#1 |
Alguien tiene información sobre este motor que me están ofreciendo.
caballos, torque, repuestos, fotos, cualquier cosa saludos |
#2 |
Key Specs 1994 6vd1 Engine Specs
General Specs Type: V6, 3.2L, belt-driven SOHC and DOHC, 24-valves, aluminum block and heads Displacement: 3165cc (193 cid) Bore x stroke: 93.4 x 77mm (3.677 x 3.031 in.) Horsepower: 190 hp @ 5,600 rpm (DOHC) or 175 @ 5,200 rpm (SOHC) Torque: 195 ft.-lbs. @ 3,800 rpm (DOHC) or 188 ft.-lbs. @ 4,000 rpm (SOHC) Compression ratio: 9.3:1 (SOHC) or 9.8:1 (DOHC) Emission control: EGR, EVAP Fuel system: General Motors Fuel pressure: 25-30 psi @ idle, 41-46 psi unregulated Fuel injectors: SOHC, 2 ohms; DOHC, 12.2 ohms Oil pressure: min 57 psi @ 3,000 rpm Valve clearance: hydraulic Spark plug gap: 0.040 in. (1.05mm) Firing order: 1-2-3-4-5-6 (No.1 on right bank) Ignition timing: ) 5° @ idle Base idle speed: 750 rpm |
#3 |
Para mayor claridad :
Año 1992 - 1995 6vd1 Engine Specs General Specs Type: V6, 3.2L, belt-driven, SOHC Aluminum block and heads Displacement: 3165cc (193 cid) Bore x stroke: 93.4 x 77mm (3.677 x 3.031 in.) Horsepower: 175 @ 5,200 rpm Torque: 188 ft.-lbs. @ 4,000 rpm Compression ratio: 9.3:1 Emission control: EGR, EVAP Fuel system: General Motors Fuel pressure: 25-30 psi @ idle, 41-46 psi unregulated Fuel injectors: SOHC, 2 ohms Oil pressure: min 57 psi @ 3,000 rpm Valve clearance: hydraulic Spark plug gap: 0.040 in. (1.05mm) Firing order: 1-2-3-4-5-6 (No.1 on right bank) Ignition timing: ) 5° @ idle Base idle speed: 750 rpm Años 1996 - 1999 6vd1 Engine Specs General Specs Type: V6, 3.2L, DOHC, 24-valves, aluminum block and heads Displacement: 3165cc (193 cid) Bore x stroke: 93.4 x 77mm (3.677 x 3.031 in.) Horsepower: 190 hp @ 5,600 rpm Torque: 195 ft.-lbs. @ 3,800 rpm Compression ratio: 9.8:1 Emission control: EGR, EVAP Fuel system: General Motors Fuel pressure: 25-30 psi @ idle, 41-46 psi unregulated Fuel injectors: 12.2 ohms Oil pressure: min 57 psi @ 3,000 rpm Valve clearance: hydraulic Spark plug gap: 0.040 in. (1.05mm) Firing order: 1-2-3-4-5-6 (No.1 on right bank) Ignition timing: ) 5° @ idle Base idle speed: 750 rpm Año 2000 - 2003 (despues RIP) Idem al anterior DOHC pero con 205 Hp |
| Juegos 4x4 | GRaN_PeYuCo | General | 106 | 14-05-2010 18:42:24 |
| RAID ATACAMA 2007, 25 años de Acción y Aventura | Pato Ríos | Paseos, Raids, Competencias y Eventos 4x4. | 1963 | 05-09-2007 01:16:40 |
| MAM mal de altura causas y prevención (para novatos) | Ermitaño | Novatos | 5 | 28-04-2007 15:58:56 |
| Como elegir un Turbo | VSilva | General 4WD | 3 | 09-07-2006 15:37:54 |
| MAS INFORMACION DEL RALLY | Francisco Lopez | General ATV / UTV | 0 | 22-04-2004 07:44:20 |
