Antiguo 15-08-2005, 14:14:44   #1
andres_kike_lopez
Avatar de andres_kike_lopez
Predeterminado Nuevo Toyota Megacruiser
Algo se parece a uno gringo que hay por ahi ( lease sarcasticamente )
Especificaciones
Standard Metric
GENERAL
Name Megacruiser Megacruiser
Model 4100 (AT) 4100 (AT)
Reference KK-BXD20V-RRPEZ KK-BXD20V-RRPEZ
ENGINE
Type 15B-FTE, diesel, turbo-charged and intercooled, 4-valves/cyl 15B-FTE, diesel, turbo-charged and intercooled, 4-valves/cyl
Cylinders 4 cylinders inline 4.104-Liter 4 cylinders inline 4.104-Liter
Bore and Stroke 4.25 x 4.41 (in.) 108 mm x 112 mm
volumetrique ratio 18,4 18,4
Power 150 hp @ 3400 rpm 150 hp @ 3400 rpm
Torque 280 lbs-ft @ 1800 rpm 39,0 kg-m @ 1800 rpm
Transmission 4-speed automatic O/D transmission 4-speed automatic O/D transmission
Ratios of limps speeds
1st 3.018 3.018
2nd 1.548 1.548
3rd 1.000 1.000
4th 0,765 0,765
RG 2,678 2,678
Low range 2,488 2,488
Axle ratio 3,700 3,700
Hub reduction 1,692 1,692
CONNECTIONS TO THE GROUND
Suspension 4 wheel independent, double wishbone 4 wheel independent, double wishbone
FR/RR Steering box gear ratio 21,99/18,72 21,99/18,72
Turning radius 18.4 ft. 5.6 m
Tires 37 x 12,50 R 17,5-8 (run flat) 37 x 12,50 R 17,5-8 (run flat)
Brakes 4 inboard ventilated discs 4 inboard ventilated discs
Transmission Full-time 4x4 Full-time 4x4
différentiels centre differential lock centre differential lock
WEIGHTS AND CAPACITIES
Overall length 200.4 in. 5090 mm
Overall width 85.4 in. 2170 mm
Overall height 81.7 in. 2075 mm
Wheelbase 133.7 in. 3395 mm
Tread width (front/rear) 70.7 in./69.9 in. 1795 mm/1775 mm
Ground Clearance 16.5 in. 420 mm
Curb weight 6395 lbs. 2900 kg
Gross Vehicle Weight Rating - GVWR 8445 lbs. 3830 kg
Payload 1323 lbs. 600 kg
Seats rows 2 2
Seating Capacity 6 6
Maximum Cant 50° 50°
Approach angle 49° 49°
Departure angle 45° 45°
Angle of breakover 33° 33°
Fuel tank 28.5 gals. 108 l
Mas info en:
http://www.megacruiser.com/
Antiguo 15-08-2005, 18:01:29   #2
FJ40Diesel
El famoso mega Cruiser, ya se fueron al chanco los ponjas con el parecido al Hummer, pero si se cumple lo que siempre pasa... deben haber mejorado algunas cosas..... como el caso el siaetema de dirección trasero que está de lujo.
Ya tiene bastantes años ese modelo, incluso aparece en desarme en el catálogo electrónico de partes de Toyota (Versión asiática) yo me dedico a mirar y reir ya q salen los repuestos y todo.... jajajaja tal como las Hilux, 4runners Tercel Corollas ....etc etc
Lástima q los japoneses se lo guardaron para ellos no más... al parecer hay un par fuera de Japón uno en Alemania y por ahí....
Saludos!
FJ40Diesel está offline   Responder Con Cita
Antiguo 15-08-2005, 20:20:16   #3
Predeterminado Re: Nuevo Toyota Megacruiser
Empezado por andres_kike_lopez
De nuevo no tiene mucho, la proimera vez que lo vi fue hace varios años, y definitivamente el un Hummer bien hecho, al menos esa inpresion me dio segun lo que se puede ver por fuera.-
Antiguo 16-08-2005, 00:48:51   #4
Como dicen, ya tienen artos años. Se ve arto mas confortable y tecnologico k un Hummer, me imagino la calidad igual debe ser superior.
Antiguo 16-08-2005, 18:38:09   #5
LAB
muy feo
Antiguo 18-08-2005, 18:36:02   #6
Dario_LJ
En la provincia de Almería, España, donde yo vivo hay uno, solo lo e visto 1 vez y no tenia camara de fotos , pero ves eso y un hummer al lao parese un suzuki.. es megabestiaaaaa
Antiguo 18-08-2005, 18:58:23   #7
Empezado por Fantasma-4x4
Yo he estado arriba jugando y moviendo perillas, y se nota la diferencia :wink:
Toyota Fj45...100% original $2 millones Churri-Pilme Venden - Partes y accesorios para 4X4 2 09-08-2005 23:22:46
ARB PARA TOYOTA 8" CON COMPRESOR TODO NUEVO!!! VENDIDO! Kronos Venden - Partes y accesorios para 4X4 4 18-07-2005 21:38:47
Twisted Andes Sortea autoadhesivo Toyota Racing Development Gonzalo Bravo General 21 24-12-2003 16:15:09
samurai con motor toyota 22re???? Alberto Bravo General 4WD 24 27-11-2003 20:33:36
La franja horaria es GMT -3. Ahora son las 23:39:31.
