Antiguo 14-10-2015, 10:20:41   #1
Kustom Parts
Avatar de Kustom Parts
Predeterminado Radiador Mishimoto Jeep TJ/YJ
Radiador MISHIMOTO para Jeep TJ/YJ, nuevo sellado.
$300.000
Direct fit for the 1987–2006 Jeep Wrangler TJ/YJ with 2.5L/4.0L engine
Full aluminum construction including durable, TIG-welded end tanks
Features a two-row, 1.97" thick, efficient brazed aluminum core
Increases fluid capacity by .36 gal over stock Jeep Wrangler radiator
Provides a proven 20% improvement in fluid cooling efficiency, ideal for use on the street or trails
Engineered for use in both stock and highly modified vehicles
iIncludes 1.3 Bar High-Pressure Radiator Cap which effectively raises the boiling point of engine coolant, providing a safer and more efficient system
Includes Magnetic Drain Plug to capture any metallic debris/fragments in your cooling system
Mishimoto Lifetime Warranty
Kustom Parts está offline   Responder Con Cita
Antiguo 01-12-2015, 13:13:04   #2
Kustom Parts
Predeterminado Re: Radiador Mishimoto Jeep TJ/YJ
UP, gran regalo para esta Navidad.
Antiguo 18-12-2015, 10:48:28   #3
Kustom Parts
PM respondidos
Antiguo 06-01-2016, 11:51:41   #4
Kustomparts
Vendido!!!
Kustomparts está offline   Responder Con Cita
Antiguo 15-01-2016, 17:53:49   #5
Kustom Parts
Vendido, gracias TA
slds,
La franja horaria es GMT -3. Ahora son las 07:03:47.
