#1 |
Hola la consulta es la sgte:
Que versiones de Jeep Cherokee entre el 95 y 2000 existen ? Laredo,Pionner etc ..?? Tipos de yugos etc .. NECESITO uno de 4 puertas ojala diesel ,en 2,5cc 0 4.0cc SALUDOS Daniel ROA |
#2 |
alguien tiene info ?
#3 |
En esos años a Chile solo llegaron bencineros.
Desde el 95 a Chile solo llegaron 4.0 segun tengo entendido 95 - Sport 96 - Sport 97 - Sport 98 - Sport, Classic 99 - Sport, Classic 00 - Sport, Classic 01 - Sport, Classic, Creo que asi es la distribucion de modelos |
#4 | |
(There may be small differences, dependent upon trim level and/or optional equipment) Wheelbase = 101.4" Overall length = 165.3" - 168.8" Overall width = 67.9" - 70.5" Track = 58" Height = 64" (with roof rack 66.8") Ground clearance from differentials = 7.3" (Upcountry = 8.3") Approach angle = 37.6º - 38º Departure angle = 31º - 32.1º Breakover angle = 21º - 21.9º Curb weight 2wd = 2,891 lbs - 2,993 lbs Curb weight 4wd = 3,057 lbs - 3,386 lbs Cargo capacity = 71.0 cu ft. Body The body comes in both 2-door and 4-door styles with a rear hatch (liftgate). In 94 side-impact beams were added to the doors and roof was strengthened. The 3rd brakelight was added to the top of the liftgate as well. In 96 the body structure was strengthened some...it was not noticeable in overall appearance. In 97 the body and interior were redesigned. Most noticeably it gave the body smoother lines by changing the bumpers, flares, and moldings. The front fender was trimmed just below the headlights and replaced with plastic bumper endcaps that wrap around to the wheel well. The windshield washer bottle was relocated to the inside of the drivers side front fender and the liftgate was also changed from fiberglass to sheet metal. Engines
Manual Transmissions
All the transfer cases used are all chain driven with aluminum housings. T-cases were designated either NP or NV. They are essentially the same t-case...just a different "brand name" (NP was used for the purposes of this list:
Front Axles
Note: 8.25 axles - none of these axles were used on XJ's with ABS brakes. If you have ABS, you have the Dana 35. Without ABS you could have either axle. 8.25 axles are c-clip. Gearing
Drivers side airbag (mechanical) was added in 1995. Passenger side airbag was added in 1997. Airbags changed from mechanical to electronic in this year also. Espero te sirva Saludos Última edición por Mac fecha: 19-01-2008 a las 22:22:55 |
#5 |
Gracias " amigo MAC"
Ahora a estudiar y ver que es mejor ,ojala encuentre algo sanito y bueno o con minimos detalles , Saludos y gracias DANIEL ROA |
#6 | |
$4.600.000. Vendo Cherokee Classic 4.0 año 2000.4 puertas Bencinero Full equipo, doble airbag, frenos ABS, aire acondicionado, cierre, alzavidrios, direccion hidraulica 113.000 km. Acepto ofertas. Contactar al celular 97456049. opazo.julia@gmail.com |
#7 |
me encantan los chero; pero respecto a las compras; en que detalles hay que fijarse antes de tomar una desición??? a ver si algun dia le hacemos empeño..
saludso y suerte con tu compra. Enzo |
#8 | |
Pero en general no hay mayores diferencia que con otro auto cuando vas a comprar uno usado. Saludos |
#9 |
fijate si la caja puede pasar cambios en altas rev´s.......ojo con posibles juegos en la caja de dirección... ojo con el riel de inyectores, fijaté que no gotee.... fijate si funciona la tracción, con esto me refiero que funcione el sistema de vacios que acciona la horquilla para tener 4x4---
saludos hakuna |
#10 | |
Grande Twisted Saludos y gracias a todos por la ayuda . Daniel Roa |
