| R/C Off Road Foro exclusivo para autos radiocontrolados Off Road, Stadium Truck, RC Crawling, etc. |
Herramientas |
#1 |
![]() Estaba con ganas de comprarme la F-350 High Lift.. pero despues de ver esta.. uff.. no sé compro esta y le compro a parte la carroceria de la 350? ... los dejo con la info y el link ***************** http://www.tamiyausa.com/product/ite...oduct-id=58397 Combining nostalgic feel with modern mechanics, the superbly detailed classic Toyota pick-up truck body is now mounted on the same chassis as the Ford F-350 High-Lift. # About the Model Durable ladder frame chassis features steel channel and resin crossmembers for high strength. # Adjustable front and rear leaf spring suspension system equipped with friction dampers. # 3-speed transmission allows gear changing and realistic low-speed driving. # Propeller shafts and slipper clutch efficiently transfer power to all wheels on any type of terrain. # Differential may be easily locked in place to enable improved off-road performance. # Highly-detailed injection-molded body complete with new parts for rear bumper, muffler, side steps, side mirrors, and wipers, accurately reproduces the classic pick-up truck. # Manufacturer logos depicted with metal transfer stickers, and various metal plated parts accentuate the truck's body. # Quick-access battery compartment enables easy battery changes without removing body. # Includes type 540 motor. # 4-channel transmitter, ESC, and running battery & charger are all separately required. # Installing the separately available Pick-Up Truck Multi-Function Unit MFC-02 (ITEM 53957) will further enhance the truck and put a wide range of realistic light, sound, and vibration effects at your fingertips. |
#2 | |
Saludos !!! |
#3 |
Uta que linda.... definitivamente mi veta RC va por los de Escala, se ve muy linda... ¿caja tres velocidades...? ademas... ATR
Felcitaciones!!!! |
#4 |
la pille anoche a las 3AM en la pagina de Tamiya (llegue ahi por RCCrawler)... pero interiorizandome un poco mas anoche cache q la van a lanzar luego.. aun no tiene codigo de Tower Hobbies. es cosa de esperar no más.
#5 |
Preciosa, increible el nivel de detalles.....el termometro comenzo a subir
#6 |
Compratela wn
esta filete |
#7 |
a todo esto la tienen en stock en hobby express en $273.600
por si hay algun otro calentin por ahi... |
#8 |
Edad: 61
#9 |
Edad: 30
hola no pues esta chidicima yo me quiero comprar una = pero no sse donde
