Antiguo 20-10-2007, 19:56:57   #1
Otto Nass
Avatar de Otto Nass
Predeterminado Manual Completo Vitara (motores G16, J20, H25)
Pongo a su disposición el manual completo de Vitara, en inglés. Son 5 archivos en formato pdf. En total son más de 2000 páginas.
ftp://manual:manual@208.113.189.21/M...o%20Vitara.zip
Tabla de contenidos:
General Information and
Diagnosis (G16/J20)
Diagnosis (H25)
Engine Mechanical (G16)
Engine Mechanical (H25)
Engine Mechanical (J20)
Engine Cooling
Engine Fuel
Engine and Emission Control
System (SFI for G16/J20)
System (SFI for H25)
Ignition System (G16)
Ignition System (J20/H25)
Cranking System
(Reduction Type)
Cranking System
(No-Reduction Type)
Charging System
Exhaust System
TRANSMISSION, CLUTCH
AND DIFFERENTIAL
Manual Transmission (Type 1)
Manual Transmission (Type 2)
Automatic Transmission
Clutch (Hydraulic Type)
Transfer
Differential (Front)
Differential (Rear)
BODY ELECTRICAL SYSTEM
Wiring Diagram
Lighting System
Instrumentation/Driver
Information
Windows, Mirrors, Security
and Lock
Immobilizer Control System
BODY SERVICE
RESTRAINT SYSTEM
Seat Belt
Air Bag System
GENERAL INFORMATION
General Information
Maintenance and Lubrication
TABLE OF CONTENTS TABLE OF CONTENTS SECTION SECTION
0B
HEATING AND AIR
CONDITIONING
Heater and Ventilation
Air Conditioning
STEERING, SUSPENSION,
WHEELS AND TIRES
Front End Alignment
Power Steering (P/S) System
Steering Wheel and Column
(Not Equipped with Air Bag)
Air Bag Steering Wheel
and Column
Front Suspension
Rear Suspension
Wheel and Tires
DRIVE SHAFT/PROP. SHAFT
Front Drive Shaft/Shaft
Bearing, Oil Seal
Propeller Shaft
BRAKES
Brake Pipe/Hose/Master
Cylinder
Front Brakes
Parking and Rear Brakes
Antilock Brake System
Más un manual general para modelos diesel.
Otto
Última edición por Otto Nass fecha: 21-10-2007 a las 16:42:46
Otto Nass está offline   Responder Con Cita
Antiguo 20-10-2007, 21:23:26   #2
Pacer
Contactar con Pacer a través de MSN
Predeterminado Re: Manual Completo Vitara (motores G16, J20, H25)
tito.araya@gmail.com
Gracias
Pacer está offline   Responder Con Cita
Antiguo 20-10-2007, 21:42:39   #3
Otto Nass
Avatar de Otto Nass
Empezado por pacemaker Ver Mensaje
Ya lo envié, avísame si te llega a ver si funciona el correo y el archivo.
Antiguo 20-10-2007, 22:17:32   #4
Otto Nass
Avatar de Otto Nass
Una muestra: g16, j20, h25
Antiguo 20-10-2007, 22:24:10   #5
Panchopirata
Avatar de Panchopirata
fcoguerra@gmail.com
Agradecido de antemano
Antiguo 20-10-2007, 22:43:34   #6
Otto Nass
Avatar de Otto Nass
Empezado por Panchopirata Ver Mensaje
fcoguerra@gmail.com
Enviado
Antiguo 20-10-2007, 22:55:27   #7
Rex
Contactar con Rex a través de MSN
buena otto, me lo enviarias a chipyturex@hotmail.com...
seria buena idea subirlo a rapidshare o megaupload
Salu2 y gracuas
Rex está offline   Responder Con Cita
Antiguo 20-10-2007, 23:00:23   #8
Otto Nass
Avatar de Otto Nass
Empezado por Rex Ver Mensaje
Salu2 y gracuas
Nunca lo he hecho , si quieres puedes hacerlo cuando te llegue el mail, que ya está enviado.
Antiguo 20-10-2007, 23:01:53   #9
Otto Nass
Avatar de Otto Nass
Salu2 y gracuas
Rebotó el mail, tienes otro con más espacio disponible??
Antiguo 20-10-2007, 23:07:39   #10
Rex
El de la eñora...jejeje
karmi.vamp@gmail.com
gracias y tratare de subirlo
La franja horaria es GMT -3. Ahora son las 02:42:56.
