 KB
Nombre:  DSC01274.jpg
Vistas: 626
Tamaño: 48,0 KB
Nombre:  DSC01275.jpg
Vistas: 623
Tamaño: 44,6 KB
Nombre:  DSC01375.jpg
Vistas: 626
Tamaño: 67,0 KB
Nombre:  DSC01374.jpg
Vistas: 628
Tamaño: 63,5 KB
Nombre:  DSC01276.jpg
Vistas: 626
Tamaño: 65,3 KB
Antiguo 11-05-2013, 16:00:53   #3
Carlos Cabrera
Nombre:  DSC01376.jpg
Vistas: 638
Tamaño: 78,1 KB
Nombre:  DSC01377.jpg
Vistas: 634
Tamaño: 71,7 KB
Nombre:  DSC01378.jpg
Vistas: 639
Tamaño: 68,2 KB
Nombre:  DSC01379.jpg
Vistas: 635
Tamaño: 77,7 KB
Nombre:  DSC01380.jpg
Vistas: 639
Tamaño: 66,1 KB
Antiguo 12-05-2013, 10:01:07   #4
MLOZANO
Got Jeep?
Avatar de MLOZANO
Predeterminado Re: Tercera Venta Garage
Hola
Cuanto miden las ruedas tamiya? (Altura)
son con hex de 12mm?
Mariano
UTV Polaris Ranger RZR 2008
Antiguo 12-05-2013, 10:08:27   #5
vodska
Avatar de vodska
El body Mitsubishi que escala es?
Antiguo 12-05-2013, 11:11:31   #6
Guga
Mande PM
Guga
Guga está offline   Responder Con Cita
Antiguo 12-05-2013, 14:42:32   #7
Carlos Cabrera
Post Re: Tercera Venta Garage
Hola
Mariano
Diametro neumático 88 mm
Hex 12 mm
Peso 55 gramos !!!
C.
Última edición por Carlos Cabrera fecha: 12-05-2013 a las 14:48:40
Antiguo 12-05-2013, 14:46:05   #8
Carlos Cabrera
Empezado por vodska Ver Mensaje
1:10
Wheel base :252 mm
C.
Antiguo 12-05-2013, 14:50:46   #9
Carlos Cabrera
Empezado por Guga Ver Mensaje
Mande PM
Guga
Respondido.
Entrega en mi trabajo en el Centro o en mi Dpto Ñuñoa.-
C.
Antiguo 12-05-2013, 21:10:38   #10
FRANCO-RC
Me interesa el mitsubishi lo tienes aun ?
FRANCO-RC está offline   Responder Con Cita
La franja horaria es GMT -3. Ahora son las 19:01:23.
