Antiguo 14-01-2007, 21:48:46   #1
Rodrigo Ahumada V.
Avatar de Rodrigo Ahumada V.
Predeterminado GPS Garmin 76 S, Con Software y mapas actualizados
GPS 76 s, Es perfectas condiciones
Funciona con pilas y con 12V,(Cable no inlcuido)
Incluye Base para fijar al Jeep
Pantalla en Blanco y Negro
Valor $ 150.000
Descripcion
"If you’re a devoted mariner or serious outdoor enthusiast, our new GPSMAP® 76S is the GPS/mapping unit for you. The "S" in the product name stands for "sensors", because the GPSMAP 76S incorporates a GPS receiver, barometric altimeter, and an electronic compass that deliver precise location, elevation, and bearing information to take adventurers as high or as far as they want to go. The unit also contains a basemap of North and South America, including major highways, thoroughfares, rivers, lakes, and borders, with plenty of memory (24 MB) for downloading MapSource® data. It's also waterproof and floats in water— and its larger screen, increased readability, bigger buttons, and rugged design make this unit at home in even the harshest conditions."
Foto
Ford Ranger 4.0 V6..., en Upgrades..., (Si!, otra vez...!)
Última edición por Rodrigo Ahumada V. fecha: 09-08-2007 a las 13:19:29
Rodrigo Ahumada V. está offline   Responder Con Cita
Antiguo 19-01-2007, 09:50:38   #2
Rodrigo Ahumada V.
Se aceptan ofertas!!!...(Razonables por supuesto!)
Última edición por Rodrigo Ahumada V. fecha: 19-01-2007 a las 16:49:34
Antiguo 24-01-2007, 12:02:27   #3
Rodrigo Ahumada V.
Ningun interesado...?
Antiguo 13-02-2007, 14:42:31   #4
Rodrigo Ahumada V.
Up....!
Antiguo 05-05-2007, 14:18:31   #5
Rodrigo Ahumada V.
Predeterminado Re: GPS Garmin 76 S, Con Software y mapas actualizados
Ningun Ineteresado!..., aun en venta...
Antiguo 05-05-2007, 23:48:51   #6
raliaga
Empezado por Rodrigo Ahumada V.
En todo caso es la raja este GPS ... hay que ser medianamente capaz para usarlo, quizas ese es el problema que no alla interes.....
La franja horaria es GMT -3. Ahora son las 19:38:25.
