Antiguo 28-12-2005, 22:12:35   #1
Predeterminado Robby Gordon al Dakar 2006
No tenia idea, pero Robby Gordon va a correr el Dakar este año en auto propio, un "Hummer H3" (buggy porsupuesto)
Robby Gordon Off-Road Dakar Hummer H3 Technical Specifications
TEAM DAKAR USA > Tech Specs
CHASSIS & SUSPENSION
Material: 4130 steel alloy space frame construction
Wheelbase: 120 inches
Track: 88 inches front and rear
Overall Length: 174 inches
Overall height: 65 inches
Weight: 4,500 pounds
Front Suspension: Double “A” arms with coil-over springs and specially calibrated, four position-sensitive by-pass shocks by King. Total vertical wheel travel 20 inches.
Rear Suspension: Semi-trailing lower arm with integral hubs, 934 series CV joints and stub axles by Kartek Manufacturing. King coil-over four-position shocks and springs. Total vertical wheel travel 20 inches.
Brakes: Four wheel disc ProAm brakes by Kartek Manufacturing. A special hand-operated “splitter” brake in the cockpit enables the driver to make tighter and faster turns by isolating the right and left rear brake systems
Steering: Robby Gordon Motorsports power-assisted rack and pinion. One turn lock to lock (37 degrees)
Fuel System: Twin fuel tanks, with Fuel-Safe fuel-cells carry 100 gallons of Regular Grade ASO mandated pump gas. Mileage varies according to conditions, but under the worst-case scenario the Hummer H3 can cover 500 miles without refueling
Jacking System: Twin Howe integral chassis mounted hydraulic rams can lift either side of the car to facilitate a change of tires or extracting from sand and/or mud
TIRES & WHEELS
Tires: Toyo Open Country M/T 37 x 14.50R15 (two spares are carried on board)
Wheels: Robby Gordon 15 x 6.5 alloy racing wheels with integral bead locks.
NAVIGATION
Navigation Aids: Twin Terra-Trip odometers with KVH digital compass, twin GPS, with ASO supplied Iritrac team navigation/locator units. Note: ASO GPS units are purposely limited in accuracy by the organizers to place a premium on the team’s navigation skills. By ASO regulation no communication systems of any type are allowed. The Iritrac system will allow viewers to follow the progress of the race in real time on the team’s website, Robby Gordon.com The Hummer is also equipped with an ASO required Belize satellite tracking emergency, homing beacon which, if activated, immediately disqualifies the entry.
BODY & INTERIOR
Body: Carbon fiber replica of the Hummer H3 made by Menards Engineering Limited in Oxfordshire, England. The two-place cockpit for driver and navigator is completely sealed, filtered by UNI and cooled by an engine driven-air conditioning system.
Seating: Twin Custom built MasterCraft buckets with Simpson five point harnesses. Driver and navigator also wear custom made Simpson fire suits
Electrical and Lighting Systems: Twin Pro-Comp batteries power a Milspec type, custom wired RayChem harness designed and fabricated by James Lin. Lighting by three Hella HIDs units on roof and two high beam/low beam Hella HID units on the front bumper with 55 watt street legal lamps.
Custom fabricated RGM/RacePak digital instrument panel allows monitoring of all vital systems.
ENGINE
Rear mounted, GM designed, fuel injected, normally aspirated, with alloy block and heads, 427 CID, LS1 series V8, built by Katech Engineering in Detroit and specially tuned and mapped for desert racing by Scott Urshell of UMI in Phoenix Arizona.
The engine build specifications, with the exception of compression ratio and its wet sump, are almost identical to those used by GM Racing’s factory Corvettes to win the GT1 Class at the 24 Hours of Le Mans, France, on three different occasions.
ASO regulations limit power by use of a sealed induction system using a 37mm inlet anulus. A four-gallon plenum feeds double filtered air to the engine. Bassani Headers with a single Magnaflow muffler keeps the engine within FIA mandated noise limits.
Cooling: Seven-gallon re-circulating through a Ron Davis radiator with two integral heat exchangers for engine and transmission coolant. Ten gallons of emergency coolant/drinking water are carried on board in two five-gallon containers.
TRANSMISSION
5-Speed sequential Albins/Weddel manual shift transaxle. Power is fed through a multi-plate Tilton Engineering clutch assembly.
Última edición por Gonzalo Bravo fecha: 28-12-2005 a las 22:16:26
Antiguo 28-12-2005, 22:50:09   #2
Talking
Estos gringos , todo tiene que ser top , hasta las graficas... FOOSE
Antiguo 29-12-2005, 01:56:45   #3
MacMarquez
y cuanto ira a durar ? 6 etapas ?
Antiguo 29-12-2005, 02:08:55   #4
OB1
Avatar de OB1
Edad: 67
Empezado por MacMarquez4x4
Impresionantes las especificaciones...¿pero no podría haberlo hecho más liviano?
Lo otro: dice
"Tires: Toyo Open Country M/T 37 x 14.50R15 (two spares are carried on board), Wheels: Robby Gordon 15 x 6.5 alloy racing wheels with integral bead locks."
Si leo bien, dice neumáticos 37x14.50r15 en llantas de 6.5" de ancho???? no cacho
OB1
Antiguo 29-12-2005, 09:12:19   #5
Ojala Gane, para que tenga emocion la carrera, ya que siempre es entre dos marcas.-
Ademas que no se si alguna vez ha ganado un 4X2.-
Antiguo 29-12-2005, 12:27:52   #6
AMERICO
Avatar de AMERICO
Empezado por Gonzalo Bravo
lo que yo se, es que SCHLESSER gano el DAKAR en los años 1999 y 2000...
en el buggie renault.
En todo caso ojala Gordon cuide la maquina ya que el año paso
se volco muy fuerte y quedo fuera a unas pocas etapas de
iniciarse el dakar2005.
hay un buena pagina con informacion
www.raid-live.com
SALUDOS...
Antiguo 29-12-2005, 13:37:50   #7
CASALEX
Contactar con CASALEX a través de MSN
Lso Neumaticos Son De 6.5" Porke Si Le Ponen Llantas De 10 Por Ejemplo Se Rajan A Los Lados
CASALEX está offline   Responder Con Cita
Antiguo 29-12-2005, 13:58:32   #8
OB1
Avatar de OB1
Edad: 67
Empezado por CASALEX
¿por qué los laterales estarían más protegidos?
No deja de impresionarme que el neumático es 8" más ancho que la llanta. En todas las conversaciones se indica 2" de diferencia, y lo que más he escuchado es 4" de diferencia, pero 8 pulgadas jamás. Incluso hay argumentos respecto que el reborde del neumático que va en la llanta se hace pedazos. Eso puede no ser una consideración en una competencia corta, pero en una de largo aliento como PD....me parece que sí.
OB1
Antiguo 29-12-2005, 14:42:04   #9
Empezado por AMERICO
www.raid-live.com
SALUDOS...
Cierto, 99 y 00.
Bueno, ahora corre en un auto como el que corre siempre, ademas es "basicamente" la Red Bull con pinta de H3.-
Antiguo 30-12-2005, 09:42:32   #10
MacMarquez
seria interesante que ganara o punteara alguna estapa, pero con lo pata de fierro que es, es poco probable que llegue a Dakar.
El toureg le duro re pocas etapas
Auto pillado, auto pasado...sino un Robby Gordon AMERICO Rally Cross Country / Baja 5 23-06-2007 04:09:52
TATT ARGENTINA 9-10-11 y 12 Noviembre 2006 outdoor Paseos, Raids, Competencias y Eventos 4x4. 34 22-12-2006 11:03:24
TATT ARGENTINA 9-10-11 y 12 Noviembre 2006 outdoor Rally Cross Country / Baja 4 27-10-2006 19:32:23
Que hay en firme de Salazar en en H3 de Robby Gordon? Gonzalo Bravo Rally Cross Country / Baja 52 17-04-2006 00:00:55
Video Robby Gordon pato castro General 0 01-06-2004 11:35:45
La franja horaria es GMT -3. Ahora son las 10:36:43.
