Antiguo 07-11-2014, 08:50:32   #1
Toyotero Calama
Avatar de Toyotero Calama
Predeterminado superchip wrangler JK
lo compre para cherokee y llego equivocado para wrangler 2007 al 2014
sirve para cambiar varios parametros ademas de ver codigos de error y eliminar dichos codigos (funcion de scanner), normalizar odometro por cambio de medida de neumaticos o relacion de piñon y corona ademas de mas parametros
esta nuevo en caja con todos sus manuales
$150.000.- me costo
acepto ofertas
Introducing the Superchips Flashcal for 2007-2014 JK Wrangler. We’ve done our homework and have loaded the Flashcal with the most sought after options for your JK. Take full advantage of the most popular aftermarket upgrades your late model JK craves. If you’ve added tires or gears to your Jeep, Flashcal is a must!
KEY PRODUCT FEATURES:
• Corrects speedometer for tire upgrades between 22.5” - 44.25”
• Speedometer recalibration for gear /axle swaps up to 5.38
• Locking axle options with transfer case in 4-Hi & 4-Low (2007-10 Rubicon only)
• ESP stability optimization (2011-14 automatic transmission models only)
• Engine idle adjustability for winching
• Street legal TPMS adjustability (Off-Road options available for download)
• Daytime running light options (2007-14 models only)
• One touch lane change
• Radio delay options (2011-14 models only)
• Headlamp delay options (2011-14 models only)
• Horn chirp and exterior lighting flash options when locking doors with keyless entry
• Reads and clears diagnostic trouble codes
• Internet updatable
* Results and feature set may vary based on vehicle make, model, and aftermarket upgrades. Read all instructions before installation and/or operation of this product use.
Antiguo 11-11-2014, 08:56:07   #2
Toyotero Calama
Predeterminado Re: superchip wrangler JK
arriba, se aceptan ofertas
Antiguo 29-11-2014, 14:59:03   #3
Toyotero Calama
Se remata quien dijo yo
Antiguo 29-11-2014, 16:45:04   #4
mzrox
Me interesa. Aceptas $100.000 ?
mzrox está offline   Responder Con Cita
Antiguo 29-11-2014, 16:49:23   #5
Toyotero Calama
Empezado por mzrox Ver Mensaje
No hay problema
Antiguo 29-11-2014, 16:51:20   #6
mzrox
Excelente!
La franja horaria es GMT -3. Ahora son las 14:51:35.
