Antiguo 15-03-2016, 13:48:03   #1
turbo_lover
Predeterminado Diferencia performance entre 4runners 4th gen
Estimados buenas tardes,
Estuve leyendo y me encontré con este articulo:
Las mas antiguas con caja 4ta (Año 2004)
"Excellent Performance
4Runner power is supplied by a 4.0-liter V6 aluminum engine with variable valve timing with intelligence (VVT-i). The lightweight engine is Toyota’s first all-aluminum engine on a light truck. It features a new linkless electronic throttle control system with intelligence (ETCS-i) that helps improve performance and increase fuel economy. The V6 produces 245 horsepower at 5,200 RPM and generates 282 lb.-ft. of torque at 3,400 RPM. The V6 delivers capable fuel economy with EPA city/highway gas mileage estimates of 18/21 mpg for 2WD models and 17/21 for 4WD grades. The V6 engine is EPA-certified as a Low Emission Vehicle (LEV)."
Y las post 2005 (Con caja 5ta) Año 2009:
The 4Runner is available with a choice of V6 or V8 engines, in both 2WD and 4WD models. The standard 4.0-liter dual overhead cam (DOHC) V6 engine produces 236 horsepower, with 266 lb-ft. of torque at 4,000 rpm
Alguien tiene info sobre esto ??
Gracias de antemano
Rod
turbo_lover está offline   Responder Con Cita
Antiguo 17-03-2016, 21:21:54   #2
Gerardo Oakley
Enviar un mensaje a través de AIM a Gerardo Oakley Contactar con Gerardo Oakley a través de MSN
Predeterminado Re: Diferencia performance entre 4runners 4th gen
Cual es tu pregunta.??
Gerardo Oakley está offline   Responder Con Cita
Antiguo 18-03-2016, 10:49:12   #3
Zorlac
Son cosas diferentes:
Además estas leyendo texto referidos a versiones que se vendieron en USA
(Usa Specs) resumiendo la historia es asi:
4runner USA
4gen
2003-2005
Motor 1GR FE 4.000 cc v6 vvti / caja A340F (PRND32L)/ traccion part time
Motor 2UZ-FE 4.700 cc v8 vvit / caja A750F (PRND432L) /traccion FULL TIME
2005-2009
Motor 1GR FE 4.000 cc v6 vvti / caja A750F (PRND432L) /traccion part time
5gen
2010 --->
Motor 1GR FE 4.000 cc v6 DUAL vvti / caja A750F (PRND+S-) /traccion FULL TIME
__________________________________________________ _______________
4runner Chile
2003-2005
2005-2009
5gen
2010--->
En todas las configuraciones las RP cambian en 2 rangos o es 41/11 o 43/11
la caja A340F tiene varilla para medir y usa aceite ATF Type IV Toyota
la caja A750F no tiene varilla para medir y usa aceite ATF WS Toyota...
A mas "nuevo" el motor 1GR-FE le iban añadiendo mas power.....y torque
La "mejor combinación" 1GRFE + A340F + RP 3,9 para offroad, desde stock
La "mejor combinación" para mucha autopista 1GRFE + A750F + RP 3,7 Part Time
La "mejor combinacion" para sentirse siempre seguro y sacrificando consumo 1GRFE + A750F + RP 3,7 FULL TIME
Lo mejor de todos los mundos y sin preocuparse del consumo, y teniendo maximo agarre
la USA specs 2UZFE + A750F Full time
eso te puedo ayudar
Última edición por Zorlac fecha: 18-03-2016 a las 11:06:50 Razón: agregue flechas
Antiguo 22-03-2016, 13:03:56   #4
turbo_lover
Empezado por Gerardo Oakley Ver Mensaje
Me llamo la atención que las post 2005 figuraran con menos HP que las versiones anteriores.
Slds
Antiguo 22-03-2016, 13:18:40   #5
turbo_lover
Muchas gracias, me quedo mas claro el tema.
Lo único que no me quedo muy claro es la diferencia de potencia y torque entre las 4th Gen 1GR-FE (o si existiera alguna diferencia), independiente de las cajas utilizadas.
En algunas paginas aparecen con 245 HP y 282 lb.-ft para todas las versiones (entre el 2003 hasta el 2009), y en otras paginas 236 hp y 266 lb-ft para las post 2005 (no es muy lógico) ...
Muy agradecido
Empezado por Zorlac Ver Mensaje
4runner USA
4gen
2003-2005
2005-2009
5gen
2010 --->
4runner Chile
2003-2005
2005-2009
5gen
2010--->
eso te puedo ayudar
La franja horaria es GMT -3. Ahora son las 08:45:18.
