Antiguo 05-09-2007, 13:36:59   #1
Fernando Vliegenthart
Contactar con Fernando Vliegenthart a través de MSN
Predeterminado bloqueador EATON para GM12
Vendo bloqueador EATON para GM12 bolt, esta funcionando impecable..........
150.000
http://www.traction.eaton.com/prod2.htm
Mechanical Locking Differential
The Eaton mechanical locking differential was the first to be offered as an option to pickup drivers and today it is known around the world simply by the GM option code G80. This automatic unit, available as standard and optional equipment for rear drive and 4-wheel drive vehicles, makes traction problems a thing of the past. The Locker makes towing large boats and campers a breeze. Be sure to ask your dealer if your vehicle has an Eaton differential.
During lockup, a self-energized clutch system causes a cam plate to ramp against a side gear. This ramping action compresses those disc packs mentioned earlier. The ramping continues until both axles - and therefore both wheels - are spinning at the same speed. This is full lock, and it prevents any further wheel slip. (Note: Axle lockup can only occur at speeds below 20 mph.)
Fernando Vliegenthart está offline   Responder Con Cita
Antiguo 25-09-2007, 12:05:52   #2
Predeterminado Re: bloqueador EATON para GM12
up
Antiguo 25-09-2007, 15:14:59   #3
juan andrade
Avatar de juan andrade
Empezado por Fernando Vliegenthart Ver Mensaje
150.000
si la descripcion es correcta no sirve para gm 12,solo para eaton .averigua bien y si sirve para gm 12 yo estoy interesado
Antiguo 26-09-2007, 13:32:13   #4
estimado, el bloqueador si sirve para GM12 bolt, de hecho actualmente esta instalado en ese diferencial (eran de una blazer)..............
dame un email y te mando fotos del bloqueador instalado en el diferencial y el comportamiento del jeep con el mismo trabajando................
Última edición por Fernando Vliegenthart fecha: 24-07-2009 a las 14:59:11
Antiguo 26-09-2007, 15:38:41   #5
juan andrade
andradefj40@hotmail.com
Antiguo 27-09-2007, 11:20:11   #6
fotos enviadas!!!
Antiguo 30-09-2007, 11:04:34   #7
el bloqueador ya esta afuera e impecable, lo pueden ver y analizar detenidamente los interesados
Antiguo 09-10-2007, 09:37:08   #8
up
Antiguo 21-10-2007, 10:15:49   #9
up
Antiguo 06-11-2007, 15:02:56   #10
no hay interesados??? el bloqueador esta impecable y el precio inmejorable................
La franja horaria es GMT -3. Ahora son las 23:19:46.
