Antiguo 24-05-2011, 20:17:53   #21
jarogo
Edad: 77
Predeterminado Re: Bec
Empezado por JOTE Ver Mensaje
Según la página oficial: http://www.teamtekin.com/fx.html
Dice que para usar 3s, debe ser un motor 35T hacia arriba, es decir, no menor.
Saludos!!
Jote
Entiendo hay que hacer un upgrade a traves del HotWire interface....será para que aguante 3 celdas?
Es correcto eso??'
Levantemos el caso a tekin..jejejejeje
Sigo atento
Antiguo 26-05-2011, 17:57:55   #22
Smile Re: Bec
Gustavo, pase por Mirax para preguntar por el BEC de 8A y a pesar de que aparecen 8 en stock me dijeron que no los encuentran, en una de esas ya los rescataron de bodega y podrian estar a la vista.
Antiguo 27-05-2011, 17:24:20   #23
Smile Re: Bec
Señores y este BEC al no estar el otro tambien sirve ??? http://www.mirax.cl/detalles.php?codigo=132445
Specifications
Dimensions: 48 x 27 x 9mm
Input Voltage: 8 - 42V (3 - 10 cells lithium battery pack)
Output Voltage: 5V or 6V(Changeable with an jumper)
Continuous Output Current: 5 Amps
Burst Output Current: 7.5 Amps
Quiescent Current: 20mA
Cable Length: 90mm (Battery), 380mm (Receiver)
Features
1. Designed with an advanced switch mode DC-DC regulator IC, the max efficiency of the chip is up to 92%.
2. The output current is very large, the continuous output current is up to 5 Amps, and the burst output current is up to 7.5Amps.
3. With the output short-circuit protection function.
4. A metal shield covers almost all the electronic components, and a filter (ferrite ring) is attached with the output wires to significantly reduce the electromagnetic interference.
5. With ultra-wide input voltage from 8V-42V.
6. Safe power on with the polarity protection function. If the input polarity is not correct, the UBEC can’t work, but it will not be damaged. What you need to do is just swapping the battery pack’s polarity.
7. Shows the working status with an indicator (LED), it lights when the output is in normal range.
8. It has a switch to turn on or turn off the output.
9. Accessory: A step-down voltage regulator with 0.7V down.( from 6.0V to 5.3V)
La franja horaria es GMT -3. Ahora son las 08:43:20.
