Antiguo 22-08-2008, 20:35:38   #1
guilorca
Avatar de guilorca
Contactar con guilorca a través de MSN
Predeterminado Amplificador Blaupunkt Gta 2
Hola tengo disponible un AMPLIFICADOR BLAUPUNKT GTA 2 casi nuevo 1 mes de uso VALOR $65.000.-
Two channel mode max power: 2 x 110W into 4 ohms
- Two channel mode max power: 2 x 170W into 2 ohms
- Two channel mode RMS power: 2 x 55W into 4 ohms
- Two channel mode RMS power: 2 x 85W into 2 ohms
- Mono mode max power: 1 x 340W into 4 ohms
- Mono mode max power: 1 x 375W into 2 ohms
- Frequency response 10Hz - 26kHz
- Signal to noise ratio > 90dB
- THD (at full rated power) <0.05%
- 2 ohm stability in all channel modes
- Input signal 0.1 - 8.0V (will not accept speaker level inputs)
- Low pass filter: 50 - 250Hz variable
- High pass filter: 80Hz switchable
- Bass boost 0 - 12dB variable at 45Hz
- Nickel plated RCA input, RCA preamp output & speaker output terminals
- Power on and protection LED (green/red)
- Dimensions (190W x 57H x 260L mm
ATTE
GUILLERMO LORCA
GUIPARTS4x4
AV LAS CONDES 7784
09-5796300
SANTIAGO
Última edición por guilorca fecha: 07-10-2009 a las 17:56:13
guilorca está offline   Responder Con Cita
La franja horaria es GMT -3. Ahora son las 09:07:29.
