Antiguo 03-02-2004, 23:40:18   #1
Predeterminado Samurai version Off Road Hawaii
Interesante Samurai para los que les gustan estos ...
http://www.speedhawaii.com/rides/ima...evesuzuki1003/
Algunos Specs:
Owner: Steve
Year: 1988
Manufacturer: Suzuki
Color: Custom
Model: Samurai
Awards:
4 Wheel Magazine December 2002
1st Place 2003 Hawaii Top Truck Challenge
Rock Course
Modifications:
Chassis
1988 Suzuki Samurai
Engine
Rebuilt 1988 Suzuki 1300 block
Decked (.010) blue printed and balanced
Stock Bore
Mild Ported Cylinder Head w/ Isky 'High Lift' cam & 2-degrees advance
Center Force 'Dual Friction' Clutch
External Oil Cooler
'Epoxied Solid' Fan
Exhaust
Pacesetter long tube headers 2-1/4" exhaust pipe to a 2-chamber Flowmaster muffler
Fuel
Holly Projection 1D (modified {Don't event attempt
this at home!} ) fitted to a modified stock intake
8-gal tank fuel cell (foam filled)
Moroso Cool Can
Ignition
Stock Distributor set @ 34-degrees total advance
MSD Blaster coil
10 mm Taylor wires w/ heat shield
NGK Iridium IFR6A-11 spark plugs
Transmission
Stock 'oldie, but goodie' 1988
Transfer Case
Sumo 6.1 Gearing
Roll Cage
Custom and full 1/4" steel skid plate w/ 1/8" steel
rocker slider plates
Axle (Front)
Diff. OEM 5.12 w/ mini-spool and 'Double Tough' axles
1/4" thick steel pumpkin cover and 1/4" steel channel welded to bottom of axle tube
3/16" steel front truss w/ Top-Over steering
Axle (Rear)
Diff. OEM 5.12 back (welded) 1/4" pumpkin cover
1/4" steel channel welded to bottom of axle tube and upper outer after spring perch
Steering
Chevy P/S pump (modified for pressure & volume)
Chevy 2x gear box w/ drop pitman arm
AGR 'Rock Ram' power assist
External cooler
Drive Shafts
Driveshaft Solutions 'BIG'
Suspension
8" Lift Coil Spring stretched 4" foward and 4" rearward
Front w/Doetsch Tech shocks (having special 'spherical bearing' in lower end)
Rear w/ Doetsch Tech Coil-Over shocks
Electrical System
Stock alternator
Battery safety shutoff switch
12V dry cell battery
Winch
Ramsey 8,000lb. w/ synthetic rope
Rims and Tires
Steel 2" back spacing w/ sidewall screws on both sides
Micky Thompson Baja Claw 'Competition Rubber Compund = Drag Slick Rubber' 37x12.5x15
Desarme SAMURAI DESCAPOTABLE RoNdrigo Pastén Venden - Partes y accesorios para 4X4 93 14-09-2012 13:41:39
2005 TWISTED ANDES JAMBOREE - Promo Gonzalo Bravo Paseos, Raids, Competencias y Eventos 4x4. 447 30-04-2005 03:59:37
Parachoques Off Road para Samurai Cristian General 4WD 9 15-03-2005 20:18:20
web favoritas ullrich General 8 19-12-2003 13:49:28
La franja horaria es GMT -3. Ahora son las 17:48:12.
