General Temas no técnicos, Saludos y Sugerencias referentes a 4x4 y Offroad. |
Herramientas |
01-05-2004, 08:50:41 | #1 |
planeta off road de brasil
holaps
estuve mirando la web de planeta off road de brasil, que sale en los links http://www.planetaoffroad.com.br/p08m.htm este es el jeep de billj? right? porque no ha cambiado el motor? dentro de todos los upgrades que tiene me suena como uno de los mas obvios y faciles de hacer. por que no lo ha echo? es complicado en brasil? |
04-05-2004, 12:16:57 | #2 | |
Re: planeta off road de brasil
Sim, é o meu jipe........... :wink: Desde então, já troquei o motor para o 1.6 16V do Swift, entrou água no original......... Não troquei antes porque não havia necessidade, o 1.3 atendia bem com a redução GRS 2 e diffs 4,88....... Abraços, |
04-05-2004, 14:12:38 | #3 | ||
aaaaaaaaaaaaaa ok alla puro barro??????? |
04-05-2004, 20:13:21 | #4 |
Bill es americano, tal vez se le entenderia mejor si escribiese en Ingles .... :wink:
05-05-2004, 05:07:40 | #5 | |
OK, this time in English....... :P =========== Yes, that is my rig.......... :wink: Since thenm I´ve swapped the motor to a 1,6 16V from a Swift, water got into the original......... I hadn´t swapped the motor before because there was no reason to, the 1,3 worked well with the GRS 2 t-case and 4,88 diffs........ |
05-05-2004, 06:21:17 | #6 |
no worries billj
actually I got it just right the first time I was just wondering, that it works just fine cos you only have mud there? have you tried your configuration in rocks?? sand??? |
05-05-2004, 06:55:34 | #7 | |
With my gear reduction, I´ve had very little problems. Yes, the little 1.3 sometimes lacked torque in long mud runs, where tire speed is important. But in rocks, there was necer any problem. Sand I haven´t ran in much at all. The 1,6 16 valve is a LOT more powerful though. I never would have imagined such a difference........ :wink: Abraços, |
05-05-2004, 06:59:08 | #8 | |||
Leyendo despacio se entiende bien.
05-05-2004, 11:49:51 | #9 | ||
05-05-2004, 12:46:10 | #10 | |||
Compartir en Redes Sociales |
Temas Similares | ||||
IV Raid Fraternidad Off Road 2007 Organizado Por El Club Pucara 4x4 | chelocko | Paseos, Raids, Competencias y Eventos 4x4. | 350 | 27-08-2007 20:40:46 |
Revista Off Road | Javier Arancibia | General | 11 | 20-03-2007 12:48:31 |
4 Neumaticos 100% Off Road | AZZ | Venden - Partes y accesorios para 4X4 | 20 | 14-02-2007 21:47:44 |
Rally Road Book Ritoque | AMERICO | Rally Cross Country / Baja | 9 | 21-09-2006 16:44:43 |
Este Viernes 4 de Julio se lanza Revista Off Road 4x4 | RoNdrigo Pastén | General | 35 | 31-12-1969 20:00:00 |
