Antiguo 07-06-2004, 13:39:09   #1
Camilo Cádiz
Avatar de Camilo Cádiz
Predeterminado KFX700
hola.. buscando por inet encontre esta atv de kawasaki...
estas son las specs
SPECIFICATIONS
Engine: Liquid-cooled, four-stroke V-twin, SOHC, four valves per cylinder with wet sump lubrication
Displacement: 697cc
Bore and stroke: 82 x 66mm
Carburetion: Dual Keihin CVKR-D32 carburetors
Starting: Electric
Transmission: Kawasaki Automatic Power Drive System with forward, reverse and neutral
Final drive: Shaft
Frame type: Double cradle, racing type, high-tensile tubular steel
Suspension, front/wheel travel: Dual A-arms, coil-over shocks/9.25 in.
Suspension, rear/wheel travel: Linkless swingarm, upside-down gas-charged shock, dual-rate spring/7.9 in.
Tires, front: ITP Holeshot AT 22 x 7-10
Tires, rear: ITP Holeshot AT 22 x 11-10
Brakes, front: Dual discs with two-piston calipers
Brakes, rear: Sealed, oil-bathed, multi-disc
Overall length: 78.1 in.
Overall width: 47.0 in.
Overall height: 46.1 in.
Seat height: 33.5 in.
Wheelbase: 50.6 in.
Ground clearance (center of chassis/at rear axle): 9.6/6.3 in.
Lighting, headlights: Dual 45-watt halogen headlights, 5/21-watt taillight/brake light
Dry weight: 516 lbs.
Fuel capacity: 3.2 gal.
Footpegs: Sport-style, serrated
Color: Kawasaki Lime Green, Blazing Orange
Antiguo 07-06-2004, 13:51:11   #2
Camilo Cádiz
Antiguo 07-06-2004, 22:27:42   #3
Pito TJ
Se ve bastante rica... pero...
Empezado por Camilo Cádiz
para mi gusto.... pura
Antiguo 08-06-2004, 20:59:39   #4
Giovanni
Yo tambien encuentro una lata la falta de cambios... Kawasaki reinvento este segmento de ATV con la KFX 700, hicieron cambios sobre partes que parecian un standard como el estanque trasero, la falta de cambios, la transmision sin cadena y el freno trasero.
Este reporte es re-interesante acerca de esta moto.
P.D. Es feona la moto :?
La franja horaria es GMT -3. Ahora son las 01:54:41.
