| Rally Cross Country / Baja Foro exclusivo para Rally Cross Country o carreras tipo Baja |
Herramientas |
#1 |
Edad: 28
Amigos necesito su ayuda,aquí grabé un videoPROBLEMA CRAWLER KING ESC/RECEIVER: http://youtu.be/-unA9s77Rj4
#2 |
Probaste el manual de usuario? Nose si te servirá, nunca ni he usado una de esas cosas.
1. Turn on the transmitter’s power switch. (Be sure the transmitter batteries are fully charged). 2. Turn the ESC switch on. 3. Press and release the setup button. The red and green LEDs will light. 4. Move the throttle to the full throttle position and press the programming button. The green LED will remain lit and the red LED will go out. (If the ESC does not sense throttle movement in 3 seconds by the transmitter, it will exit the programming mode and you will have to begin again.) 5. Now move the throttle to full reverse and press the programming button. The red LED will glow and the green LED will go out. 6. Return the throttle to neutral and press the programming button. The green LED will glow and the red LED will go out, indicating programming is complete. During normal operation, the green LED indicates neutral and the red LED indicates full forward and full reverse. http://www.bladehelis.com/prodinfo/Files/LOSB9521.pdf http://www.horizonhobby.com/pdf/LOSB0104_Manual.pdf Última edición por samir.18 fecha: 08-02-2015 a las 07:40:06 |
