Antiguo 31-12-1969, 21:00:00   #1
Predeterminado Nissan Titan V8 = USA agarrate los pantalones
CON 300 HP y un motor V8 de 5.6 litros, hara que las RAM, Silverados y F150 se hagan "pipi" DE MIEDO .... AHAHAHAHAHAH
Detroit has dodged bullets before – in the full-size truck market, that is. The high-profit domain of the Big Three has seen the likes of the Toyota T100 come and go, and the Toyota Tundra come very close and take a significant piece of business away from their mainstays. But not until now has a Japanese maker taken on the full-size market so directly, in size, mission, even in country of origin.
Nissan’s new 2004 Titan, which made its debut at the Detroit show, is a full-frontal assault on Detroit’s profitable big pickups. It’s built on a new platform dubbed ZW, which also will spawn a new Frontier/Xterra in the not-too-distant future. The Titan spans the same rough critical dimensions as the Ram, Silverado and F-150. It sports a 300-plus horsepower V-8, standard King Cab configuration with two rear-hinged and two front-hinged doors, and high towing capacity. And Nissan is betting its heavy nod to flexibility, especially in the Titan’s bed, will win it some buyers from the more conventional trucks from Chevy, Ford and Dodge.
Nissan pegged plenty of performance benchmarks with the Titan because they knew the Titan had to be good to enough show up on the radar of domestic truck shoppers. “We don’t have a lot of credibility in this segment,” said Larry Dominque, Chief Product Specialist, Nissan Titan. Their goals for building the Titan were to make an expressive shape that had the best in class power, fuel economy and driving range.
To that end, the Titan comes with a 5.6-liter V-8 rated at more than 300 horsepower and 375 pound-feet of torque. Loosely based on the Infiniti V-8, Nissan calls this iteration the “Endurance” V-8. The 300 hp is achieved without the use of variable valve timing; Dominique says with VVT the engine can “easily make 30 or 40 hp more,” and also notes that a supercharger will fit neatly in the V-8’s 90-degree valley. The V-8 does have other semi-exotic hardware, though, including a microfinished forged steel crankshaft and moly-coated pistons.
With the sole engine – a V-6 is in the discussion stage -- the new Titan offers a only a five-speed automatic transmission, no manuals. With that gearbox, the Titan is rated at 9400 lb towing capacity, just shy of best in class. (Before word of the Titan’s tow rating was made public, Ford had issued its 2004 F-150 rating of less than 9400 pounds. Later, Ford updated its numbers and now rates the ’04 F-150 at 9500 lb towing capacity.)
Four-wheel drive is available on the Titan in a system that offers only electronic shift on the fly below 50 mph. Soon after launch, Nissan says it will offer an off-road package with a lower-ratio Dana 44 axle, an electronic locking rear differential, Rancho shocks and bigger all-terrain tires. Power rack-and-pinion steering is standard, as are four-wheel disc brakes with anti-lock control.
The shape, Nissan hopes, will be perceived as a modern, fresh break with pickup tradition. The “fourth way” Nissan has chosen cuts a leaner figure than the bulky American designs. The sole cabin at launch is the King Cab, which offers two full front-hinged doors paired with two rear-hinged half doors. A full four-door Crew Cab will be unveiled at April’s New York auto show.
The Titan’s bed design benefits from a new generation of crossovers and the call for more flexibility in cars and trucks of all sizes and shapes. For the hardcore truck users, Nissan has made a spray-in black bedliner available through the factory. There’s also a new Utili-track System that incorporates five C-channels in the bed that will accommodate a range of accessories, like a planned sliding toolbox, dividers, even removable cleats for tying down cargo. And along with special bed lighting, Nissan also has fitted the optional flexible bed with four stake pockets and a bedside storage compartment that will hold work gloves, ball hitches, and other equipment in a bin located behind the driver-side rear wheel, accessible even when the bed is full. The Titan’s bed hold the ubiquitous and proverbial 4x8 sheet of plywood, so fear not, Home Depot devotees.
Inside, Nissan plans a thorough range of standard and optional equipment, including power front seats with memory, heated front seats, flip-up rear seat cushions with grocery hooks. And the doors to the King Cab model sport a unique feature that Nissan dubs the Wide-Open rear door. It swings open nearly 180 degrees, giving much improved access to the rear seats/cargo area.
The Titan will be one of four vehicles assembled in the Canton, Miss. facility, along with the new Nissan Quest, Nissan full-size SUV and full-size Infiniti SUV. The new 3.5-million square foot Canton facility is schedule to start production in summer 2003, and Nissan’s goal for volume is 100,000 Titans a year. Nissan’s Decherd, Tenn. plant will produce the Titan's Nissan Endurance 5.6-liter V-8. Nissan suggests the Titan will be priced as an exceptional value, though in King Cab V-8 configuration not less than $30,000.
Looking ahead, a Nissan full-size SUV based on the Titan, but with an independent rear suspension, will be shown at the New York Auto Show along with the Titan Crew Cab. And Nissan seems to be studying seriously the development of a heavy-duty pickup. Diesels, too, are on the consideration list, and execs say they’ve talked to Delphi about that company’s Quadrasteer four-wheel steering.
The Titan is scheduled to go on sale nationwide later this year.
Antiguo 31-12-1969, 21:00:00   #2
pato castro
Avatar de pato castro
Oye JP, ¿viste el nuevo Infiniti FX 45? la cagó...315 h.p. y hace de 0 a 100 km/h como en 6 seg.
http://www.infiniti.com/discover/Mod...,24508,00.html
Antiguo 31-12-1969, 21:00:00   #3
Si Pato, es tambien el Nissan Murano como el Infinity... ese motor esespectacular !! Si bien no me compraria uno (ademas de lo caro) , cada dia los SUV son menos Jeep y mas autos, vean el nuevo 4 Runner 2003 parece una Rav 4 con motor V8 ..... :(
Antiguo 31-12-1969, 21:00:00   #4
pato castro
¿Qué tiene de malo la nueva 4Runner? la encuentro espectecular.
Antiguo 31-12-1969, 21:00:00   #5
Perdió el chassis, ahora es Unibody .... y parece el SUV de Meteoro ... los guardafangos son una copia descarada de la Chevy Avalanche y la cola es de una Ford Escape ....
Antiguo 31-12-1969, 21:00:00   #6
pato castro
...pero igual es Toyota. :wink:
Antiguo 31-12-1969, 21:00:00   #7
Huummm ... bueno
(entre Toyota, Nissan, Mitsubishi y Mazda, cero que las diferencias son minimas, son solo un nicho de mercado de gustos ....)
Antiguo 31-12-1969, 21:00:00   #8
Aqui hay un "update" muy interesante... LIVE... chao Tundra, Chao T100, chao Tacoma.... viva Nissan !!!!!
http://www.nissanusa.com/vehicles/Me...,30438,00.html
Antiguo 31-12-1969, 21:00:00   #9
Si fueras a Japon verias los Nissan y Toyotas que hay alla y entenderias lo que realmente son estas dos marcas. Un mundo de diferencia con Honda por ejemplo.
Antiguo 31-12-1969, 21:00:00   #10
pato castro
Predeterminado Re: 4Runner .
Empezado por Alfred
Empezado por JPVM
calidad y exclusividad Nissan ....
que quieres decir ... que 70% de los taxis santiaginos son "exlcusivos" ???
creo que son palabras reservados para bmw/mercedes/audi/volvo .... pero no para nissan (somos honestos)
alfred
Eso sonó bastante clasista... además que acá lleguen Mercedes y BMW bastante caros es sólo porque hay un mercado establecido, pero estas marcas también tienen modelos bastante básicos. Ahora, ¿conoces los Infiniti?
Infiniti es Nissan, al igual que Lexus es toyota, pero la gama de lujo. Años atrás un tipo de Ferrari dijo que el modelo Honda NS-X no podía siquiera ser comparado con un Ferrari porque no tenía ni la tradición ni la clase y simplemente no podía ser comparado, pero la diferencia más importante es la confiabilidad de un auto japonés, que por más tradición que tenga igual falla, y harto.
Nissan 4x4 : Qué diferenciales tengo ? JPVM General 4WD 36 28-08-2016 22:52:35
NISSAN D21 O TOYOTA HILUX (gasolina) JCPA General 4WD 46 15-06-2012 11:02:49
Juegos 4x4 GRaN_PeYuCo General 106 14-05-2010 18:42:24
Como reconocer los Diferenciales !! JPVM General 4WD 37 05-10-2009 02:03:33
Dakar Camvoy Rally Cross Country / Baja 64 15-01-2006 14:09:14
La franja horaria es GMT -3. Ahora son las 09:28:10.
