Antiguo 15-06-2006, 11:59:56   #1
GrizzlyCamp
Predeterminado tranfer chevrolet blazer modelo 207 C.
caja de tranfer chevrolet blazer modelo 207 C. año 92
saludos,Juan Figueroa.
09-7447943
GrizzlyCamp está offline   Responder Con Cita
Antiguo 15-06-2006, 14:32:45   #2
pzapata
Empezado por JF Macaco
caja de tranfer chevrolet blazer modelo NP207 C. año 92
09-7447943
Antiguo 15-06-2006, 18:59:36   #3
GrizzlyCamp
EXCELENTE.
:razz:
Antiguo 23-06-2006, 18:15:52   #4
GrizzlyCamp
Predeterminado Precio
Agrego Info Adicional.
New Process 207
This part time transfer case is found in 1984-1987 XJ's and the 1987 YJ. The NP-207 was the transfer case in Jeep referred to as the Command Trac option.
Featuring chain-driven, planetary reduction, aluminum transfer case has a 2.60-to-1 low range and direct in high. New for Jeeps in 1984, the 207 transfer case had the front output yoke positioned on the driver's side.
The NP 207 is easily identified by the numbering in its red and silver tag on the back. This transfer case is a fairly strong unit. Its replacement was the NP 231. The 207 can be mated to some upgrade transmissions, but it can take some custom machine work to do so. We recomend you call and discuss your swap with us in these scenarios.
La franja horaria es GMT -3. Ahora son las 03:57:50.
